IMX8MP Jack detection issue with MAX98090 codec
2,183件の閲覧回数
pratham_malaviya
Hi there,
We are using the MAX98090 audio codec on a custom i.MX8MP-based board. The issue we are facing is with headphone jack detection.
In the MAX98090 codec driver, jack detection appears to work correctly — I can see debug prints when the jack is plugged in or removed. However, when streaming audio using aplay, audio is coming from both the speaker and headphone simultaneously, which is not the desired behavior. Ideally, the speaker should automatically turn off when headphones are connected.
I am wondering if this could be related to ALSA or PulseAudio configuration, or if something is missing in the device tree or driver setup.
For reference, I am attaching the device tree snippet of the  and the codec outputs of amixer -c 0 scontrols and pactl list cards command in the attached max-logs.txt file.
Any help would be appreciated!
DTS snippet:
sound-max98090 {
        compatible = "simple-audio-card";
        simple-audio-card,name = "max98090-audio";
        simple-audio-card,format = "i2s";
        simple-audio-card,frame-master = <&cpudai>;
        simple-audio-card,bitclock-master = <&cpudai>;
        simple-audio-card,bitclock-inversion;
        simple-audio-card,widgets =
                "Microphone", "Mic Jack",
                "Speakers", "Speakers",
                "Line", "Line In",
                "Line", "Line Out",
                "Headphone", "Headphone Jack";
        simple-audio-card,routing =
                "Headphone Jack", "HPL",
                "Headphone Jack", "HPR",
                "Line Out", "RCVL",
                "Line Out", "RCVR",
        /* Uncomment any of these below lines if the Line Input(s) is(are) used else leave it as such. */
                "IN1","Line In",
                "IN2","Line In",
                "IN5", "Line In",  /* IN1/IN2/IN3/IN4/IN6 (For single-ended input) */
                "IN34", "Line In", /* IN34 (For differential inputs) */
                "IN56", "Line In", /* IN34 (For differential inputs) */
                "MIC1", "Mic Jack",
                "MIC2", "Mic Jack",
                "Mic Jack", "MICBIAS",
                "IN1", "MICBIAS",
                "MIC1","IN1",
                "MIC2","IN1",
                "Speakers", "SPKL",
                "Speakers", "SPKR",
                /* DMIC-3 Routings */
                "DMICL", "DMIC Mux",
                "DMIC Mux", "DMIC3",
                "DMIC3", "DMIC3_ENA",
                "DMIC3", "AHPF",
                /* DMIC-4 Routings */
                "DMICR", "DMIC Mux",
                "DMIC Mux", "DMIC4",
                "DMIC4", "DMIC4_ENA",
                "DMIC3", "AHPF",
                "DMIC4", "AHPF",
                 "HiFi Capture", "DMICL",
                 "HiFi Capture", "DMICR";
                 cpudai: simple-audio-card,cpu {
                        sound-dai = <&sai3>;
                        dai-tdm-slot-num = <2>;
            simple-audio-card,codec {
                    sound-dai = <&max98090>;
                    clocks = <&audio_blk_ctrl  IMX8MP_CLK_AUDIOMIX_SAI3_MCLK1>;
&i2c4 {
        clock-frequency = <400000>;
        pinctrl-names = "default";
        pinctrl-0 = <&pinctrl_i2c4>;
        status = "okay";
        max98090: max98090@10 {
                #sound-dai-cells = <0>;
                pinctrl-0 = <&pinctrl_sai3>;
                compatible = "maxim,max98091";
                reg = <0x10>;
                clocks = <&clk IMX8MP_CLK_SAI3_ROOT>;
                interrupt-parent = <&gpio1>;
                interrupts = <8 IRQ_TYPE_LEVEL_LOW>; /* NC from HW side */
                clock-names = "mclk";
&sai3 {
        assigned-clocks = <&clk IMX8MP_AUDIO_PLL2_OUT>, <&clk IMX8MP_CLK_SAI3>;
        assigned-clock-parents = <&clk IMX8MP_AUDIO_PLL2_OUT>, <&clk IMX8MP_AUDIO_PLL2_OUT>;
        assigned-clock-rates = <361267200>,<11289600>;
        fsl,sai-mclk-direction-output;
        status = "okay";
3 返答(返信)
2,163件の閲覧回数
Bio_TICFSL
That must be a hardware issue since it works perfectly with EVK, however i noticed that you change the dtb, please check the dtb from the EVK and apply the changes accordingly .
2,143件の閲覧回数
pratham_malaviya
Hi @Bio_TICFSL,
-- Can you please elaborate which EVK are you referring to?  If its IMX8MP EVK then I believe it has a different audio codec.
-- Do i need to refer EVK for the codec routings? But both are different codecs and the MAX98090 does not have the hp-det-gpio pin like wm8960.
2,123件の閲覧回数
Bio_TICFSL
My suggestion is to also take look into the codec drivers that are available within our Linux BSP: codecs\soc\sound - linux-imx - i.MX Linux kernel (both drivers for WM8960 and WM824 are included here). That would be a good starting point to look for different codec-driver examples that may also suit your needs. Also, one of colleagues posted a document his experience WM8960: WM8960 audio codec.It would also be convenient to check it out.
%3CLINGO-SUB%20id%3D%22lingo-sub-2174276%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMAX98090%E3%82%B3%E3%83%BC%E3%83%87%E3%83%83%E3%82%AF%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8BIMX8MP%E3%82%B8%E3%83%A3%E3%83%83%E3%82%AF%E6%A4%9C%E5%87%BA%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2174276%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%82%84%E3%81%82%E3%80%81%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%20i.MX8MP%20%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%20MAX98090%20%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%20%E3%82%B3%E3%83%BC%E3%83%87%E3%83%83%E3%82%AF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%8C%E7%9B%B4%E9%9D%A2%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%95%8F%E9%A1%8C%E3%81%AF%E3%80%81%3CSTRONG%3E%E3%83%98%E3%83%83%E3%83%89%E3%83%95%E3%82%A9%E3%83%B3%E3%82%B8%E3%83%A3%E3%83%83%E3%82%AF%E3%81%AE%E6%A4%9C%E5%87%BA%3C%2FSTRONG%3E%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EMAX98090%20%E3%82%B3%E3%83%BC%E3%83%87%E3%83%83%E3%82%AF%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%A7%E3%81%AF%E3%80%81%E3%82%B8%E3%83%A3%E3%83%83%E3%82%AF%E6%A4%9C%E5%87%BA%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A6%8B%E3%81%88%E3%81%BE%E3%81%99%E3%80%82%E3%82%B8%E3%83%A3%E3%83%83%E3%82%AF%E3%81%8C%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%9F%E3%82%8A%E5%8F%96%E3%82%8A%E5%A4%96%E3%81%95%E3%82%8C%E3%81%9F%E3%82%8A%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%83%97%E3%83%AA%E3%83%B3%E3%83%88%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81aplay%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%82%92%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%3CSTRONG%3E%E3%82%B9%E3%83%94%E3%83%BC%E3%82%AB%E3%83%BC%E3%81%A8%E3%83%98%E3%83%83%E3%83%89%E3%83%95%E3%82%A9%E3%83%B3%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%8B%E3%82%89%E5%90%8C%E6%99%82%E3%81%AB%3C%2FSTRONG%3E%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%81%8C%E5%87%BA%E5%8A%9B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E6%9C%9B%E3%81%BE%E3%81%97%E3%81%84%E5%8B%95%E4%BD%9C%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E7%90%86%E6%83%B3%E7%9A%84%E3%81%AB%E3%81%AF%E3%80%81%E3%83%98%E3%83%83%E3%83%89%E3%83%95%E3%82%A9%E3%83%B3%E3%82%92%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%83%83%E3%83%89%E3%81%99%E3%82%8B%E3%81%A8%E3%82%B9%E3%83%94%E3%83%BC%E3%82%AB%E3%83%BC%E3%81%8C%E8%87%AA%E5%8B%95%E7%9A%84%E3%81%AB%E3%82%AA%E3%83%95%E3%81%AB%E3%81%AA%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%20ALSA%20%E3%81%BE%E3%81%9F%E3%81%AF%20PulseAudio%20%E3%81%AE%E6%A7%8B%E6%88%90%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8B%E3%81%AE%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%E3%83%84%E3%83%AA%E3%83%BC%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%AB%E4%BD%95%E3%81%8B%E3%81%8C%E6%AC%A0%E3%81%91%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%8B%E7%96%91%E5%95%8F%E3%81%AB%E6%80%9D%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E5%8F%82%E8%80%83%E3%81%BE%E3%81%A7%E3%81%AB%E3%80%81%E6%B7%BB%E4%BB%98%E3%81%AE%20max-logs.txt%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%3CFONT%20face%3D%22andale%20mono%2Ctimes%22%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20color%3D%22%23FF0000%22%3E%20%E3%80%81amixer%20-c%200%20scontrols%3C%2FFONT%3E%3C%2FFONT%3E%20%E3%81%8A%E3%82%88%E3%81%B3%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20color%3D%22%23FF0000%22%3E%20pactl%3C%2FFONT%3E%20list%20cards%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AE%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3CSTRONG%3E%20%E3%83%84%E3%83%AA%E3%83%BC%20%E3%82%B9%E3%83%8B%E3%83%9A%E3%83%83%E3%83%88%20%E3%81%A8%E3%82%B3%E3%83%BC%E3%83%87%E3%83%83%E3%82%AF%E5%87%BA%E5%8A%9B%E3%82%92%E6%B7%BB%E4%BB%98%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%AA%E3%81%9F%E3%81%8B%E5%8A%A9%E3%81%91%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99!%3CBR%20%2F%3E%3CBR%20%2F%3EDTS%20%E3%82%B9%E3%83%8B%E3%83%9A%E3%83%83%E3%83%88%3A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Esound-max98090%20%7B%0A%20%20%20%20%20%20%20%20compatible%20%3D%20%22simple-audio-card%22%3B%0A%20%20%20%20%20%20%20%20simple-audio-card%2Cname%20%3D%20%22max98090-audio%22%3B%0A%20%20%20%20%20%20%20%20simple-audio-card%2Cformat%20%3D%20%22i2s%22%3B%0A%20%20%20%20%20%20%20%20simple-audio-card%2Cframe-master%20%3D%20%26lt%3B%26amp%3Bcpudai%26gt%3B%3B%0A%20%20%20%20%20%20%20%20simple-audio-card%2Cbitclock-master%20%3D%20%26lt%3B%26amp%3Bcpudai%26gt%3B%3B%0A%20%20%20%20%20%20%20%20simple-audio-card%2Cbitclock-inversion%3B%0A%0A%20%20%20%20%20%20%20%20simple-audio-card%2Cwidgets%20%3D%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%22Microphone%22%2C%20%22Mic%20Jack%22%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%22Speakers%22%2C%20%22Speakers%22%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%22Line%22%2C%20%22Line%20In%22%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%22Line%22%2C%20%22Line%20Out%22%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%22Headphone%22%2C%20%22Headphone%20Jack%22%3B%0A%0A%20%20%20%20%20%20%20%20simple-audio-card%2Crouting%20%3D%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%22Headphone%20Jack%22%2C%20%22HPL%22%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%22Headphone%20Jack%22%2C%20%22HPR%22%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%22Line%20Out%22%2C%20%22RCVL%22%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%22Line%20Out%22%2C%20%22RCVR%22%2C%0A%20%20%20%20%20%20%20%20%2F*%20Uncomment%20any%20of%20these%20below%20lines%20if%20the%20Line%20Input(s)%20is(are)%20used%20else%20leave%20it%20as%20such.%20*%2F%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%22IN1%22%2C%22Line%20In%22%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%22IN2%22%2C%22Line%20In%22%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%22IN5%22%2C%20%22Line%20In%22%2C%20%20%2F*%20IN1%2FIN2%2FIN3%2FIN4%2FIN6%20(For%20single-ended%20input)%20*%2F%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%22IN34%22%2C%20%22Line%20In%22%2C%20%2F*%20IN34%20(For%20differential%20inputs)%20*%2F%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%22IN56%22%2C%20%22Line%20In%22%2C%20%2F*%20IN34%20(For%20differential%20inputs)%20*%2F%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%22MIC1%22%2C%20%22Mic%20Jack%22%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%22MIC2%22%2C%20%22Mic%20Jack%22%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%22Mic%20Jack%22%2C%20%22MICBIAS%22%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%22IN1%22%2C%20%22MICBIAS%22%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%22MIC1%22%2C%22IN1%22%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%22MIC2%22%2C%22IN1%22%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%22Speakers%22%2C%20%22SPKL%22%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%22Speakers%22%2C%20%22SPKR%22%2C%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2F*%20DMIC-3%20Routings%20*%2F%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%22DMICL%22%2C%20%22DMIC%20Mux%22%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%22DMIC%20Mux%22%2C%20%22DMIC3%22%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%22DMIC3%22%2C%20%22DMIC3_ENA%22%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%22DMIC3%22%2C%20%22AHPF%22%2C%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2F*%20DMIC-4%20Routings%20*%2F%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%22DMICR%22%2C%20%22DMIC%20Mux%22%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%22DMIC%20Mux%22%2C%20%22DMIC4%22%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%22DMIC4%22%2C%20%22DMIC4_ENA%22%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%22DMIC3%22%2C%20%22AHPF%22%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%22DMIC4%22%2C%20%22AHPF%22%2C%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%22HiFi%20Capture%22%2C%20%22DMICL%22%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%22HiFi%20Capture%22%2C%20%22DMICR%22%3B%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20cpudai%3A%20simple-audio-card%2Ccpu%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20sound-dai%20%3D%20%26lt%3B%26amp%3Bsai3%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20dai-tdm-slot-num%20%3D%20%26lt%3B2%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%7D%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20simple-audio-card%2Ccodec%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20sound-dai%20%3D%20%26lt%3B%26amp%3Bmax98090%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20clocks%20%3D%20%26lt%3B%26amp%3Baudio_blk_ctrl%20%20IMX8MP_CLK_AUDIOMIX_SAI3_MCLK1%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%7D%3B%0A%20%20%20%20%7D%3B%0A%0A%26amp%3Bi2c4%20%7B%0A%20%20%20%20%20%20%20%20clock-frequency%20%3D%20%26lt%3B400000%26gt%3B%3B%0A%20%20%20%20%20%20%20%20pinctrl-names%20%3D%20%22default%22%3B%0A%20%20%20%20%20%20%20%20pinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_i2c4%26gt%3B%3B%0A%20%20%20%20%20%20%20%20status%20%3D%20%22okay%22%3B%0A%0A%20%20%20%20%20%20%20%20max98090%3A%20max98090%4010%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%23sound-dai-cells%20%3D%20%26lt%3B0%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20pinctrl-names%20%3D%20%22default%22%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20pinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_sai3%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20compatible%20%3D%20%22maxim%2Cmax98091%22%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20reg%20%3D%20%26lt%3B0x10%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20clocks%20%3D%20%26lt%3B%26amp%3Bclk%20IMX8MP_CLK_SAI3_ROOT%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20interrupt-parent%20%3D%20%26lt%3B%26amp%3Bgpio1%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20interrupts%20%3D%20%26lt%3B8%20IRQ_TYPE_LEVEL_LOW%26gt%3B%3B%20%2F*%20NC%20from%20HW%20side%20*%2F%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20clock-names%20%3D%20%22mclk%22%3B%0A%20%20%20%20%20%20%20%20%7D%3B%20%20%20%20%20%20%0A%7D%3B%0A%26amp%3Bsai3%20%7B%0A%20%20%20%20%20%20%20%20%23sound-dai-cells%20%3D%20%26lt%3B0%26gt%3B%3B%0A%20%20%20%20%20%20%20%20assigned-clocks%20%3D%20%26lt%3B%26amp%3Bclk%20IMX8MP_AUDIO_PLL2_OUT%26gt%3B%2C%20%26lt%3B%26amp%3Bclk%20IMX8MP_CLK_SAI3%26gt%3B%3B%0A%20%20%20%20%20%20%20%20assigned-clock-parents%20%3D%20%26lt%3B%26amp%3Bclk%20IMX8MP_AUDIO_PLL2_OUT%26gt%3B%2C%20%26lt%3B%26amp%3Bclk%20IMX8MP_AUDIO_PLL2_OUT%26gt%3B%3B%0A%20%20%20%20%20%20%20%20assigned-clock-rates%20%3D%20%26lt%3B361267200%26gt%3B%2C%26lt%3B11289600%26gt%3B%3B%0A%20%20%20%20%20%20%20%20fsl%2Csai-mclk-direction-output%3B%0A%20%20%20%20%20%20%20%20status%20%3D%20%22okay%22%3B%0A%7D%3B%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2174276%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E3%82%B0%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%82%B9%E3%81%A8%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX%208M%20%7C%20i.MX%208M%20%E3%83%9F%E3%83%8B%20%7C%20i.MX%208M%20%E3%83%8A%E3%83%8E%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3E%E3%83%9E%E3%83%AB%E3%83%81%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EYocto%20Project%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2175065%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20Jack%20detection%20issue%20with%20MAX98090%20codec%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2175065%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3E%E7%A7%81%E3%81%AE%E6%8F%90%E6%A1%88%E3%81%AF%E3%80%81Linux%20BSP%20%E5%86%85%E3%81%A7%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%E3%82%B3%E3%83%BC%E3%83%87%E3%83%83%E3%82%AF%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%82%E8%AA%BF%E3%81%B9%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%3A%20codecs%5Csoc%5Csound%20-%20linux-imx%20-%20i.MX%20Linux%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%20(WM8960%20%E3%81%A8%20WM824%20%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E3%81%93%E3%81%93%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99)%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E3%83%8B%E3%83%BC%E3%82%BA%E3%81%AB%E5%90%88%E3%81%86%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%AE%E3%81%82%E3%82%8B%E3%81%95%E3%81%BE%E3%81%96%E3%81%BE%E3%81%AA%E3%82%B3%E3%83%BC%E3%83%87%E3%83%83%E3%82%AF%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AE%E4%BE%8B%E3%82%92%E6%8E%A2%E3%81%99%E3%81%9F%E3%82%81%E3%81%AE%E8%89%AF%E3%81%84%E5%87%BA%E7%99%BA%E7%82%B9%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81%E5%90%8C%E5%83%9A%E3%81%AE%E4%B8%80%E4%BA%BA%E3%81%8C%20WM8960%20%E3%81%AE%E4%BD%BF%E7%94%A8%E7%B5%8C%E9%A8%93%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E6%96%87%E6%9B%B8%E3%80%8CWM8960%20%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%20%E3%82%B3%E3%83%BC%E3%83%87%E3%83%83%E3%82%AF%E3%80%8D%E3%82%92%E6%8A%95%E7%A8%BF%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%BF%E3%82%8B%E3%81%AE%E3%82%82%E3%82%88%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2174743%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20Jack%20detection%20issue%20with%20MAX98090%20codec%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2174743%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F34846%22%20target%3D%22_blank%22%3E%40Bio_TICFSL%3C%2FA%3E%20%E3%80%81%3CBR%20%2F%3E%20%3CEM%3E%3CBR%20%2F%3EEVK%E3%81%A7%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%8F%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%81%AE%E3%81%A7%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%A7%E3%81%82%E3%82%8B%E3%81%AB%E9%81%95%E3%81%84%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%3C%2FEM%3E%20--%20%E3%81%A9%E3%81%AE%20EVK%20%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%A8%80%E5%8F%8A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%8B%E8%A9%B3%E3%81%97%E3%81%8F%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3FIMX8MP%20EVK%20%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E7%95%B0%E3%81%AA%E3%82%8B%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%20%E3%82%B3%E3%83%BC%E3%83%87%E3%83%83%E3%82%AF%E3%81%8C%E6%90%AD%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E6%80%9D%E3%82%8F%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CEM%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81dtb%20%E3%81%8C%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B0%97%E4%BB%98%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82EVK%20%E3%81%8B%E3%82%89%20dtb%20%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%A6%E5%A4%89%E6%9B%B4%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FEM%3E%3C%2FP%3E%3CP%3E--%20%E3%82%B3%E3%83%BC%E3%83%87%E3%83%83%E3%82%AF%E3%81%AE%E3%83%AB%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%20EVK%20%E3%82%92%E5%8F%82%E7%85%A7%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E4%B8%A1%E8%80%85%E3%81%AF%E7%95%B0%E3%81%AA%E3%82%8B%E3%82%B3%E3%83%BC%E3%83%87%E3%83%83%E3%82%AF%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81MAX98090%20%E3%81%AB%E3%81%AF%20wm8960%20%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%20hp-det-gpio%20%E3%83%94%E3%83%B3%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2174379%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20Jack%20detection%20issue%20with%20MAX98090%20codec%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2174379%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3EEVK%20%E3%81%A7%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%8F%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%A7%E3%81%82%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81dtb%20%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%9F%E3%81%93%E3%81%A8%E3%81%AB%E6%B0%97%E4%BB%98%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82EVK%20%E3%81%8B%E3%82%89%20dtb%20%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%A6%E5%A4%89%E6%9B%B4%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
