IMX8M plus SDXC extended Capacity
1,563 次查看
Parag1
Hello Team,
I have one Query regarding the IMX8M Plus SDXC  Capacity .
In datasheet its not mention the storage capacity of SDXC. it only mention its support SDXC
Please let me know what is the Extended capacity for the SDXC .
Please also share if you have any document related to the SD storage supported by the IMX8M plus .
2 回复数
1,511 次查看
Parag1
Hello Ritesh.
Thank you for the explanation
1,543 次查看
riteshmpatel
Hi @Parag1 ​,
I hope you are doing well.
Please refer to Section 10.3.1.2 Features of the i.MX8MP Reference Manual.
Since it is compatible with the SD Memory Card Specification v3.0 and supports the Extended Capacity SD Memory Card, it shall support up to 2TB of memory.
Kindly refer to the SD specifications from the below-mentioned link.
https://community.nxp.com/pwmxy87654/attachments/pwmxy87654/imx-processors%40tkb/3706/1/Part_1_Physi...
Thanks & Regards,
Ritesh M Patel
