I2S support on RT595 (249FOW LP)
ソリューションへジャンプ
1,657件の閲覧回数
johnstephanou
Under "Flexcomm Interface" in table 53 / pg 78 of the IMXRT500EC doc, it says that FC6 and FC7 support I2S functions. Is there a reason these two are called out specifically? Are they somehow different than I2S on FC0, FC1, FC2 or FC4?
1,630件の閲覧回数
kerryzhou
Hi @johnstephanou ,
 Seems your datasheet is old, please check the newest datasheet:
https://www.nxp.com/docs/en/data-sheet/IMXRT500EC.pdf
 Whether you still find the FC6 and FC7 are called out specifically?
  In fact, the FC6, FC7 to I2S is no special:
Wish it helps you!
kerry
2 返答(返信)
1,617件の閲覧回数
johnstephanou
Thank you Kerry
1,631件の閲覧回数
kerryzhou
Hi @johnstephanou ,
Wish it helps you!
kerry
