IMX8 Initialization system counter
AFR89
I try to understand how the CNTPCT_EL0 is reset to 0 at power up.
The datasheet of the A35 core say it modified by using CNTVALUEB.
CNTVALUEB seem to be connected to system counter but i don't find any information in the datasheet about the reset.
Can you give me in which document the reset of this counter is explain?
Tags (2)
brian14
Hi @AFR89,
Thank you for contacting NXP Support.
I will check this information with our internal team.
Have a great day!
brian14
Hi @AFR89,
Based on the reply from our expert team, the CNTPCT_EL0 is provided to the ARM cores via the SCU SYSCNTR (system counter). This SYSCNTR is reset to POR (Power-on-Reset). So, during the power-up and if the PMIC resets the system.  Note, the SYSCNTR of the SCU is distributed both to Cortex-A (via CNTPCT_EL0), and to Cortex-M (via its TSTMR counter). It is the same timer that will be read by the SCU, Cortex-A and Cortex-M. Useful for synchronizing them.
AFR89
Do you have any documentation that explain this behavior? We will need it
Alexandre
brian14
Hi @AFR89,
This documentation is shared under NDA.
Please submit a support ticket, to review your case.
Have a great day!
