IMX6 USB Problem
IMX6 USB Problem
1,026件の閲覧回数
Nah3l
I'm currently using the MBa6x board containing the TQMa6x card with an IMX6. And I'm trying to use the USB ports to read and write files from a USB stick. under QNX. However, when I run usb -vvv no information is given about the USBs. I tried to launch the drivers but still nothing.
If you have a solution I'm interested.
1,006件の閲覧回数
JorgeCas
Hello, I hope you are doing well.
I suggest you check with TQ-Group if there is an additional configuration to initialize your USB module on your board.
Best regards.
