IM8QXP
IM8QXP
4,213件の閲覧回数
shalanyang
hello ,
1.I want to use call watchdog function in imx8qxp kernel, where function should I use ?could you tell me?
 2. I want to know some more detail information power and PMIC ,could you send me some doc ?
 tks!
ラベル(2)
3 返答(返信)
4,011件の閲覧回数
shalanyang
I just know that when use echo c > /proc/sysrq-trigger, it will cause kernel panic in IMX8QXP target board. I want to use the watchdog to restart system. How can I enable it and use it? tks!
4,011件の閲覧回数
joanxie
1)for watchdog, pls refe to the chapter 2.11 Watchdog (WDOG) of enclosed file
2) for power consumption, pls refer to the application note as below:
https://www.nxp.com/docs/en/application-note/AN12338.pdf
4,011件の閲覧回数
shalanyang
thanks,I try it@
