IMX8MM LVDS Timing Issue
5,064件の閲覧回数
FOC
Hi Everyone,
I am using dual LVDS display with MX8M Mini variscite SoM, but I think there is a problem with LCD timings. There is a flickering and scrolling problem on the screen. Can anyone check the dts and LCD timings? There is an horizontal area on the screen and distorts the application window.
5,035件の閲覧回数
Bio_TICFSL
We can not tested here but change the LCD clock for timing issue on the DTB.
5,025件の閲覧回数
FOC
Hi Bio,
Thanks for your reply.
Should I only change the clock value? Can you check the LCD datasheet and advise? Is this possible?
