IMX6Q quad core supply separation
1,095 次查看
eliaz
Is there a possibility to separate the supplies for the quad core operation?
I want to supply  VDD_ARM23_IN and second for VDD_ARMIN from different suppliers (2 different dc\dc converters), Is possible?
1,019 次查看
gusarambula
Hello Eli Az,
For quad core operation the core supplies must be provided by the same power source, otherwise there would be an unwanted current between both supplies.
For more information on Hardware Design I would recommend looking at the Hardware Design Guide (link below)
http://www.nxp.com/files/32bit/doc/user_guide/IMX6DQ6SDLHDG.pdf
