I2C Driver
I2C Driver
4,210件の閲覧回数
RomanLehmann
Fresh Out Contributor
Where i can get a I2C-Driver for the i.mx53 QSB?
タグ(1)
7 返答(返信)
3,958件の閲覧回数
RomanLehmann
Is it possible to send something to the VGA I2C Bus like this: echo "Test" > ttyS0 But instead of ttyS0 to use the VGA I2C. If it would work like this it would enough for me. I just want to send some bits over the VGA-Port and to see this with my I2C tracer. Anyone a Idea?
3,958件の閲覧回数
RomanLehmann
I have a USB to I2C Tracer http://www.avitresearch.co.uk/i2c_bus_products.htm Now I wont to send something over the I2C-Bus at the VGA Port and to see with the Tracer if there is comes the same Massage that I send.
3,958件の閲覧回数
fabio_estevam
The installation and usage procedure are in the link I sent you earlier.
I haven´t understood your last question regarding I2C and VGA port.
Fabio Estevam
3,958件の閲覧回数
RomanLehmann
Can you tell me how to install and to use this tool or were i can find a instruction.
An other question is.
How can I send something over the I2C-Bus so that I can measure the signal on the VGA-Port?
3,958件の閲覧回数
fabio_estevam
If you use a FSL kernel the I2C driver is located at:
drivers/i2c/busses/mxc_i2c.c
On a mainline kernel the I2C driver is located at:
drivers/i2c/busses/i2c-imx.c
You can use this i2c utility in userspace to test I2C:
http://www.imxdev.org/wiki/index.php?title=All_Boards_I2C-tools
Fabio Estevam
3,958件の閲覧回数
RomanLehmann
My Job is to test the I2C-Bus.
I just want to send something over the I2C Bus and measuring the signals with an oscilloscope. I need to do this for my final examination. But at the time i don't know how to do this.
Maybe you got an Idea.
3,958件の閲覧回数
daiane_angolini
at imx53 QSB kernel
What do you really want to do?
