IMX8M Plus Display logo during kernel (Android11_2.6.0)
已解决
跳至解决方案
5,998 次查看
vachlan
Due to the BSP(android11_2.6.0) package being  by default IMX8MP_ USES_ GKI =true。
Display drivers are loaded after kernel startup,Causing inability to display logo during kernel startup。
I will use IMX8MP_ USES_ GKI=true commented out, there was a GPU error as attached.
Please advise on how to correct the errors in this section。
标签 (1)
1 解答
6 回复数
5,973 次查看
Rita_Wang
Do you want the uboot logo keep in the kernel ?
5,966 次查看
vachlan
Yes, I want to do that. But first of all, I want to display the logo in the kernel in this BSP
5,975 次查看
Rita_Wang
Are you using the NXP i.MX8MP LPDDR4 EVK board?
5,965 次查看
vachlan
Yes, we are using this board, and we have designed a similar board
5,947 次查看
vachlan
Thank you, I have read these two links you sent (which I plan to follow up on). May I ask if the IMX8MP_ USES_ GKI=true commented out。 Can GPU errors be corrected?
