IMX6Q Parallel RGb Video Quality
1,154件の閲覧回数
tengri
Hi All,
From xrandr side, is there anyway to improve or make color corrections to LCD signals ? I have connected an LCD panel with correct mode settings manually in xrandr, but the brightness-contrast need to be adjusted !
ラベル(3)
タグ(1)
953件の閲覧回数
Bio_TICFSL
Try to add xrand gamma, and brigthness args and check if it makes any difference, also setting bootarg "res=" to desired value.
Hope it helps
