IMX6ULL - Y1 and Y2 Difference
1,725件の閲覧回数
velayutha_perum
I have flashed the MFG tool for Programming IMX6ULL Y2 which is working fine.
But when i try to flash same MFG tool for Programming IMX6ULL Y1 , it is failing.
So may i know what is the difference between Y1 and Y2.
Is there any document available to know the difference?
Appreciate your help.
ラベル(3)
1,585件の閲覧回数
gusarambula
Hello Velayutha Perumal,
You can see the features of these variants of the i.MX6ULL on Table 1 of the i.MX6ULL Datasheet (link below). You will see that there are lists of features for the Y0, Y1, Y2 and Y7 part variations.
https://www.nxp.com/docs/en/data-sheet/IMX6ULLCEC.pdf
I hope this helps,
