[IMX8MP] Error profiling OpenCL application on imx8mp evk board
1,676 次查看
dteng
When I try to profile OpenCL application on IMX8MP evk board using VivanteIDE5.4.0. I got the following error:
Anyone can tell me what could be the reason for this? Thanks!
2 回复数
1,669 次查看
Zhiming_Liu
Please check your connection
1,661 次查看
dteng
Could you please elaborate? I can't find issues with my connection. I'm able to ssh as root to the board using the IP. In fact, the IDE was able to connect to the board in the Remote System View. Using the same connection settings, I was able to do Debugging. It would just fail when launching profiling. What aspect of connection should I check?
