IMX6ULL EPIT Not Working Properly
1,709 次查看
zzl
hi all, I try to use EPIT timer in IMX6ULL chip, but the timer interrupt is not working properly. Linux already uses GPT timer as system clock, so can't EPIT and GPT work at the same time? Thank you very much for your answers.
1,662 次查看
Sanket_Parekh
Hi @zzl
Please try below mentioned patch for EPIT timer.
https://patchwork.kernel.org/project/linux-arm-kernel/patch/20180530120327.27681-5-peron.clem@gmail....
Thanks & Regards
Sanket Parekh
1,667 次查看
Sanket_Parekh
Hi @zzl
I hope you are doing well.
Which kernel driver you are using for EPIT timer?
Thanks & Regards
Sanket Parekh
