IMX6ULL supports systemd
vasudhevan
Contributor V
Hi Team,
Processor = IMX6ULL
Currently we using sysvint.
can we use systemd, if we use systemd what are the disadvantages is there.
what is the major difference between systemd and sysvint  ?
  Vasu
Labels (3)
jamesbone
In the following web page you can find a very good comparison between both Init options:
https://linoxide.com/linux-command/systemd-vs-sysvinit-cheatsheet/
TIC
vasudhevan
Contributor V
Hi Jamesbone,
Thank You for your response.
I having one more doubt if we use systemd rootfs size increase except that performance wise any issue is there because of IMX6ULL is single core processor.
What is the status of CPU and RAM usage compared to sysvinit ?
  Vasu
