IMX6qpsabreauto HDMI Problem
ソリューションへジャンプ
2,465件の閲覧回数
abdullahaktay
Dear all,
I compiled the kernel by following the documentation below (for SATA).
Booting Linux from SATA on i.MX6Q SABRE AI.
http://www.bcmcom.com/CustomerDL/AR6MX/Yocto/Freescale_Yocto_Project_User%27s_Guide.pdf
I set the following for HDMI.
setenv displayinfo 'video=mxcfb0:dev=hdmi,1920x1080M@60,if=RGB24'
But when I connect the HDMI cable after boot, I get the bottom line error/warning.
mxc_hdmi 20e0000.hdmi_video: Read EDID again
mxc_hdmi 20e0000.hdmi_video: create default modelist
Any ideas on this?
Thanks.
ラベル(4)
2,206件の閲覧回数
abdullahaktay
I solved the problem.
Solution:
setenv my_bootargs_sata setenv bootargs console=\${console},\${baudrate} root=/dev/sda2 video=mxcfb0:dev=hdmi,1920x1080M@60,if=RGB24
Thanks.
2 返答(返信)
2,207件の閲覧回数
abdullahaktay
Solution:
Thanks.
2,206件の閲覧回数
joanxie
pls check if your hdmi supports 1080p@60 or not,  and check connect to mxcfb0 or mxcfb1
