IMX8M plus sata interface
1,116 次查看
Chethanbg
We have a requirement of connecting SATA HDD to IMX8M Plus processor but we have only single lane PCIe 3.0 interface.
Can you please suggest converter from PCIe to sata interface to support extrenal HDD(2TB max)
1 回复
1,104 次查看
riteshmpatel
Hi @Chethanbg,
I hope you are doing well.
One can use any compatible converter available in the market. However, i.MX8MPlus processor doesn't have a built-in SATA controller. To support SATA, an external controller, e.g. PCIe-to-SATA controller, should be used.
Thanks & Regards,
Ritesh M Patel
