IMX 95 NPU not activated
5,636件の閲覧回数
OlivierG
HI
I use a IMX 95 Verdin Toradex Card a1 (not b0)
I would like to evaluate the NPU
if i launch :
/usr/bin/tensorflow-lite-2.18.0/examples# python3 ./label_image.py --ext_delegate /usr/lib/libneutron_delegate.so
i get the following messages
Error in cpuinfo: prctl(PR_SVE_GET_VL) failed
INFO: Created TensorFlow Lite XNNPACK delegate for CPU.
Is there a connection between these two messages?
Should I conclude that the NPU is not enabled?
What should I do to resolve this issue?
Greetings
Olivier
15 返答(返信)
5,098件の閲覧回数
Zhiming_Liu
Please download eIQ to convert .tflite with Neutron support.
The eIQ1.16 is for L6.12.20 Neutron support.
For Neutron Converter CLI, please refer eIQ User Guide.
Zhiming
5,591件の閲覧回数
OlivierG
hi
on IMX 95 i get
python3 label_image.py --ext_delegate /usr/lib/libneutron_delegate.so
Loading external delegate from libneutron_delegate.so with args: {}
ext_delegate [<tflite_runtime.interpreter.Delegate object at 0xffffa6d52660>]
INFO: NeutronDelegate delegate: 0 nodes delegated out of 31 nodes with 0 partitions.
Warm-up time: 122.3 ms
Inference time: 118.2 ms
0.870588: military uniform
0.031373: Windsor tie
0.011765: mortarboard
0.007843: bow tie
0.007843: bulletproof vest
in comparison, on IMX 93 i get
python3 label_image.py --ext_delegate /usr/lib/libethosu_delegate.so
Loading external delegate from /usr/lib/libethosu_delegate.so with args: {}
INFO: Ethosu delegate: device_name set to /dev/ethosu0.
INFO: Ethosu delegate: cache_file_path set to .
INFO: Ethosu delegate: timeout set to 60000000000.
INFO: Ethosu delegate: enable_cycle_counter set to 0.
INFO: Ethosu delegate: enable_profiling set to 0.
INFO: Ethosu delegate: profiling_buffer_size set to 2048.
INFO: Ethosu delegate: pmu_event0 set to 0.
INFO: Ethosu delegate: pmu_event1 set to 0.
INFO: Ethosu delegate: pmu_event2 set to 0.
INFO: Ethosu delegate: pmu_event3 set to 0.
INFO: EthosuDelegate: 31 nodes delegated out of 31 nodes with 1 partitions.
Warm-up time: 4.1 ms
Inference time: 3.9 ms
0.874510: military uniform
0.015686: mortarboard
0.011765: bulletproof vest
0.007843: bow tie
on  imx 93 there is no message:
The inference time is much shorter  118.2 ms -> 3.9 ms
Olivier
5,525件の閲覧回数
Zhiming_Liu
Hi @OlivierG
Please use older verison with tensorflow 2.16.2, like L6.6.X.
root@imx95frdm:/usr/bin/tensorflow-lite-2.16.2/examples# python3 label_image.py --ext_delegate /usr/lib/libneutron_delegate.so
Loading external delegate from /usr/lib/libneutron_delegate.so with args: {}
INFO: NeutronDelegate delegate: 29 nodes delegated out of 31 nodes with 1 partitions.
Warm-up time: 3.9 ms
Inference time: 1.8 ms
0.850980: military uniform
0.058824: Windsor tie
0.007843: bow tie
There are some issue about NPU delegate even in latest BSP L6.12.34
Zhiming
4,884件の閲覧回数
min-eta
Hi Zhiming, your reply to this message would seem to indicate that in the older Linux version 6.6.x, to use the NeutronDelegate, you DO NOT need to first use the neutron_converter to convert some of the TFLite Ops in the Model to the custom NeutronGraph.
But for the newer Linux 6.12.x, you DO have to first use neutron_converter to convert the Model first?
@min-eta
min-eta
4,833件の閲覧回数
Zhiming_Liu
Hi @min-eta
Yes, the software framework has changed since L6.12.y
Zhiming
5,507件の閲覧回数
OlivierG
HI
i try the folowing python code
import tensorflow as tf
modelpath ='model_yolo_11s_int8_fp32.tflite'
with open(modelpath, 'rb') as fid:
tflite_model = fid.read()
interpreter = tf.lite.Interpreter(model_content=tflite_model,experimental_delegates=[tf.lite.experimental.load_delegate('libneutron_delegate.so')])
interpreter.allocate_tensors()
i get the following error message
/usr/lib/python3.13/site-packages/tensorflow/lite/python/interpreter.py:457: UserWarning: Warning: tf.lite.Interpreter is deprecated and is scheduled for deletion in
TF 2.20. Please use the LiteRT interpreter from the ai_edge_litert package.
See the [migration guide](https://ai.google.dev/edge/litert/migration)
for details.
warnings.warn(_INTERPRETER_DELETION_WARNING)
INFO: NeutronDelegate delegate: 0 nodes delegated out of 339 nodes with 0 partitions.
Exception ignored in: <function Delegate.__del__ at 0xffff5171bf60>
Traceback (most recent call last):
File "/usr/lib/python3.13/site-packages/tensorflow/lite/python/interpreter.py", line 122, in __del__
AttributeError: 'NoneType' object has no attribute 'c_void_p'
Does the python code match your answer?
i precise that libethosu_delegate.so is not on my Card
Greetings
Olivier
5,366件の閲覧回数
Zhiming_Liu
Yes, the sw team is investigating this issue.
Zhiming
5,611件の閲覧回数
Zhiming_Liu
-->There is no connection about them.
-->If you can see below log, that means NPU delegate is working.
INFO: NeutronDelegate delegate: .......
-->Can you share full log?
Zhiming
5,004件の閲覧回数
OlivierG
now, i have a imx95-19x19-lpddr5-evk
The Yocto is
i.MX Linux Yocto Project BSP 6.12.20_2.0.0 Release
When i launch
root@imx95evk:/usr/bin/tensorflow-lite-2.18.0/examples# ./benchmark_model --graph=mobilenet_v1_1.0_224_quant.tflite --external_delegate_path=/usr/lib/libneutron_delegate.so
INFO: STARTING!
INFO: Log parameter values verbosely: [0]
INFO: Graph: [mobilenet_v1_1.0_224_quant.tflite]
INFO: Signature to run: []
INFO: External delegate path: [/usr/lib/libneutron_delegate.so]
INFO: Loaded model mobilenet_v1_1.0_224_quant.tflite
INFO: EXTERNAL delegate created.
INFO: Though EXTERNAL delegate is explicitly applied, the model graph will not be executed by the delegate.
INFO: The input model file size (MB): 4.27635
INFO: Initialized session in 56.257ms.
INFO: Running benchmark for at least 1 iterations and at least 0.5 seconds but terminate if exceeding 150 seconds.
INFO: count=5 first=122578 curr=118671 min=118400 max=122578 avg=119396 std=1595
INFO: Running benchmark for at least 50 iterations and at least 1 seconds but terminate if exceeding 150 seconds.
INFO: count=50 first=118459 curr=117971 min=117954 max=118782 avg=118259 std=173
INFO: Inference timings in us: Init: 56257, First inference: 122578, Warmup (avg): 119396, Inference (avg): 118259
INFO: Note: as the benchmark tool itself affects memory footprint, the following is only APPROXIMATE to the actual memory footprint of the model at runtime. Take the information at your discretion.
INFO: Memory footprint delta from the start of the tool (MB): init=12.0352 overall=15.1602
when i launch
cat /sys/class/remoteproc/remoteproc0/state
i get : offline
Greetings
Olivier
4,968件の閲覧回数
Zhiming_Liu
Hi @OlivierG
Please refer previous reply here.
To use NPU in i.MX95, customer need to convert common .tflite to neutron .tflite support with eIQ or neutron converter CLI.
Here you can try this model which i converted with eIQ.
Zhiming
4,914件の閲覧回数
OlivierG
When i launch the python sample with the converted file, i get
root@imx95evk:/usr/bin/tensorflow-lite-2.18.0/examples# python3 label_image.py -m mobilenet_v1_1.0_224_quant_converted.tflite
File "/usr/bin/tensorflow-lite-2.18.0/examples/label_image.py", line 92, in <module>
File "/usr/lib/python3.13/site-packages/tflite_runtime/interpreter.py", line 534, in allocate_tensors
return self._interpreter.AllocateTensors()
RuntimeError: Encountered unresolved custom op: NeutronGraph.
See instructions: https://www.tensorflow.org/lite/guide/ops_custom Node number 1 (NeutronGraph) failed to prepare.Encountered unresolved custom op: NeutronGraph.
With the executable version i get
root@imx95evk:/usr/bin/tensorflow-lite-2.18.0/examples# ./label_image -m mobilenet_v1_1.0_224_quant_converted.tflite
INFO: Loaded model mobilenet_v1_1.0_224_quant_converted.tflite
INFO: resolved reporter
ERROR: Encountered unresolved custom op: NeutronGraph.
ERROR: Node number 1 (NeutronGraph) failed to prepare.
ERROR: Failed to allocate tensors!
Greetings
Olivier
4,832件の閲覧回数
Zhiming_Liu
Hi @OlivierG
Can you try to test with neutron delegate /usr/lib/libneutron_delegate.so ?
Zhiming
4,794件の閲覧回数
OlivierG
I build the last version of the yocto kernel imx-6.12.34-2.1.0
when i launch
python3 label_image.py -e /usr/lib/libneutron_delegate.so
i get
/usr/lib/python3.13/site-packages/tflite_runtime/interpreter.py:457: UserWarning: Warning: tf.lite.Interpreter is deprecated and is scheduled for deletion in
for details.
Warm-up time: 94.5 ms
Inference time: 60.2 ms
0.878431: military uniform
0.027451: Windsor tie
0.007843: sax
i modify the python code to correct the warning
python3 label_image2.py -e /usr/lib/libneutron_delegate.so
i get
Warm-up time: 58.0 ms
Inference time: 55.5 ms
0.007843: sax
i always get
i must precise that on IMX95
return : offline
The same command on the IMX93 board return : running
On IMX95
dmesg | grep remoteproc
return
remoteproc remoteproc0: imx-rproc is available
On IMX93
return
remoteproc remoteproc0: powering up imx-rproc
remoteproc remoteproc0: Booting fw image ethosu_firmware, size 244744
remoteproc remoteproc0: remote processor imx-rproc is now up
i think that the NPU is not activated
Greetings
Olivier
4,793件の閲覧回数
OlivierG
On IMX95
return
remoteproc remoteproc0: neutron-rproc is available
remoteproc remoteproc1: imx-rproc is available
remoteproc remoteproc1: attaching to imx-rproc
remoteproc remoteproc1: remote processor imx-rproc is now attached
remoteproc remoteproc0: powering up neutron-rproc
remoteproc remoteproc0: Booting fw image NeutronFirmware.elf, size 66896
remoteproc remoteproc0: remote processor neutron-rproc is now up
remoteproc remoteproc0: stopped remote processor neutron-rproc
4,677件の閲覧回数
Zhiming_Liu
Hi @OlivierG
Please try to use this model in attachment, this model is converted from L6.12.34 neutron converter.
root@imx95evk:/usr/bin/tensorflow-lite-2.19.0/examples# ./label_image -m mobilenet_v1_1.0_224_int8_converted.tflite --external_delegate_path=/lib/libneutron_delegate.so -i grace_hopper.bmp -l labels.txt
INFO: Loaded model mobilenet_v1_1.0_224_int8_converted.tflite
INFO: NeutronDelegate delegate: 1 nodes delegated out of 4 nodes with 1 partitions.
INFO: Neutron delegate version: v1.0.0-be8bf399, zerocp enabled.
INFO: Applied EXTERNAL delegate.
INFO: invoked
INFO: average time: 1.388 ms
INFO: 0.756863: 653 military uniform
INFO: 0.145098: 907 Windsor tie
INFO: 0.0156863: 458 bow tie
INFO: 0.0117647: 466 bulletproof vest
INFO: 0.00784314: 835 suit
Zhiming
%3CLINGO-SUB%20id%3D%22lingo-sub-2175643%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EIMX%2095%20NPU%E3%81%8C%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E5%8C%96%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2175643%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHI%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AFIMX%2095%20Verdin%20Toradex%E3%82%AB%E3%83%BC%E3%83%89a1%EF%BC%88b0%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%EF%BC%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3ENPU%E3%82%92%E8%A9%95%E4%BE%A1%E3%81%97%E3%81%9F%E3%81%84%3C%2FP%3E%3CP%3E%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%EF%BC%9A%3CBR%20%2F%3E%20%2Fusr%2Fbin%2Ftensorflow-lite-2.18.0%2Fexamples%23%20python3%20.%2Flabel_image.py%20--ext_delegate%20%2Fusr%2Flib%2Flibneutron_delegate.so%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E5%8F%97%E3%81%91%E5%8F%96%E3%82%8A%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3CEM%3Ecpuinfo%20%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%3A%20prctl(PR_SVE_GET_VL)%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%E6%83%85%E5%A0%B1%3A%20CPU%20%E7%94%A8%E3%81%AE%20TensorFlow%20Lite%20XNNPACK%20%E3%83%87%E3%83%AA%E3%82%B2%E3%83%BC%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FEM%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%82%89%202%20%E3%81%A4%E3%81%AE%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AE%E9%96%93%E3%81%AB%E3%81%AF%E9%96%A2%E9%80%A3%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3ENPU%20%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%A8%E7%B5%90%E8%AB%96%E4%BB%98%E3%81%91%E3%82%8B%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%94%E6%8C%A8%E6%8B%B6%3C%2FP%3E%3CP%3E%E3%82%AA%E3%83%AA%E3%83%B4%E3%82%A3%E3%82%A8%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2196397%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX%2095%20NPU%20not%20activated%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2196397%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F245939%22%20target%3D%22_blank%22%3E%40OlivierG%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%B7%BB%E4%BB%98%E3%81%AE%E3%83%A2%E3%83%87%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%93%E3%81%AE%E3%83%A2%E3%83%87%E3%83%AB%E3%81%AF%20L6.12.34%20Neutron%20%E3%82%B3%E3%83%B3%E3%83%90%E3%83%BC%E3%82%BF%E3%81%8B%E3%82%89%E5%A4%89%E6%8F%9B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Eroot%40imx95evk%3A%2Fusr%2Fbin%2Ftensorflow-lite-2.19.0%2Fexamples%23%20.%2Flabel_image%20-m%20mobilenet_v1_1.0_224_int8_converted.tflite%20--external_delegate_path%3D%2Flib%2Flibneutron_delegate.so%20-i%20grace_hopper.bmp%20-l%20labels.txt%0AINFO%3A%20Loaded%20model%20mobilenet_v1_1.0_224_int8_converted.tflite%0AINFO%3A%20resolved%20reporter%0AINFO%3A%20EXTERNAL%20delegate%20created.%0AINFO%3A%20NeutronDelegate%20delegate%3A%201%20nodes%20delegated%20out%20of%204%20nodes%20with%201%20partitions.%0A%0AINFO%3A%20Neutron%20delegate%20version%3A%20v1.0.0-be8bf399%2C%20zerocp%20enabled.%0AINFO%3A%20Applied%20EXTERNAL%20delegate.%0AINFO%3A%20Created%20TensorFlow%20Lite%20XNNPACK%20delegate%20for%20CPU.%0AINFO%3A%20invoked%0AINFO%3A%20average%20time%3A%201.388%20ms%0AINFO%3A%200.756863%3A%20653%20military%20uniform%0AINFO%3A%200.145098%3A%20907%20Windsor%20tie%0AINFO%3A%200.0156863%3A%20458%20bow%20tie%0AINFO%3A%200.0117647%3A%20466%20bulletproof%20vest%0AINFO%3A%200.00784314%3A%20835%20suit%0A%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%3CBR%20%2F%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%3CBR%20%2F%3E%E5%BF%97%E6%98%8E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2195638%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX%2095%20NPU%20not%20activated%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2195638%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EIMX95%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%3CBR%20%2F%3Edmesg%20%7C%20grep%20%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%83%97%E3%83%AD%E3%82%B7%E3%83%BC%E3%82%B8%E3%83%A3%3C%2FP%3E%3CP%3E%E6%88%BB%E3%82%8B%3CBR%20%2F%3Eremoteproc%20remoteproc0%3A%20neutron-rproc%E3%81%8C%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%3CBR%20%2F%3Eremoteproc%20remoteproc1%3A%20imx-rproc%20%E3%81%8C%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%3CBR%20%2F%3Eremoteproc%20remoteproc1%3A%20imx-rproc%20%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3Eremoteproc%20remoteproc1%3A%20%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%20imx-rproc%20%E3%81%8C%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%3CBR%20%2F%3Eremoteproc%20remoteproc0%3A%20neutron-rproc%20%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3Eremoteproc%20remoteproc0%3A%20FW%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8NeutronFirmware.elf%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%B5%E3%82%A4%E3%82%BA%2066896%3CBR%20%2F%3E%20remoteproc%20remoteproc0%3A%20%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%20neutron-rproc%20%E3%81%8C%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Eremoteproc%20remoteproc0%3A%20%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%20neutron-rproc%20%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%3CBR%20%2F%3Eremoteproc%20remoteproc0%3A%20neutron-rproc%20%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3Eremoteproc%20remoteproc0%3A%20FW%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8NeutronFirmware.elf%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%B5%E3%82%A4%E3%82%BA%2066896%3CBR%20%2F%3E%20remoteproc%20remoteproc0%3A%20%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%20neutron-rproc%20%E3%81%8C%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Eremoteproc%20remoteproc0%3A%20%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%20neutron-rproc%20%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2195637%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX%2095%20NPU%20not%20activated%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2195637%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%83%8F%E3%82%A4%3C%2FP%3E%3CP%3Eyocto%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E6%9C%80%E6%96%B0%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3imx-6.12.34-2.1.0%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%81%A8%3CBR%20%2F%3Epython3%20label_image.py%20-e%20%2Fusr%2Flib%2Flibneutron_delegate.so%3CBR%20%2F%3E%E7%A7%81%E3%81%AF%3CBR%20%2F%3E%2Fusr%2Flib%2Flibneutron_delegate.so%20%E3%81%8B%E3%82%89%E5%BC%95%E6%95%B0%20%7B%7D%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E5%A4%96%E9%83%A8%E3%83%87%E3%83%AA%E3%82%B2%E3%83%BC%E3%83%88%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%2Fusr%2Flib%2Fpython3.13%2Fsite-packages%2Ftflite_runtime%2Finterpreter.py%3A457%3AUserWarning%3A%20%E8%AD%A6%E5%91%8A%3A%20tf.lite.Interpreter%20%E3%81%AF%E9%9D%9E%E6%8E%A8%E5%A5%A8%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E5%89%8A%E9%99%A4%E3%81%95%E3%82%8C%E3%82%8B%E4%BA%88%E5%AE%9A%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%20TF2.20%E3%80%82ai_edge_litert%20%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%AE%20LiteRT%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%97%E3%83%AA%E3%82%BF%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%5B%E7%A7%BB%E8%A1%8C%E3%82%AC%E3%82%A4%E3%83%89%5D(%20%3CA%20href%3D%22https%3A%2F%2Fai.google.dev%2Fedge%2Flitert%2Fmigration%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fai.google.dev%2Fedge%2Flitert%2Fmigration%3C%2FA%3E%20)%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3CBR%20%2F%3E%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%AD%A6%E5%91%8A.warn(_INTERPRETER_DELETION_WARNING)%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%3A%20NeutronDelegate%20%E3%83%87%E3%83%AA%E3%82%B2%E3%83%BC%E3%83%88%3A%20%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%200%20%E5%80%8B%E3%81%AE%2031%20%E3%83%8E%E3%83%BC%E3%83%89%E3%81%AE%E3%81%86%E3%81%A1%200%20%E3%83%8E%E3%83%BC%E3%83%89%E3%81%8C%E5%A7%94%E4%BB%BB%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E6%83%85%E5%A0%B1%3A%20CPU%20%E7%94%A8%E3%81%AE%20TensorFlow%20Lite%20XNNPACK%20%E3%83%87%E3%83%AA%E3%82%B2%E3%83%BC%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%82%A6%E3%82%A9%E3%83%BC%E3%83%A0%E3%82%A2%E3%83%83%E3%83%97%E6%99%82%E9%96%93%3A%2094.5%20%E3%83%9F%E3%83%AA%E7%A7%92%3C%2FP%3E%3CP%3E%E6%8E%A8%E8%AB%96%E6%99%82%E9%96%93%3A%2060.2%20%E3%83%9F%E3%83%AA%E7%A7%92%3C%2FP%3E%3CP%3E0.878431%3A%20%E8%BB%8D%E6%9C%8D%3CBR%20%2F%3E0.027451%3A%20%E3%82%A6%E3%82%A3%E3%83%B3%E3%82%B6%E3%83%BC%E3%82%BF%E3%82%A4%3CBR%20%2F%3E0.011765%3A%20%E3%83%A2%E3%83%AB%E3%82%BF%E3%83%AB%E3%83%9C%E3%83%BC%E3%83%89%3CBR%20%2F%3E0.011765%3A%20%E9%98%B2%E5%BC%BE%E3%83%81%E3%83%A7%E3%83%83%E3%82%AD%3CBR%20%2F%3E0.007843%3A%20%E3%82%B5%E3%83%83%E3%82%AF%E3%82%B9%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E8%AD%A6%E5%91%8A%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%ABPython%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epython3%20label_image2.py%20-e%20%2Fusr%2Flib%2Flibneutron_delegate.so%3CBR%20%2F%3E%E7%A7%81%E3%81%AF%3CBR%20%2F%3E%2Fusr%2Flib%2Flibneutron_delegate.so%20%E3%81%8B%E3%82%89%E5%BC%95%E6%95%B0%20%7B%7D%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E5%A4%96%E9%83%A8%E3%83%87%E3%83%AA%E3%82%B2%E3%83%BC%E3%83%88%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%3A%20NeutronDelegate%20%E3%83%87%E3%83%AA%E3%82%B2%E3%83%BC%E3%83%88%3A%20%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%200%20%E5%80%8B%E3%81%AE%2031%20%E3%83%8E%E3%83%BC%E3%83%89%E3%81%AE%E3%81%86%E3%81%A1%200%20%E3%83%8E%E3%83%BC%E3%83%89%E3%81%8C%E5%A7%94%E4%BB%BB%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E6%83%85%E5%A0%B1%3A%20CPU%20%E7%94%A8%E3%81%AE%20TensorFlow%20Lite%20XNNPACK%20%E3%83%87%E3%83%AA%E3%82%B2%E3%83%BC%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%82%A6%E3%82%A9%E3%83%BC%E3%83%A0%E3%82%A2%E3%83%83%E3%83%97%E6%99%82%E9%96%93%3A%2058.0%20%E3%83%9F%E3%83%AA%E7%A7%92%3C%2FP%3E%3CP%3E%E6%8E%A8%E8%AB%96%E6%99%82%E9%96%93%3A%2055.5%20%E3%83%9F%E3%83%AA%E7%A7%92%3C%2FP%3E%3CP%3E0.878431%3A%20%E8%BB%8D%E6%9C%8D%3CBR%20%2F%3E0.027451%3A%20%E3%82%A6%E3%82%A3%E3%83%B3%E3%82%B6%E3%83%BC%E3%82%BF%E3%82%A4%3CBR%20%2F%3E0.011765%3A%20%E3%83%A2%E3%83%AB%E3%82%BF%E3%83%AB%E3%83%9C%E3%83%BC%E3%83%89%3CBR%20%2F%3E0.011765%3A%20%E9%98%B2%E5%BC%BE%E3%83%81%E3%83%A7%E3%83%83%E3%82%AD%3CBR%20%2F%3E0.007843%3A%20%E3%82%B5%E3%83%83%E3%82%AF%E3%82%B9%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%84%E3%81%A4%E3%82%82%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%3A%20CPU%20%E7%94%A8%E3%81%AE%20TensorFlow%20Lite%20XNNPACK%20%E3%83%87%E3%83%AA%E3%82%B2%E3%83%BC%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%3CSTRONG%3EIMX95%3C%2FSTRONG%3E%E3%81%A7%E3%81%AF%E3%81%9D%E3%82%8C%E3%82%92%E6%AD%A3%E7%A2%BA%E3%81%AB%E8%BF%B0%E3%81%B9%E3%81%AA%E3%81%91%E3%82%8C%E3%81%B0%E3%81%AA%E3%82%89%E3%81%AA%E3%81%84%3CBR%20%2F%3Ecat%20%2Fsys%2Fclass%2Fremoteproc%2Fremoteproc0%2Fstate%3CBR%20%2F%3E%E6%88%BB%E3%82%8B%3A%3CSTRONG%3E%E3%82%AA%E3%83%95%E3%83%A9%E3%82%A4%E3%83%B3%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3EIMX93%3C%2FSTRONG%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E5%90%8C%E3%81%98%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%AC%A1%E3%81%AE%E7%B5%90%E6%9E%9C%E3%81%8C%E8%BF%94%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%3A%20%3CSTRONG%3Erunning%3C%2FSTRONG%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSTRONG%3EIMX95%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%3C%2FSTRONG%3E%3CBR%20%2F%3Edmesg%20%7C%20grep%20%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%83%97%E3%83%AD%E3%82%B7%E3%83%BC%E3%82%B8%E3%83%A3%3C%2FP%3E%3CP%3E%E6%88%BB%E3%82%8B%3CBR%20%2F%3Eremoteproc%20remoteproc0%3A%20imx-rproc%E3%81%8C%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3E%3CSTRONG%3EIMX93%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%3C%2FSTRONG%3E%3CBR%20%2F%3Edmesg%20%7C%20grep%20%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%83%97%E3%83%AD%E3%82%B7%E3%83%BC%E3%82%B8%E3%83%A3%3CBR%20%2F%3E%E6%88%BB%E3%82%8B%3CBR%20%2F%3Eremoteproc%20remoteproc0%3A%20imx-rproc%E3%81%8C%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%3CBR%20%2F%3Eremoteproc%20remoteproc0%3A%20imx-rproc%20%E3%81%AE%E9%9B%BB%E6%BA%90%E3%82%92%E3%82%AA%E3%83%B3%E3%81%AB%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3Eremoteproc%20remoteproc0%3A%20FW%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%20ethosu_firmware%20%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%B5%E3%82%A4%E3%82%BA%20244744%3CBR%20%2F%3E%20remoteproc%20remoteproc0%3A%20%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%20imx-rproc%20%E3%81%8C%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ENPU%E3%81%8C%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%81%94%E6%8C%A8%E6%8B%B6%3C%2FP%3E%3CP%3E%E3%82%AA%E3%83%AA%E3%83%B4%E3%82%A3%E3%82%A8%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2195313%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX%2095%20NPU%20not%20activated%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2195313%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F245939%22%20target%3D%22_blank%22%3E%40OlivierG%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ENeutron%20%E3%83%87%E3%83%AA%E3%82%B2%E3%83%BC%E3%83%88%3CEM%3E%2Fusr%2Flib%2Flibneutron_delegate.so%20%E3%81%A7%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%3F%3C%2FEM%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%3CBR%20%2F%3E%E5%BF%97%E6%98%8E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2195312%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX%2095%20NPU%20not%20activated%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2195312%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F224771%22%20target%3D%22_blank%22%3E%40min-eta%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%AF%E3%81%84%E3%80%81%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AF%E3%83%BC%E3%82%AF%E3%81%AFL6.12.y%E3%81%8B%E3%82%89%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%3CBR%20%2F%3E%E5%BF%97%E6%98%8E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2195069%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX%2095%20NPU%20not%20activated%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2195069%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81Zhiming%20%E3%81%95%E3%82%93%E3%80%82%E3%81%93%E3%81%AE%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%B8%E3%81%AE%E8%BF%94%E4%BF%A1%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%80%81%E5%8F%A4%E3%81%84%20Linux%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%206.6.x%20%E3%81%A7%20NeutronDelegate%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E6%9C%80%E5%88%9D%E3%81%AB%20neutron_converter%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%A2%E3%83%87%E3%83%AB%E5%86%85%E3%81%AE%20TFLite%20Ops%20%E3%81%AE%E4%B8%80%E9%83%A8%E3%82%92%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%20NeutronGraph%20%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%AF%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%20Linux%206.12.x%20%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%81%BE%E3%81%9A%20neutron_converter%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%A2%E3%83%87%E3%83%AB%E3%82%92%E5%A4%89%E6%8F%9B%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F224771%22%20target%3D%22_blank%22%3E%40min-eta%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2194948%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX%2095%20NPU%20not%20activated%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2194948%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%83%8F%E3%82%A4%3C%2FP%3E%3CP%3E%E5%A4%89%E6%8F%9B%E3%81%97%E3%81%9F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7Python%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%3C%2FP%3E%3CP%3E%3CBR%20%2F%3Eroot%40imx95evk%3A%2Fusr%2Fbin%2Ftensorflow-lite-2.18.0%2Fexamples%23%20python3%20label_image.py%20-m%20mobilenet_v1_1.0_224_quant_converted.tflite%3CBR%20%2F%3E%20cpuinfo%20%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%3A%20prctl(PR_SVE_GET_VL)%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%3A%20CPU%20%E7%94%A8%E3%81%AE%20TensorFlow%20Lite%20XNNPACK%20%E3%83%87%E3%83%AA%E3%82%B2%E3%83%BC%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%E3%83%90%E3%83%83%E3%82%AF%EF%BC%88%E6%9C%80%E6%96%B0%E3%81%AE%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%8C%E6%9C%80%E5%BE%8C%EF%BC%89%3A%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%22%2Fusr%2Fbin%2Ftensorflow-lite-2.18.0%2Fexamples%2Flabel_image.py%22%E3%80%81%E8%A1%8C%2092%E3%80%81%3CMODULE%3E%3CBR%20%2F%3E%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%97%E3%83%AA%E3%82%BF.allocate_tensors()%3CBR%20%2F%3E~~~~~~~~~~~~~~~~~~~~~~~~~~~~~%5E%5E%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%22%2Fusr%2Flib%2Fpython3.13%2Fsite-packages%2Ftflite_runtime%2Finterpreter.py%22%2Callocate_tensors%E3%81%AE534%E8%A1%8C%E7%9B%AE%3CBR%20%2F%3Eself._interpreter.AllocateTensors()%20%E3%82%92%E8%BF%94%E3%81%99%3CBR%20%2F%3E~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~%5E%5E%3CBR%20%2F%3E%E5%AE%9F%E8%A1%8C%E6%99%82%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E6%9C%AA%E8%A7%A3%E6%B1%BA%E3%81%AE%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%20op%20%E3%81%AB%E9%81%AD%E9%81%87%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%20NeutronGraph%E3%80%82%3CBR%20%2F%3E%E6%89%8B%E9%A0%86%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fwww.tensorflow.org%2Flite%2Fguide%2Fops_custom%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.tensorflow.org%2Flite%2Fguide%2Fops_custom%20%E3%82%92%3C%2FA%3E%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%83%8E%E3%83%BC%E3%83%89%E7%95%AA%E5%8F%B7%201%20(NeutronGraph)%20%E3%81%AE%E6%BA%96%E5%82%99%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%9C%AA%E8%A7%A3%E6%B1%BA%E3%81%AE%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%20op%3A%20NeutronGraph%20%E3%81%AB%E9%81%AD%E9%81%87%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E6%89%8B%E9%A0%86%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fwww.tensorflow.org%2Flite%2Fguide%2Fops_custom%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.tensorflow.org%2Flite%2Fguide%2Fops_custom%20%E3%82%92%3C%2FA%3E%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%83%8E%E3%83%BC%E3%83%89%E7%95%AA%E5%8F%B7%201%20(NeutronGraph)%20%E3%81%AE%E6%BA%96%E5%82%99%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FMODULE%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E5%AE%9F%E8%A1%8C%E5%8F%AF%E8%83%BD%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%AF%3CBR%20%2F%3Eroot%40imx95evk%3A%2Fusr%2Fbin%2Ftensorflow-lite-2.18.0%2Fexamples%23%20.%2Flabel_image-m%20mobilenet_v1_1.0_224_quant_converted.tflite%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%3A%20%E3%83%A2%E3%83%87%E3%83%AB%20mobilenet_v1_1.0_224_quant_converted.tflite%20%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%3A%20%E8%A7%A3%E6%B1%BA%E6%B8%88%E3%81%BF%E5%A0%B1%E5%91%8A%E8%80%85%3CBR%20%2F%3Ecpuinfo%20%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%3A%20prctl(PR_SVE_GET_VL)%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%3A%20CPU%20%E7%94%A8%E3%81%AE%20TensorFlow%20Lite%20XNNPACK%20%E3%83%87%E3%83%AA%E3%82%B2%E3%83%BC%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E6%9C%AA%E8%A7%A3%E6%B1%BA%E3%81%AE%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%20op%3A%20NeutronGraph%20%E3%81%AB%E9%81%AD%E9%81%87%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E6%89%8B%E9%A0%86%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fwww.tensorflow.org%2Flite%2Fguide%2Fops_custom%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.tensorflow.org%2Flite%2Fguide%2Fops_custom%20%E3%82%92%3C%2FA%3E%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%83%8E%E3%83%BC%E3%83%89%E7%95%AA%E5%8F%B7%201%20(NeutronGraph)%20%E3%81%AE%E6%BA%96%E5%82%99%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E6%9C%AA%E8%A7%A3%E6%B1%BA%E3%81%AE%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%20op%3A%20NeutronGraph%20%E3%81%AB%E9%81%AD%E9%81%87%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E6%89%8B%E9%A0%86%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fwww.tensorflow.org%2Flite%2Fguide%2Fops_custom%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.tensorflow.org%2Flite%2Fguide%2Fops_custom%20%E3%82%92%3C%2FA%3E%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%83%8E%E3%83%BC%E3%83%89%E7%95%AA%E5%8F%B7%201%20(NeutronGraph)%20%E3%81%AE%E6%BA%96%E5%82%99%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%83%86%E3%83%B3%E3%82%BD%E3%83%AB%E3%81%AE%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%94%E6%8C%A8%E6%8B%B6%3C%2FP%3E%3CP%3E%E3%82%AA%E3%83%AA%E3%83%B4%E3%82%A3%E3%82%A8%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2194633%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX%2095%20NPU%20not%20activated%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2194633%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F245939%22%20target%3D%22_blank%22%3E%40OlivierG%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%89%8D%E5%9B%9E%E3%81%AE%E8%BF%94%E4%BF%A1%E3%81%AF%E3%81%93%E3%81%A1%E3%82%89%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Zhiming_Liu_0-1761699158616.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Zhiming_Liu_0-1761699158616.png%22%20style%3D%22width%3A%20302px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F362966iD7BBE858E45F2564%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Zhiming_Liu_0-1761699158616.png%22%20alt%3D%22Zhiming_Liu_0-1761699158616.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3Ei.MX95%E3%81%A7NPU%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AA.tflite%E3%82%92Neutron%20.tflite%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82eIQ%20%E3%81%BE%E3%81%9F%E3%81%AF%20neutron%20%E3%82%B3%E3%83%B3%E3%83%90%E3%83%BC%E3%82%BF%E3%83%BC%20CLI%20%E3%81%AB%E3%82%88%E3%82%8B%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%81%93%E3%81%A7%E3%81%AF%E3%80%81eIQ%20%E3%81%A7%E5%A4%89%E6%8F%9B%E3%81%97%E3%81%9F%E3%81%93%E3%81%AE%E3%83%A2%E3%83%87%E3%83%AB%E3%82%92%E8%A9%A6%E3%81%99%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%3CBR%20%2F%3E%E5%BF%97%E6%98%8E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2194308%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX%2095%20NPU%20not%20activated%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2194308%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%83%8F%E3%82%A4%3C%2FP%3E%3CP%3E%E4%BB%8A%E3%80%81%E7%A7%81%E3%81%AFimx95-19x19-lpddr5-evk%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3EYocto%20%E3%81%AF%3CBR%20%2F%3Ei.MX%20Linux%20Yocto%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%20BSP%206.12.20_2.0.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%3C%2FP%3E%3CP%3E%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%81%A8%3CBR%20%2F%3Eroot%40imx95evk%3A%2Fusr%2Fbin%2Ftensorflow-lite-2.18.0%2Fexamples%23%20.%2Fbenchmark_model--graph%3Dmobilenet_v1_1.0_224_quant.tflite%20--external_delegate_path%3D%2Fusr%2Flib%2Flibneutron_delegate.so%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%3A%20%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%99!%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%3A%20%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E5%80%A4%E3%82%92%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%83%AD%E3%82%B0%E3%81%AB%E8%A8%98%E9%8C%B2%3A%20%5B0%5D%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%3A%20%E3%82%B0%E3%83%A9%E3%83%95%3A%20%5Bmobilenet_v1_1.0_224_quant.tflite%5D%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%3A%20%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E7%BD%B2%E5%90%8D%3A%20%5B%5D%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%3A%20%E5%A4%96%E9%83%A8%E3%83%87%E3%83%AA%E3%82%B2%E3%83%BC%E3%83%88%E3%83%91%E3%82%B9%3A%20%5B%2Fusr%2Flib%2Flibneutron_delegate.so%5D%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%3A%20%E3%83%A2%E3%83%87%E3%83%AB%20mobilenet_v1_1.0_224_quant.tflite%20%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%3A%20EXTERNAL%20%E3%83%87%E3%83%AA%E3%82%B2%E3%83%BC%E3%83%88%E3%81%8C%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%3CSTRONG%3E%E6%83%85%E5%A0%B1%3A%20NeutronDelegate%20%E3%83%87%E3%83%AA%E3%82%B2%E3%83%BC%E3%83%88%3A%20%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%200%20%E5%80%8B%E3%81%AE%2031%20%E3%83%8E%E3%83%BC%E3%83%89%E3%81%AE%E3%81%86%E3%81%A1%200%20%E3%83%8E%E3%83%BC%E3%83%89%E3%81%8C%E5%A7%94%E4%BB%BB%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E6%83%85%E5%A0%B1%3A%20EXTERNAL%20%E3%83%87%E3%83%AA%E3%82%B2%E3%83%BC%E3%83%88%E3%81%8C%E6%98%8E%E7%A4%BA%E7%9A%84%E3%81%AB%E9%81%A9%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%83%A2%E3%83%87%E3%83%AB%20%E3%82%B0%E3%83%A9%E3%83%95%E3%81%AF%E3%83%87%E3%83%AA%E3%82%B2%E3%83%BC%E3%83%88%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSTRONG%3E%3CBR%20%2F%3Ecpuinfo%20%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%3A%20prctl(PR_SVE_GET_VL)%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%3A%20CPU%20%E7%94%A8%E3%81%AE%20TensorFlow%20Lite%20XNNPACK%20%E3%83%87%E3%83%AA%E3%82%B2%E3%83%BC%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%3A%20%E5%85%A5%E5%8A%9B%E3%83%A2%E3%83%87%E3%83%AB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E3%82%B5%E3%82%A4%E3%82%BA%20(MB)%3A%204.27635%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%3A%2056.257%20%E3%83%9F%E3%83%AA%E7%A7%92%E3%81%A7%E3%82%BB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%3A%20%E3%83%99%E3%83%B3%E3%83%81%E3%83%9E%E3%83%BC%E3%82%AF%E3%82%92%E5%B0%91%E3%81%AA%E3%81%8F%E3%81%A8%E3%82%82%201%20%E5%9B%9E%E3%81%AE%E5%8F%8D%E5%BE%A9%E3%81%A8%E5%B0%91%E3%81%AA%E3%81%8F%E3%81%A8%E3%82%82%200.5%20%E7%A7%92%E9%96%93%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81150%20%E7%A7%92%E3%82%92%E8%B6%85%E3%81%88%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%3A%20count%3D5%20first%3D122578%20curr%3D118671%20min%3D118400%20max%3D122578%20avg%3D119396%20std%3D1595%3C%2FP%3E%3CP%3E%E6%83%85%E5%A0%B1%3A%20%E3%83%99%E3%83%B3%E3%83%81%E3%83%9E%E3%83%BC%E3%82%AF%E3%82%92%E5%B0%91%E3%81%AA%E3%81%8F%E3%81%A8%E3%82%82%2050%20%E5%9B%9E%E5%8F%8D%E5%BE%A9%E3%81%97%E3%80%81%E5%B0%91%E3%81%AA%E3%81%8F%E3%81%A8%E3%82%82%201%20%E7%A7%92%E9%96%93%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81150%20%E7%A7%92%E3%82%92%E8%B6%85%E3%81%88%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%3A%20count%3D50%20first%3D118459%20curr%3D117971%20min%3D117954%20max%3D118782%20avg%3D118259%20std%3D173%3C%2FP%3E%3CP%3E%E6%83%85%E5%A0%B1%3A%20%E6%8E%A8%E8%AB%96%E6%99%82%E9%96%93%20(us)%3A%20%E5%88%9D%E6%9C%9F%E5%8C%96%3A%2056257%E3%80%81%E6%9C%80%E5%88%9D%E3%81%AE%E6%8E%A8%E8%AB%96%3A%20122578%E3%80%81%E3%82%A6%E3%82%A9%E3%83%BC%E3%83%A0%E3%82%A2%E3%83%83%E3%83%97%20(%E5%B9%B3%E5%9D%87)%3A%20119396%E3%80%81%E6%8E%A8%E8%AB%96%20(%E5%B9%B3%E5%9D%87)%3A%20118259%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%3A%20%E6%B3%A8%E6%84%8F%3A%20%E3%83%99%E3%83%B3%E3%83%81%E3%83%9E%E3%83%BC%E3%82%AF%20%E3%83%84%E3%83%BC%E3%83%AB%E8%87%AA%E4%BD%93%E3%81%8C%E3%83%A1%E3%83%A2%E3%83%AA%20%E3%83%95%E3%83%83%E3%83%88%E3%83%97%E3%83%AA%E3%83%B3%E3%83%88%E3%81%AB%E5%BD%B1%E9%9F%BF%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AF%E5%AE%9F%E8%A1%8C%E6%99%82%E3%81%AE%E3%83%A2%E3%83%87%E3%83%AB%E3%81%AE%E5%AE%9F%E9%9A%9B%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%20%E3%83%95%E3%83%83%E3%83%88%E3%83%97%E3%83%AA%E3%83%B3%E3%83%88%E3%81%AE%E6%A6%82%E7%AE%97%E5%80%A4%E3%81%AB%E3%81%99%E3%81%8E%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E6%83%85%E5%A0%B1%E3%81%AF%E3%81%94%E8%87%AA%E8%BA%AB%E3%81%AE%E5%88%A4%E6%96%AD%E3%81%A7%E3%81%94%E5%88%A9%E7%94%A8%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%3A%20%E3%83%84%E3%83%BC%E3%83%AB%E9%96%8B%E5%A7%8B%E3%81%8B%E3%82%89%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%95%E3%83%83%E3%83%88%E3%83%97%E3%83%AA%E3%83%B3%E3%83%88%E3%81%AE%E5%B7%AE%E5%88%86%20(MB)%3A%20init%3D12.0352%20%E5%85%A8%E4%BD%93%3D15.1602%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%81%A8%3CBR%20%2F%3Ecat%20%2Fsys%2Fclass%2Fremoteproc%2Fremoteproc0%2Fstate%3CBR%20%2F%3E%3CSTRONG%3E%E3%82%AA%E3%83%95%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AB%3C%2FSTRONG%3E%E3%81%AA%E3%82%8B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%94%E6%8C%A8%E6%8B%B6%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%AA%E3%83%AA%E3%83%B4%E3%82%A3%E3%82%A8%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2189593%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX%2095%20NPU%20not%20activated%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2189593%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%0A%3CP%3E.tflite%E3%82%92%E5%A4%89%E6%8F%9B%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AFeIQ%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84Neutron%20%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Zhiming_Liu_0-1761024034289.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Zhiming_Liu_0-1761024034289.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F361735iB6FEBBFCB1B4FCB0%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Zhiming_Liu_0-1761024034289.png%22%20alt%3D%22Zhiming_Liu_0-1761024034289.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EeIQ1.16%20%E3%81%AF%20L6.12.20%20Neutron%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E7%94%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Zhiming_Liu_1-1761024318029.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Zhiming_Liu_1-1761024318029.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F361736i0389BF8CAD6E8C91%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Zhiming_Liu_1-1761024318029.png%22%20alt%3D%22Zhiming_Liu_1-1761024318029.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22fontstyle0%22%3ENeutron%20%E3%82%B3%E3%83%B3%E3%83%90%E3%83%BC%E3%82%BF%3C%2FSPAN%3E%20CLI%20%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81eIQ%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%AC%E3%82%A4%E3%83%89%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Zhiming_Liu_0-1761024419102.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Zhiming_Liu_0-1761024419102.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F361737i50BB2568CC717F15%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Zhiming_Liu_0-1761024419102.png%22%20alt%3D%22Zhiming_Liu_0-1761024419102.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CBR%20%2F%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%3CBR%20%2F%3E%E5%BF%97%E6%98%8E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2182501%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX%2095%20NPU%20not%20activated%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2182501%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%AF%E3%81%84%E3%80%81SW%20%E3%83%81%E3%83%BC%E3%83%A0%E3%81%8C%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%AA%BF%E6%9F%BB%E4%B8%AD%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%3CBR%20%2F%3E%E5%BF%97%E6%98%8E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2178085%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX%2095%20NPU%20not%20activated%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2178085%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHI%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AEPython%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E8%A9%A6%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3CEM%3ETensorflow%E3%82%92TF%E3%81%A8%E3%81%97%E3%81%A6%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%E3%83%A2%E3%83%87%E3%83%AB%E3%83%91%E3%82%B9%20%3D'model_yolo_11s_int8_fp32.tflite'%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3Efid%E3%81%A8%E3%81%97%E3%81%A6open(modelpath%2C%20'rb')%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%3A%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3Etflite_model%20%3D%20fid.read()%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%97%E3%83%AA%E3%82%BF%E3%83%BC%20%3D%20tf.lite.Interpreter(model_content%3Dtflite_model%E3%80%81experimental_delegates%3D%5Btf.lite.experimental.load_delegate('libneutron_delegate.so')%5D)%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%97%E3%83%AA%E3%82%BF.allocate_tensors()%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E6%AC%A1%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3CEM%3E%2Fusr%2Flib%2Fpython3.13%2Fsite-packages%2Ftensorflow%2Flite%2Fpython%2Finterpreter.py%3A457%3A%20UserWarning%3A%20%E8%AD%A6%E5%91%8A%3A%20tf.lite.Interpreter%20%E3%81%AF%E9%9D%9E%E6%8E%A8%E5%A5%A8%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E5%89%8A%E9%99%A4%E3%81%95%E3%82%8C%E3%82%8B%E4%BA%88%E5%AE%9A%E3%81%A7%E3%81%99%E3%80%82%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3ETF%202.20%E3%80%82ai_edge_litert%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%AELiteRT%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%97%E3%83%AA%E3%82%BF%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%5B%E7%A7%BB%E8%A1%8C%E3%82%AC%E3%82%A4%E3%83%89%5D(%20%3CA%20href%3D%22https%3A%2F%2Fai.google.dev%2Fedge%2Flitert%2Fmigration%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fai.google.dev%2Fedge%2Flitert%2Fmigration%3C%2FA%3E%20)%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%82%3C%2FEM%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CEM%3E%E8%AD%A6%E5%91%8A.warn(_INTERPRETER_DELETION_WARNING)%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%E6%83%85%E5%A0%B1%3A%20NeutronDelegate%20%E3%83%87%E3%83%AA%E3%82%B2%E3%83%BC%E3%83%88%3A%20%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%200%20%E5%80%8B%E3%81%AE%20339%20%E3%83%8E%E3%83%BC%E3%83%89%E3%81%AE%E3%81%86%E3%81%A1%200%20%E5%80%8B%E3%81%AE%E3%83%8E%E3%83%BC%E3%83%89%E3%81%8C%E5%A7%94%E4%BB%BB%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%E6%83%85%E5%A0%B1%3A%20CPU%20%E7%94%A8%E3%81%AE%20TensorFlow%20Lite%20XNNPACK%20%E3%83%87%E3%83%AA%E3%82%B2%E3%83%BC%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%E4%BE%8B%E5%A4%96%E3%81%AF%E7%84%A1%E8%A6%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%20%3CFUNCTION%20delegate.__del__%3D%22%22%20at%3D%22%22%200xffff5171bf60%3D%22%22%3E%3C%2FFUNCTION%3E%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%E3%83%90%E3%83%83%E3%82%AF%EF%BC%88%E6%9C%80%E6%96%B0%E3%81%AE%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%8C%E6%9C%80%E5%BE%8C%EF%BC%89%3A%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%22%2Fusr%2Flib%2Fpython3.13%2Fsite-packages%2Ftensorflow%2Flite%2Fpython%2Finterpreter.py%22%E3%80%81%E8%A1%8C%E7%95%AA%E5%8F%B7%20122%E3%80%81%20__del__%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3EAttributeError%3A%20'NoneType'%20%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AB%E3%81%AF%E5%B1%9E%E6%80%A7%20'c_void_p'%20%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FEM%3E%3C%2FP%3E%3CP%3EPython%20%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E7%AD%94%E3%81%88%E3%81%A8%E4%B8%80%E8%87%B4%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E%E7%A7%81%E3%81%AF%E3%80%81%20%3CEM%3Eibethosu_delegate.so%3C%2FEM%3E%E3%81%8C%E7%A7%81%E3%81%AE%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AB%E8%BC%89%E3%81%A3%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E6%98%8E%E7%A2%BA%E3%81%AB%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%94%E6%8C%A8%E6%8B%B6%3C%2FP%3E%3CP%3E%E3%82%AA%E3%83%AA%E3%83%B4%E3%82%A3%E3%82%A8%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2177776%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX%2095%20NPU%20not%20activated%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2177776%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F245939%22%20target%3D%22_blank%22%3E%40OlivierG%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EL6.6.X%20%E3%81%AA%E3%81%A9%E3%80%81Tensorflow%202.16.2%20%E3%81%AE%E5%8F%A4%E3%81%84%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Eroot%40imx95frdm%3A%2Fusr%2Fbin%2Ftensorflow-lite-2.16.2%2Fexamples%23%20python3%20label_image.py%20--ext_delegate%20%2Fusr%2Flib%2Flibneutron_delegate.so%0ALoading%20external%20delegate%20from%20%2Fusr%2Flib%2Flibneutron_delegate.so%20with%20args%3A%20%7B%7D%0A%0AINFO%3A%20NeutronDelegate%20delegate%3A%2029%20nodes%20delegated%20out%20of%2031%20nodes%20with%201%20partitions.%0A%0AINFO%3A%20Created%20TensorFlow%20Lite%20XNNPACK%20delegate%20for%20CPU.%0AWarm-up%20time%3A%203.9%20ms%0A%0AInference%20time%3A%201.8%20ms%0A%0A0.850980%3A%20military%20uniform%0A0.058824%3A%20Windsor%20tie%0A0.011765%3A%20bulletproof%20vest%0A0.007843%3A%20bow%20tie%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%E6%9C%80%E6%96%B0%E3%81%AE%20BSP%20L6.12.34%20%E3%81%A7%E3%82%82%20NPU%20%E3%83%87%E3%83%AA%E3%82%B2%E3%83%BC%E3%83%88%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%3CBR%20%2F%3E%E5%BF%97%E6%98%8E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2176366%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX%2095%20NPU%20not%20activated%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2176366%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ehi%3C%2FP%3E%3CP%3EIMX%2095%E3%81%A7%E3%81%AF%3C%2FP%3E%3CP%3E%3CEM%3Epython3%20label_image.py%20--ext_delegate%20%2Fusr%2Flib%2Flibneutron_delegate.so%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3Elibneutron_delegate.so%20%E3%81%8B%E3%82%89%E5%BC%95%E6%95%B0%20%7B%7D%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E5%A4%96%E9%83%A8%E3%83%87%E3%83%AA%E3%82%B2%E3%83%BC%E3%83%88%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%20ext_delegate%20%5B%5D%3CTFLITE_RUNTIME.INTERPRETER.DELEGATE%20object%3D%22%22%20at%3D%22%22%200xffffa6d52660%3D%22%22%3E%20%3C%2FTFLITE_RUNTIME.INTERPRETER.DELEGATE%3E%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%E6%83%85%E5%A0%B1%3A%20NeutronDelegate%20%E3%83%87%E3%83%AA%E3%82%B2%E3%83%BC%E3%83%88%3A%20%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%200%20%E5%80%8B%E3%81%AE%2031%20%E3%83%8E%E3%83%BC%E3%83%89%E3%81%AE%E3%81%86%E3%81%A1%200%20%E3%83%8E%E3%83%BC%E3%83%89%E3%81%8C%E5%A7%94%E4%BB%BB%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3Ecpuinfo%20%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%3A%20prctl(PR_SVE_GET_VL)%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%E6%83%85%E5%A0%B1%3A%20CPU%20%E7%94%A8%E3%81%AE%20TensorFlow%20Lite%20XNNPACK%20%E3%83%87%E3%83%AA%E3%82%B2%E3%83%BC%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%E3%82%A6%E3%82%A9%E3%83%BC%E3%83%A0%E3%82%A2%E3%83%83%E3%83%97%E6%99%82%E9%96%93%3A%20122.3%20%E3%83%9F%E3%83%AA%E7%A7%92%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%E6%8E%A8%E8%AB%96%E6%99%82%E9%96%93%3A%20118.2%20%E3%83%9F%E3%83%AA%E7%A7%92%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E0.870588%3A%20%E8%BB%8D%E6%9C%8D%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E0.031373%3A%20%E3%82%A6%E3%82%A3%E3%83%B3%E3%82%B6%E3%83%BC%E3%82%BF%E3%82%A4%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E0.011765%3A%20%E3%83%A2%E3%83%AB%E3%82%BF%E3%83%AB%E3%83%9C%E3%83%BC%E3%83%89%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E0.007843%3A%20%E8%9D%B6%E3%83%8D%E3%82%AF%E3%82%BF%E3%82%A4%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E0.007843%3A%20%E9%98%B2%E5%BC%BE%E3%83%81%E3%83%A7%E3%83%83%E3%82%AD%3C%2FEM%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%81%AB%E6%AF%94%E3%81%B9%E3%81%A6%E3%80%81IMX%2093%E3%81%A7%E3%81%AF%3C%2FP%3E%3CP%3E%3CEM%3Epython3%20label_image.py%20--ext_delegate%20%2Fusr%2Flib%2Flibethosu_delegate.so%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%2Fusr%2Flib%2Flibethosu_delegate.so%20%E3%81%8B%E3%82%89%E5%BC%95%E6%95%B0%20%7B%7D%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E5%A4%96%E9%83%A8%E3%83%87%E3%83%AA%E3%82%B2%E3%83%BC%E3%83%88%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3EINFO%3A%20Ethosu%20%E3%83%87%E3%83%AA%E3%82%B2%E3%83%BC%E3%83%88%3A%20device_name%20%E3%81%8C%20%2Fdev%2Fethosu0%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%E6%83%85%E5%A0%B1%3A%20Ethosu%20%E3%83%87%E3%83%AA%E3%82%B2%E3%83%BC%E3%83%88%3A%20cache_file_path%20%E3%81%8C%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%E6%83%85%E5%A0%B1%3A%20Ethosu%20%E3%83%87%E3%83%AA%E3%82%B2%E3%83%BC%E3%83%88%3A%20%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%8C%2060000000000%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%E6%83%85%E5%A0%B1%3A%20Ethosu%20%E3%83%87%E3%83%AA%E3%82%B2%E3%83%BC%E3%83%88%3A%20enable_cycle_counter%20%E3%81%8C%200%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%E6%83%85%E5%A0%B1%3A%20Ethosu%20%E3%83%87%E3%83%AA%E3%82%B2%E3%83%BC%E3%83%88%3A%20enable_profiling%20%E3%81%8C%200%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%E6%83%85%E5%A0%B1%3A%20Ethosu%20%E3%83%87%E3%83%AA%E3%82%B2%E3%83%BC%E3%83%88%3A%20profiling_buffer_size%20%E3%81%8C%202048%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%E6%83%85%E5%A0%B1%3A%20Ethosu%20%E3%83%87%E3%83%AA%E3%82%B2%E3%83%BC%E3%83%88%3A%20pmu_event0%20%E3%81%8C%200%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%E6%83%85%E5%A0%B1%3A%20Ethosu%20%E3%83%87%E3%83%AA%E3%82%B2%E3%83%BC%E3%83%88%3A%20pmu_event1%20%E3%81%8C%200%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%E6%83%85%E5%A0%B1%3A%20Ethosu%20%E3%83%87%E3%83%AA%E3%82%B2%E3%83%BC%E3%83%88%3A%20pmu_event2%20%E3%81%8C%200%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%E6%83%85%E5%A0%B1%3A%20Ethosu%20%E3%83%87%E3%83%AA%E3%82%B2%E3%83%BC%E3%83%88%3A%20pmu_event3%20%E3%81%8C%200%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%E6%83%85%E5%A0%B1%3A%20EthosuDelegate%3A%201%20%E3%81%A4%E3%81%AE%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E6%8C%81%E3%81%A4%2031%20%E3%83%8E%E3%83%BC%E3%83%89%E3%81%AE%E3%81%86%E3%81%A1%2031%20%E3%83%8E%E3%83%BC%E3%83%89%E3%81%8C%E5%A7%94%E4%BB%BB%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%E3%82%A6%E3%82%A9%E3%83%BC%E3%83%A0%E3%82%A2%E3%83%83%E3%83%97%E6%99%82%E9%96%93%3A%204.1%20%E3%83%9F%E3%83%AA%E7%A7%92%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%E6%8E%A8%E8%AB%96%E6%99%82%E9%96%93%3A%203.9%20%E3%83%9F%E3%83%AA%E7%A7%92%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E0.874510%3A%20%E8%BB%8D%E6%9C%8D%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E0.031373%3A%20%E3%82%A6%E3%82%A3%E3%83%B3%E3%82%B6%E3%83%BC%E3%82%BF%E3%82%A4%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E0.015686%3A%20%E3%83%A2%E3%83%AB%E3%82%BF%E3%83%AB%E3%83%9C%E3%83%BC%E3%83%89%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E0.011765%3A%20%E9%98%B2%E5%BC%BE%E3%83%81%E3%83%A7%E3%83%83%E3%82%AD%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E0.007843%3A%20%E8%9D%B6%E3%83%8D%E3%82%AF%E3%82%BF%E3%82%A4%3C%2FEM%3E%3C%2FP%3E%3CP%3Eimx%2093%E3%81%A7%E3%81%AF%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3A%3C%2FP%3E%3CP%3E%3CEM%3E%E6%83%85%E5%A0%B1%3A%20CPU%20%E7%94%A8%E3%81%AE%20TensorFlow%20Lite%20XNNPACK%20%E3%83%87%E3%83%AA%E3%82%B2%E3%83%BC%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FEM%3E%3C%2FP%3E%3CP%3E%E6%8E%A8%E8%AB%96%E6%99%82%E9%96%93%E3%81%AF%3CEM%3E118.2%E3%83%9F%E3%83%AA%E7%A7%92%E3%81%8B%E3%82%893.9%E3%83%9F%E3%83%AA%E7%A7%92%E3%81%B8%E3%81%A8%3C%2FEM%3E%E5%A4%A7%E5%B9%85%E3%81%AB%E7%9F%AD%E7%B8%AE%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%AA%E3%83%AA%E3%83%B4%E3%82%A3%E3%82%A8%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2176138%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX%2095%20NPU%20not%20activated%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2176138%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E%3CSPAN%3E%E3%81%93%E3%82%8C%E3%82%89%202%20%E3%81%A4%E3%81%AE%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AE%E9%96%93%E3%81%AB%E3%81%AF%E9%96%A2%E9%80%A3%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E--%26gt%3B%E3%81%9D%E3%82%8C%E3%82%89%E3%81%AB%E9%96%A2%E3%81%97%E3%81%A6%E6%8E%A5%E7%B6%9A%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E%3CSPAN%3ENPU%20%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%A8%E7%B5%90%E8%AB%96%E4%BB%98%E3%81%91%E3%82%8B%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E--%26gt%3B%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%83%AD%E3%82%B0%E3%81%8CCAN%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81NPU%20%E3%83%87%E3%83%AA%E3%82%B2%E3%83%BC%E3%83%88%E3%81%8C%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3EINFO%3A%20NeutronDelegate%20delegate%3A%20.......%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%3CBR%20%2F%3E%3CSPAN%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E--%26gt%3BCAN%E5%AE%8C%E5%85%A8%E3%81%AA%E3%83%AD%E3%82%B0%E3%82%92%E5%85%B1%E6%9C%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%3CBR%20%2F%3E%E5%BF%97%E6%98%8E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
