IMX6-Dual Disable Interrupts
omarhelmy
Hello all,
I would like to disable all maskable interrupts in the system so I can enter a critical section safely. I use imx6-dual ARM based board. Is there a certain sequence to disable interrupts ?
igorpadykov
Hi Omar
handling inetrrupts is described in arm gic documentation
https://static.docs.arm.com/ihi0048/b/IHI0048B_b_gic_architecture_specification.pdf
linux general considerations can be found in
How to disable interrupt in a C program in linux - Stack Overflow
