IMX8 Android with GMS ?
4,496 次查看
metz
Hi all,
I would like to ask if there's support for IMX8 with Android and GMS (Google Mobile Services).
I heard some roumors that CTS, which is mandatory for GMS, will fail when using an IMX8.
Best Regards
Frédéric
标记 (1)
5 回复数
4,388 次查看
diegoadrian
Google Mobile Services needs to be provided by Google. Our BSP does not have it by default. Furthermore. I suggest you contact Google. There are needed those Google services to pass the CTS test.
Diego.
4,388 次查看
metz
Thanks for your reply.
Does that mean that when we do the GMS certification/licensing, there's no support for IMX8 when CTS will fail ?
I am asking because I heard that with IMX8, GMS certification may fail and there's no support from NXP in this case ?
4,388 次查看
diegoadrian
What I am trying to say, is that you run the CTS test with our BSP it will fail in that part because it does not have by default the Google Media Services. Those services are provided directly by Google and you need to install them on your own.
Diego.
4,251 次查看
pareshchaudhary
I am also intereseted in this query.
I am also planning to use the IMX8M Plus process for GMS.  Any suggestion?
4,388 次查看
metz
Additionally, one other question:
Do you know any device having a IMX8 with Android and GMS certification/licensing ?
