I2C EEPROM
I2C EEPROM
2,678件の閲覧回数
ksaiviswanadhul
I'm using imx8qmmek board. i'm working on i2c eeprom.. i am able to write and read 256 bytes to eeprom  i'm trying to write more-than 256 bytes not able to write. For above 256 bytes write and read any user space application required?
saikumar
4 返答(返信)
2,668件の閲覧回数
Hi KUMAR
reason may be is that page size is 256 bytes, so it is necessary to set individual page
for write procedure.
2,651件の閲覧回数
ksaiviswanadhul
Hi igor,
Can u tell me how to write 256 bytes data from user space level. I'm using 24c02 eeprom.
saikumar
2,647件の閲覧回数
2,664件の閲覧回数
ksaiviswanadhul
Hi igor,
Correct I cross check the data sheet they mentioned 2k bits means 256 bytes
Saikumar
