IM95 Libcamera - Configure manual gain/exposure
3,907 次查看
rolin99
I am currently trying to configure the manual gain/exposure for `os08a20` model cameras with IMX95. We have configured the gain and exposure to be 1.0 analog gain and 3000US for exposure with the following:
req->controls().set(libcamera::controls::AeEnable, false);
req->controls().set(libcamera::controls::ExposureTime, 3000);
req->controls().set(libcamera::controls::AnalogueGain, 1.0);
However, it appears that the Libcamera debug logs are indicating gain/exposure values being set via NXP NEO AGC computed values. Can you advise on how to properly configure manual exposure and analog gain values via Libcamera API?
8 回复数
3,884 次查看
rolin99
For reference, this is the Libcamera version I'm using: https://github.com/nxp-imx/libcamera
3,888 次查看
rolin99
3,859 次查看
joanxie
try to use command as below to set
cam --camera X --stream width=${W},height=${H},pixelformat=YUYV --capture=1000 --display=HDMI-A-1 --script script_gain_exposure.yaml
3,803 次查看
rolin99
HI joanxie,
I think I need to be able to programmatically change the gain/exposure via Libcamera API rather than using the `cam` tool.
3,773 次查看
joanxie
cam also used libcamera, refer to the linux user guide, Libcamera comes with the cam test application that uses the native libcamera API
3,748 次查看
rolin99
Hi Joanxie,
I used the cam tool to stream, however, I am seeing some inconsistent results in the libcamera logs. The logs are showing the following configs being applied:
[0:17:10.346165015] [2328] DEBUG NxpNeoAlgoAgc agc.cpp:193 Set exposure to 712
[0:17:09.504320639] [2321] DEBUG NxpNeoAlgoGoc goc.cpp:185 [xferFunc] linearGain: 12.92, linearThreshold: 0.0031308, nonLinearGain: 1.055, nonLinearOffset: 0.0521327, gammaInverse: 0.416667
[0:17:07.826928461] [2321] DEBUG NxpNeoAlgoDrc drc.cpp:654 global GAIN=256
[0:17:10.346186099] [2328] DEBUG NxpNeoAlgoAgc agc.cpp:201 Set gain to 1
These don't match up with the config in the YAML file. The full logs also included in this msg.
标记 (1)
3,478 次查看
joanxie
I tested os08a20 with my imx95 evk board, the command is
my script is
frames:
  - 0:
      AeEnable: false
      AnalogueGain: 1.0000000
      ExposureTime: 10000
  - 10:
      AeEnable: false
      AnalogueGain: 5.0000000
      ExposureTime: 60000
  - 20:
      AeEnable: false
      ExposureTime: 10000
  - 30:
      AeEnable: false
      ExposureTime: 60000
  - 40:
      AeEnable: false
      ExposureTime: 10000
  - 50:
      AeEnable: false
      ExposureTime: 60000
  - 100:
      AeEnable: false
      ExposureTime: 10000
the log file is
the result is the same as settings, but I found it has 4 frame delay, internal team  still  investigate this
3,746 次查看
rolin99
[0:32:37.475564258] [3313] DEBUG NxpNeoAlgoAgc agc.cpp:415 Divided up exposure time, analogue gain and digital gain are 16554.43us, 15.5 and 2.4224
%3CLINGO-SUB%20id%3D%22lingo-sub-2257356%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EIM95%20Libcamera%20-%20%E9%85%8D%E7%BD%AE%E6%89%8B%E5%8A%A8%E5%A2%9E%E7%9B%8A%2F%E6%9B%9D%E5%85%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2257356%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E7%9B%AE%E5%89%8D%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E4%B8%BA%E9%85%8D%E5%A4%87%20IMX95%20%E7%9A%84%20%60os08a20%60%20%E5%9E%8B%E7%9B%B8%E6%9C%BA%E9%85%8D%E7%BD%AE%E6%89%8B%E5%8A%A8%E5%A2%9E%E7%9B%8A%2F%E6%9B%9D%E5%85%89%E3%80%82%E6%88%91%E4%BB%AC%E5%B0%86%E5%A2%9E%E7%9B%8A%E5%92%8C%E6%9B%9D%E5%85%89%E9%85%8D%E7%BD%AE%E4%B8%BA%201.0%20%E6%A8%A1%E6%8B%9F%E5%A2%9E%E7%9B%8A%EF%BC%8C%E5%B0%86%E6%9B%9D%E5%85%89%E9%85%8D%E7%BD%AE%E4%B8%BA%203000US%EF%BC%8C%E5%85%B7%E4%BD%93%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FP%3E%3CPRE%20translate%3D%22no%22%3Ereq-%26gt%3Bcontrols().set(libcamera%3A%3Acontrols%3A%3AAeEnable%2C%20false)%3B%3CBR%20%2F%3Ereq-%26gt%3Bcontrols().set(libcamera%3A%3Acontrols%3A%3AExposureTime%2C%203000)%3B%3CBR%20%2F%3Ereq-%26gt%3Bcontrols().set(libcamera%3A%3Acontrols%3A%3AAnalogueGain%2C%201.0)%3B%3C%2FPRE%3E%3CP%3E%E4%B8%8D%E8%BF%87%EF%BC%8CLibcamera%20%E8%B0%83%E8%AF%95%E6%97%A5%E5%BF%97%E4%BC%BC%E4%B9%8E%E6%98%BE%E7%A4%BA%E5%A2%9E%E7%9B%8A%2F%E6%9B%9D%E5%85%89%E5%80%BC%E6%98%AF%E9%80%9A%E8%BF%87%20NXP%20NEO%20AGC%20%E8%AE%A1%E7%AE%97%E5%80%BC%E8%AE%BE%E7%BD%AE%E7%9A%84%E3%80%82%E4%BD%A0%E8%83%BD%E5%BB%BA%E8%AE%AE%E5%A6%82%E4%BD%95%E9%80%9A%E8%BF%87Libcamera%20API%E6%AD%A3%E7%A1%AE%E9%85%8D%E7%BD%AE%E6%89%8B%E5%8A%A8%E6%9B%9D%E5%85%89%E5%92%8C%E6%A8%A1%E6%8B%9F%E5%A2%9E%E7%9B%8A%E5%80%BC%E5%90%97%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2257658%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IM95%20Libcamera%20-%20Configure%20manual%20gain%2Fexposure%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2257658%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%E8%AE%BE%E7%BD%AE%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22prismjs%20css-nc0a95%22%20data-code-lang%3D%22java%22%20data-ds--code--code-block%3D%22%22%3E%3CCODE%20class%3D%22language-java%22%20style%3D%22white-space%3A%20pre%3B%22%3E%3CSPAN%20class%3D%22%22%3E%E6%91%84%E5%83%8F%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E5%A4%B4%3C%2FSPAN%3E%3CSPAN%20class%3D%22token%20operator%22%3E%20--%20%E6%91%84%E5%83%8F%E6%9C%BA%3C%2FSPAN%3E%3CSPAN%20class%3D%22token%20operator%22%3E%20X%20--%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E7%9B%B4%E6%92%AD%E5%AE%BD%E5%BA%A6%3C%2FSPAN%3E%3CSPAN%20class%3D%22token%20operator%22%3E%20%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22token%20punctuation%22%3E%24%7B%3C%2FSPAN%3E%3CSPAN%20class%3D%22token%20class-name%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22token%20punctuation%22%3EW%7D%3C%2FSPAN%3E%3CSPAN%20class%3D%22token%20punctuation%22%3E%20%EF%BC%8C%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E9%AB%98%E5%BA%A6%3C%2FSPAN%3E%3CSPAN%20class%3D%22token%20operator%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22token%20punctuation%22%3E%20%24%7B%3C%2FSPAN%3E%3CSPAN%20class%3D%22token%20class-name%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22token%20punctuation%22%3EH%7D%3C%2FSPAN%3E%3CSPAN%20class%3D%22token%20punctuation%22%3E%20%EF%BC%8C%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E5%83%8F%E7%B4%A0%E6%A0%BC%E5%BC%8F%3C%2FSPAN%3E%3CSPAN%20class%3D%22token%20operator%22%3E%20%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20YUYV%3C%2FSPAN%3E%3CSPAN%20class%3D%22token%20operator%22%3E%20%E2%80%94%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E6%8D%95%E8%8E%B7%3C%2FSPAN%3E%3CSPAN%20class%3D%22token%20operator%22%3E%20%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22token%20number%22%3E%201000%3C%2FSPAN%3E%3CSPAN%20class%3D%22token%20operator%22%3E%20%E2%80%94%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E6%98%BE%E7%A4%BA%E5%99%A8%3C%2FSPAN%3E%3CSPAN%20class%3D%22token%20operator%22%3E%20%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20HDMI%3C%2FSPAN%3E%3CSPAN%20class%3D%22token%20operator%22%3E%20-%3C%2FSPAN%3E%3CSPAN%20class%3D%22token%20class-name%22%3E%20A%3C%2FSPAN%3E%3CSPAN%20class%3D%22token%20operator%22%3E%20-%3C%2FSPAN%3E%3CSPAN%20class%3D%22token%20number%22%3E%201%3C%2FSPAN%3E%3CSPAN%20class%3D%22token%20operator%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E2%80%94%20%E8%84%9A%E6%9C%AC%20script_gain_exposure%E3%80%82%3C%2FSPAN%3E%3CSPAN%20class%3D%22token%20punctuation%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Eyaml%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2257406%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IM95%20Libcamera%20-%20Configure%20manual%20gain%2Fexposure%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2257406%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Flibcamera%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E4%BD%9C%E4%B8%BA%E5%8F%82%E8%80%83%EF%BC%8C%E8%BF%99%E6%98%AF%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E7%9A%84%20Libcamera%20%E7%89%88%E6%9C%AC%EF%BC%9Ahttps%3A%2F%2Fgithub.com%2Fnxp-imx%2Flibcamera%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2258286%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IM95%20Libcamera%20-%20Configure%20manual%20gain%2Fexposure%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2258286%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8Cjoanxie%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E8%AE%A4%E4%B8%BA%E6%88%91%E9%9C%80%E8%A6%81%E9%80%9A%E8%BF%87%20Libcamera%20API%20%E4%BB%A5%E7%BC%96%E7%A8%8B%E6%96%B9%E5%BC%8F%E6%9B%B4%E6%94%B9%E5%A2%9E%E7%9B%8A%2F%E6%9B%9D%E5%85%89%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%E4%BD%BF%E7%94%A8%20%60cam%60%20%E5%B7%A5%E5%85%B7%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2258654%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IM95%20Libcamera%20-%20Configure%20manual%20gain%2Fexposure%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2258654%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%87%B8%E8%BD%AE%E8%BF%98%E4%BD%BF%E7%94%A8%20libcamera%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%20Linux%20%E7%94%A8%E6%88%B7%E6%8C%87%E5%8D%97%EF%BC%8CLibcamera%20%E9%99%84%E5%B8%A6%E7%9A%84%E5%87%B8%E8%BD%AE%E6%B5%8B%E8%AF%95%E7%A8%8B%E5%BA%8F%E4%BD%BF%E7%94%A8%E6%9C%AC%E5%9C%B0%20libcamera%20API%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2259325%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IM95%20Libcamera%20-%20Configure%20manual%20gain%2Fexposure%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2259325%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E7%90%BC%E8%A5%BF%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%E5%87%B8%E8%BD%AE%E5%B7%A5%E5%85%B7%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%B5%81%E5%BC%8F%E4%BC%A0%E8%BE%93%EF%BC%8C%E4%BD%86%E5%9C%A8%20libcamera%20%E6%97%A5%E5%BF%97%E4%B8%AD%E7%9C%8B%E5%88%B0%E4%BA%86%E4%B8%80%E4%BA%9B%E4%B8%8D%E4%B8%80%E8%87%B4%E7%9A%84%E7%BB%93%E6%9E%9C%E3%80%82%E6%97%A5%E5%BF%97%E6%98%BE%E7%A4%BA%E6%AD%A3%E5%9C%A8%E5%BA%94%E7%94%A8%E4%BB%A5%E4%B8%8B%E9%85%8D%E7%BD%AE%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CPRE%20translate%3D%22no%22%3E%5B0%3A17%3A10.346165015%5D%20%5B2328%5D%20DEBUG%20NxpNeoAlgoAgc%20agc.cpp%3A193%20Set%20exposure%20to%20712%3C%2FPRE%3E%3CPRE%20translate%3D%22no%22%3E%5B0%3A17%3A09.504320639%5D%20%5B2321%5D%20DEBUG%20NxpNeoAlgoGoc%20goc.cpp%3A185%20%5BxferFunc%5D%20linearGain%3A%2012.92%2C%20linearThreshold%3A%200.0031308%2C%20nonLinearGain%3A%201.055%2C%20nonLinearOffset%3A%200.0521327%2C%20gammaInverse%3A%200.416667%3C%2FPRE%3E%3CPRE%20translate%3D%22no%22%3E%5B0%3A17%3A07.826928461%5D%20%5B2321%5D%20DEBUG%20NxpNeoAlgoDrc%20drc.cpp%3A654%20global%20GAIN%3D256%3C%2FPRE%3E%3CPRE%20translate%3D%22no%22%3E%5B0%3A17%3A10.346186099%5D%20%5B2328%5D%20DEBUG%20NxpNeoAlgoAgc%20agc.cpp%3A201%20Set%20gain%20to%201%3C%2FPRE%3E%3CP%3E%E8%BF%99%E4%BA%9B%E9%85%8D%E7%BD%AE%E4%B8%8E%20YAML%20%E6%96%87%E4%BB%B6%E4%B8%AD%E7%9A%84%E9%85%8D%E7%BD%AE%E4%B8%8D%E4%B8%80%E8%87%B4%E3%80%82%E6%9C%AC%E9%82%AE%E4%BB%B6%E8%BF%98%E5%8C%85%E5%90%AB%E5%AE%8C%E6%95%B4%E7%9A%84%E6%97%A5%E5%BF%97%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2262310%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IM95%20Libcamera%20-%20Configure%20manual%20gain%2Fexposure%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2262310%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E7%94%A8%E6%88%91%E7%9A%84%20imx95%20evk%20%E6%9D%BF%E6%B5%8B%E8%AF%95%E4%BA%86%20os08a20%EF%BC%8C%E5%91%BD%E4%BB%A4%E6%98%AF%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22joanxie_2-1765781362281.png%22%20style%3D%22width%3A%20622px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22joanxie_2-1765781362281.png%22%20style%3D%22width%3A%20622px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F369862iE355E1F76A67A80E%2Fimage-dimensions%2F622x131%3Fv%3Dv2%22%20width%3D%22622%22%20height%3D%22131%22%20role%3D%22button%22%20title%3D%22joanxie_2-1765781362281.png%22%20alt%3D%22joanxie_2-1765781362281.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%88%91%E7%9A%84%E8%84%9A%E6%9C%AC%E6%98%AF%20%3C%2FP%3E%0A%3CDIV%20style%3D%22color%3A%20%233b3b3b%3B%20background-color%3A%20%23ffffff%3B%20font-family%3A%20Consolas%2C%20'Courier%20New'%2C%20monospace%3B%20font-weight%3A%20normal%3B%20font-size%3A%2014px%3B%20line-height%3A%2019px%3B%20white-space%3A%20pre%3B%22%3E%0A%3CDIV%3E%3CSPAN%3E%E9%95%9C%E6%9E%B6%3C%2FSPAN%3E%3CSPAN%3E%3A%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3E%20%20-%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3A%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3EAeEnable%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3Efalse%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E6%A8%A1%E6%8B%9F%E5%A2%9E%E7%9B%8A%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E1.0000000%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E6%9B%9D%E5%85%89%E6%97%B6%E9%97%B4%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E10000%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3E%20%20-%20%3C%2FSPAN%3E%3CSPAN%3E10%3C%2FSPAN%3E%3CSPAN%3E%3A%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3EAeEnable%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3Efalse%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E6%A8%A1%E6%8B%9F%E5%A2%9E%E7%9B%8A%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E5.0000000%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E6%9B%9D%E5%85%89%E6%97%B6%E9%97%B4%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E60000%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3E%20%20-%20%3C%2FSPAN%3E%3CSPAN%3E20%3C%2FSPAN%3E%3CSPAN%3E%3A%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3EAeEnable%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3Efalse%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E6%A8%A1%E6%8B%9F%E5%A2%9E%E7%9B%8A%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E1.0000000%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E6%9B%9D%E5%85%89%E6%97%B6%E9%97%B4%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E10000%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3E%20%20-%20%3C%2FSPAN%3E%3CSPAN%3E30%3C%2FSPAN%3E%3CSPAN%3E%3A%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3EAeEnable%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3Efalse%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E6%A8%A1%E6%8B%9F%E5%A2%9E%E7%9B%8A%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E5.0000000%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E6%9B%9D%E5%85%89%E6%97%B6%E9%97%B4%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E60000%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3E%20%20-%20%3C%2FSPAN%3E%3CSPAN%3E40%3C%2FSPAN%3E%3CSPAN%3E%3A%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3EAeEnable%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3Efalse%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E6%A8%A1%E6%8B%9F%E5%A2%9E%E7%9B%8A%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E1.0000000%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E6%9B%9D%E5%85%89%E6%97%B6%E9%97%B4%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E10000%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3E%20%20-%20%3C%2FSPAN%3E%3CSPAN%3E50%3C%2FSPAN%3E%3CSPAN%3E%3A%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3EAeEnable%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3Efalse%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E6%A8%A1%E6%8B%9F%E5%A2%9E%E7%9B%8A%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E5.0000000%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E6%9B%9D%E5%85%89%E6%97%B6%E9%97%B4%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E60000%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3E%20%20-%20%3C%2FSPAN%3E%3CSPAN%3E100%3C%2FSPAN%3E%3CSPAN%3E%3A%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3EAeEnable%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3Efalse%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E6%A8%A1%E6%8B%9F%E5%A2%9E%E7%9B%8A%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E1.0000000%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E6%9B%9D%E5%85%89%E6%97%B6%E9%97%B4%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E10000%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3E%E6%97%A5%E5%BF%97%E6%96%87%E4%BB%B6%E6%98%AF%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22joanxie_3-1765781419198.png%22%20style%3D%22width%3A%20520px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22joanxie_3-1765781419198.png%22%20style%3D%22width%3A%20520px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F369865i2812BF86E2EB53CC%2Fimage-dimensions%2F520x268%3Fv%3Dv2%22%20width%3D%22520%22%20height%3D%22268%22%20role%3D%22button%22%20title%3D%22joanxie_3-1765781419198.png%22%20alt%3D%22joanxie_3-1765781419198.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%0A%3CBR%20%2F%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22joanxie_4-1765781457410.png%22%20style%3D%22width%3A%20521px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22joanxie_4-1765781457410.png%22%20style%3D%22width%3A%20521px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F369866i2AEAA76A5BFF0075%2Fimage-dimensions%2F521x194%3Fv%3Dv2%22%20width%3D%22521%22%20height%3D%22194%22%20role%3D%22button%22%20title%3D%22joanxie_4-1765781457410.png%22%20alt%3D%22joanxie_4-1765781457410.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22joanxie_5-1765781509305.png%22%20style%3D%22width%3A%20522px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22joanxie_5-1765781509305.png%22%20style%3D%22width%3A%20522px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F369867i9C992DD3B8114891%2Fimage-dimensions%2F522x187%3Fv%3Dv2%22%20width%3D%22522%22%20height%3D%22187%22%20role%3D%22button%22%20title%3D%22joanxie_5-1765781509305.png%22%20alt%3D%22joanxie_5-1765781509305.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E7%BB%93%E6%9E%9C%E4%B8%8E%E8%AE%BE%E7%BD%AE%E7%9B%B8%E5%90%8C%EF%BC%8C%E4%BD%86%E6%88%91%E5%8F%91%E7%8E%B0%E5%AE%83%E6%9C%89%204%20%E5%B8%A7%E5%BB%B6%E8%BF%9F%EF%BC%8C%E5%86%85%E9%83%A8%E5%9B%A2%E9%98%9F%E4%BB%8D%E5%9C%A8%E5%AF%B9%E6%AD%A4%E8%BF%9B%E8%A1%8C%E8%B0%83%E6%9F%A5%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
