IMX6Q L2 Cache TAG and RAM latency settings?
2,126件の閲覧回数
jonwatson
In the IMX6 Quad technical reference manual I see that Table 12-5 “PL310 L2 Cache Configuration” (see pg 569 of the i.MX 6Dual/6Quad Applications Processor Reference Manual, Rev. 1, 04/2013), specifies “RAM   Latencies” as 4 and has a footnote that 4 is a preliminary value, final value is TBD.
What is the final value that should be used when setting the PL310 TAG RAM and DATA RAM latency control registers?
2 返答(返信)
1,777件の閲覧回数
gusarambula
I apologize. I couldn’t locate this specific information but may I ask why do you need this parameter? Maybe we can help with some other information.
1,777件の閲覧回数
gusarambula
We’re investigating what the final figure should be. I’ll let you know as soon as we have an update.
