IDE used for Android OS for imx8m mini
1,986件の閲覧回数
Ruban1
IDE used for Android OS for imx8m mini.
How to configure the GPIO pins using Android OS  for imx8m mini .Required Steps and documents
1,976件の閲覧回数
IvanRuiz
For Android, there is rather a BSP where you can set what you require for your specific use case. Please refer to the embedded software section for the Android source available in the following link: https://www.nxp.com/design/development-boards/i-mx-evaluation-and-development-boards/evaluation-kit-...
Hope it helps!
BR,
Ivan.
