IMX6UL LCD data bit mapping Query?
4,757件の閲覧回数
ramesh6663
  I have looked in to the LCD 24 bit signal mapping to the LCD connector in the NXP EVK design for IMx6ULL.
  LCD module mentioned Data bit mapping is different than Actual NXP EVK design data mapping, Please see below attached snap shot from LCD datasheet pinout and EVK schematic data signal mapping.
Our query is Shall we reconfigure the Data signals mapping through software?
Thanks & Regards,
Rameshkumar
4 返答(返信)
4,472件の閲覧回数
joanxie
what lcd do you use? could you share with your lcd data sheet?
4,472件の閲覧回数
ramesh6663
LCD datasheet link: http://www.farnell.com/datasheets/1773015.pdf . If this is not correct one
Could you please provide me the LCD module datasheet link which was used in IMX6UL NXP EVK board.
4,472件の閲覧回数
joanxie
you can refer to the mx6ull evk link, which includes the lcd we suggest to use
MCIMX6ULL-EVK|i.MX6ULL Evaluation Kit|NXP
4,472件の閲覧回数
ramesh6663
Thanks For the Link, But it doesn't have the LCD detailed datasheet as open source.
Our query is LCD controller has 24bit, So LCD specification mentioned R(X8) G(X8) B(X8) bit configuration.
Do we have any specific signal mapping in the IMX6UL side?
