IMX8 bluetooth module enabling
Samt07
I am using the IMX8MP and I am having some problem enabling Bluetooth module WE866C6Px.
I could successfully enable the wireless module. But for the Bluetooth,  I have no idea where to begin with.
So if anyone have any idea please guide what changes I should do to enable and advertise the module.
occam25
Hi @Samt07 , I'm trying to enable the same module using IMX8MM but I get a timeout error when I load the driver: "hif registration timedout". I suspect that there is something wrong in my device tree configuration so the module doesn't event respond.
I'm only interested in using the wifi. Since you say you have it workin, could you please share your device tree so I can figure out what part I am missing?
thanks!
Chavira
Hi @Samt07!
Thank you for contacting NXP Support!
Probably you have to add the drivers or add the device to the device tree.
Unfortunately, we don´t have this wifi module, please contact your wifi provider to ask about the drivers on Linux and the proper configuration for that.
I found the user guide for the module here:
https://www.telit.com/we866c6-evk-download-zone/
Best Regards!
Chavira
