IMX287: enable debug UART
BrilliantovKiri
Senior Contributor I
Hello!
We are use application UART for communication with periferia.
Default linux command line is:
~ # cat /proc/cmdline
console=ttyAM0,115200 root=/dev/mmcblk0p3 rw rootwait
How should I change command line for use debug UART as console?
Tank you and excuse my bad english.
Tags (2)
BrilliantovKiri
Problem solved, I found mistake in device name.
dmegs:
mxs-duart.0: ttyAM0 at MMIO 0x80074000 (irq = 47) is a DebugUART
/etc/inittab:
::respawn:/sbin/getty -L /dev/ttyAM0 115200
lategoodbye
Hello Kirill, please write down which kernel version you are using.
BrilliantovKiri
Hello, Stefan!
I use linux-2.6.35 from LTIB, package L2.6.35_1.1.0_130130_source.tar.gz from FreeScale site.
