IMX8MM Android10 add GPS
2,678件の閲覧回数
jianfeichang
hello
       I use the imx8mm andorid10,gps is ttymxc2,cat is ok。
evk_8mm:/ # cat /dev/ttymxc2
$BDGSV,4,2,13,19,56,298,,3,44,190,26,9,38,215,34,1,37,151,*58
$BDGSV,4,3,13,2,34,226,28,29,32,213,23,4,25,124,,22,9,271,28*5C
$BDGSV,4,4,13,23,8,38,*58
$GNRMC,090307.009,V,,,,,,,040821,,,N*58
  But Android 10 can't access GPS,What changes do I need to make to the Android 10 source code?The mapping software couldn't locate it。
2 返答(返信)
2,668件の閲覧回数
jianfeichang
It Iis ok!thank you!
2,045件の閲覧回数
napster_k
how , please explain
タグ(1)
