[IMX8MP][DWE] Dewarp Engine clarification
ms_emsys
From IMX8MPRM, Rev. 1, 06/2021:
The Dewarp Engine cannot be used as a standalone module.
1. Is this a hardware limitation (shared clock control etc)?
2. Is this a software limitation because the userspace stack (isp-imx) does not support this usecase?
2. Would it be possitble to use the isi_0 or isp_0 to do the format conversion from RAW8 GRAYSCALE into a format compatible with the dwe?
malik_cisse
Senior Contributor I
From iMX8MP_CAMERA_DISPLAY_GUIDE.pdf Figure 17 (see below). it appears that dewarp output is a separate output from ISP and one should be able to access it in parallel to accessing ISP output on /dev/video0 device node.
Is this understanding correct? If yes, how can I access Dewarp output? I have activated Dewarp but I only see /dev/video0 device node.
 Any usage example of Dewarp will be welcome.
THX
joanxie
I have mailed to you and give you detailed answer, pls check your mailbox
jeroenvanderlaa
I would also like to use the normal and dewarped video simultaneously. Can You help me with this issue?
%3CLINGO-SUB%20id%3D%22lingo-sub-1325383%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%5BIMX8MP%5D%5BDWE%5D%20Dewarp%20Engine%20clarification%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1325383%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EFrom%20IMX8MPRM%2C%20Rev.%201%2C%2006%2F2021%3A%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3EThe%20Dewarp%20Engine%20cannot%20be%20used%20as%20a%20standalone%20module.%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E1.%20Is%20this%20a%20hardware%20limitation%20(shared%20clock%20control%20etc)%3F%3C%2FP%3E%3CP%3E2.%20Is%20this%20a%20software%20limitation%20because%20the%20userspace%20stack%20(isp-imx)%20does%20not%20support%20this%20usecase%3F%3C%2FP%3E%3CP%3E2.%20Would%20it%20be%20possitble%20to%20use%20the%20isi_0%20or%20isp_0%20to%20do%20the%20format%20conversion%20from%20RAW8%20GRAYSCALE%20into%20a%20format%20compatible%20with%20the%20dwe%3F%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2295969%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5BIMX8MP%5D%5BDWE%5D%20Dewarp%20Engine%20clarification%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2295969%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20would%20also%20like%20to%20use%20the%20normal%20and%20dewarped%20video%20simultaneously.%20Can%20You%20help%20me%20with%20this%20issue%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1437717%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5BIMX8MP%5D%5BDWE%5D%20Dewarp%20Engine%20clarification%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1437717%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EFrom%26nbsp%3BiMX8MP_CAMERA_DISPLAY_GUIDE.pdf%20Figure%2017%20(see%20below).%20it%20appears%20that%20dewarp%20output%20is%20a%20separate%20output%20from%20ISP%20and%20one%20should%20be%20able%20to%20access%20it%20in%20parallel%20to%20accessing%20ISP%20output%20on%20%2Fdev%2Fvideo0%20device%20node.%3CBR%20%2F%3EIs%20this%20understanding%20correct%3F%20If%20yes%2C%20how%20can%20I%20access%20Dewarp%20output%3F%20I%20have%20activated%20Dewarp%20but%20I%20only%20see%20%2Fdev%2Fvideo0%20device%20node.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22dewarp.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22dewarp.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22dewarp.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F175655iA830053F7BA5081C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22dewarp.jpg%22%20alt%3D%22dewarp.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E2%80%83Any%20usage%20example%20of%20Dewarp%20will%20be%20welcome.%3CBR%20%2F%3ETHX%3C%2FP%3E%3CP%3E%E2%80%83%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1331244%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5BIMX8MP%5D%5BDWE%5D%20Dewarp%20Engine%20clarification%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1331244%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20have%20mailed%20to%20you%20and%20give%20you%20detailed%20answer%2C%20pls%20check%20your%20mailbox%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2296519%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5BIMX8MP%5D%5BDWE%5D%20Dewarp%20Engine%20clarification%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2296519%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EI%20would%20also%20like%20to%20use%20the%20normal%20and%20dewarped%20video%20simultaneously.%20Can%20You%20help%20me%20with%20this%20issue%3F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
