IMX6Q HDMI hot-plug problem
jimmyli
Contributor V
     I meet with a problem which is described below.
     IMX6Q object board connects with displayer by standard HDMI interface(19 pins). Firstly, the displayer can display normally; But after hot-plug some times, the displayer displays "no signal"; Then hot-plug again, the displayer may return to normal.
     When the problem happened, the log showed that EDID read was right and the differential lines had output signal.
     Thanks.
Labels (3)
