IMX8M PLUS || PMIC 32K Clock out
JyotiVaishnav
Hi NXP Team,
In the PMIC - CLK_32K_OUT is given and the same clock we are using for an processor RTC clock.
the PMIC will support or not ?
We are able to use that clock for RTC or required an external crystal for RTC?
joanxie
in fact, current nxp board use external crystal, you also can find more detailed information from data sheet, pls focus on the chapter 3.1.6 External clock sources
