Dear community.
Our customer has question below.
IMX6SDLAEC P94 of 4.11.10.2.3 Non-Gated Clock Mode describe that rising / falling edge and active HI / Lo can be changed,
Where should I refer to specific settings?
The timing described in Figure 61 is that of a typical sensor. Some other sensors may have a slightly
different timing. The CSI can be programmed to support rising/falling-edge triggered
IPUx_CSIx_VSYNC; active-high/low IPUx_CSIx_HSYNC; and rising/falling-edge triggered
IPUx_CSIx_PIX_CLK.
Solved! Go to Solution.
Hi Takashi
please refer to sect.38.5.151 CSI0 Sensor Configuration Register i.MX6SDL Reference Manual
(IPUx_CSI0_SENS_CONF) for description of polarity bits 0-3.
http://cache.freescale.com/files/32bit/doc/ref_manual/IMX6SDLRM.pdf
Hi Takashi
