IMX6UL Boot OP-TEE with NAND Flash
kr90911
Hi all,
I'm working on custom I.MX6UL board with 256MB NAND Flash, and I want to enable tee function on my board.
I read about this from i.MX_Porting_Guide.pdf:
Seems OP-TEE can only boot from SD card device.
Is there any way to boot OP-TEE with NAND Flash?
Labels (4)
wsm
excuse me ,how did you solved that problem?skip the uboot,only porting optee in kernel ?
Hi West
reason may be the same as in description on below commit
https://source.codeaurora.org/external/imx/linux-imx/commit/?h=imx_5.4.24_2.1.0&id=b5094b7f135be3463...
