I can't switch ON the bluetooth via GUI
4,343 次查看
ayyappadasps
I am working with IMX6SLEVK RTL8723BU (Android Kitkat 4.4.3) and this module for bluetooth and wifi, first I worked on bluetooth thast time bluetooth is perfectly worked, next I worked with wifi its also woked fine, then I integrated bot of them now wifi is working but bluetooth is not working, even I can't switch ON the bluetooth  in GUI. And I mention the log below I f anybody know mean help me to clear this problem..
U-Boot 2014.04-08641-g177af288fb-dirty (Feb 22 2018 - 19:23:53)
CPU:   Freescale i.MX6SL rev1.2 at 792 MHz
CPU:   Temperature 41 C, calibration data: 0x58b50169
Reset cause: POR
Board: MX6SLEVK
I2C:   ready
DRAM:  512 MiB
Initialized Hx8357 LCD device
MMC:   FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2
*** Warning - bad CRC, using default environment
In:    serial
Out:   serial
Err:   serial
Found PFUZE100 deviceid=10,revid=11
Detecting VOL_DOWN+POWER key for recovery(0:0) ...
check_and_clean: reg 0, flag_set 0
Fastboot: Normal
flash target is MMC:1
Net:   FEC [PRIME]
Warning: failed to set MAC address
Normal Boot
Hit any key to stop autoboot:  0
booti mmc1
kernel   @ 80808000 (6788064)
ramdisk  @ 81800000 (527792)
fdt      @ 81700000 (35045)
kernel cmdline:
        use boot.img command line:
        console=ttymxc0,115200 init=/init androidboot.console=ttymxc0 consoleblank=0 androidboot.hardware=freescale androidboot.serialno=293279d4df67dd9c
switch to ldo_bypass mode!
   Using Device Tree in place at 81700000, end 8170b8e4
Starting kernel ...
Booting Linux on physical CPU 0x0
Initializing cgroup subsys cpu
Initializing cgroup subsys cpuacct
Linux version 3.10.53-88102-gbcffb04abae1-dirty (zumi@zumi-Fujitsu) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #15 SMP PREEMPT Sat Mar 24 12:52:39 IST 2018
CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: Freescale i.MX6 SoloLite (Device Tree), model: Freescale i.MX6 SoloLite EVK Board(PFUZE100)
cma: CMA: reserved 256 MiB at 8a000000
Memory policy: ECC disabled, Data cache writealloc
PERCPU: Embedded 8 pages/cpu @813ef000 s9728 r8192 d14848 u32768
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 129792
Kernel command line: console=ttymxc0,115200 init=/init androidboot.console=ttymxc0 consoleblank=0 androidboot.hardware=freescale androidboot.serialno=293279d4df67dd9c
PID hash table entries: 2048 (order: 1, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 447MB 64MB = 511MB total
Memory: 239192k/239192k available, 285096k reserved, 0K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    vmalloc : 0xa0800000 - 0xff000000   (1512 MB)
    lowmem  : 0x80000000 - 0xa0000000   ( 512 MB)
    pkmap   : 0x7fe00000 - 0x80000000   (   2 MB)
    modules : 0x7f000000 - 0x7fe00000   (  14 MB)
      .text : 0x80008000 - 0x80e6efe4   (14748 kB)
      .init : 0x80e6f000 - 0x80ec4600   ( 342 kB)
      .data : 0x80ec6000 - 0x80f49000   ( 524 kB)
       .bss : 0x80f49000 - 0x80fddbbc   ( 595 kB)
SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Preemptible hierarchical RCU implementation.
        RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
NR_IRQS:16 nr_irqs:16 16
L310 cache controller enabled
l2x0: 16 ways, CACHE_ID 0x410000c8, AUX_CTRL 0x32030000, Cache size: 262144 B
sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
Console: colour dummy device 80x30
Calibrating delay loop... 1581.05 BogoMIPS (lpj=7905280)
pid_max: default: 32768 minimum: 301
Security Framework initialized
SELinux:  Initializing.
Mount-cache hash table entries: 512
Initializing cgroup subsys debug
Initializing cgroup subsys freezer
CPU: Testing write buffer coherency: ok
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Setting up static identity map for 0x807d4180 - 0x807d41d8
Brought up 1 CPUs
SMP: Total of 1 processors activated (1581.05 BogoMIPS).
CPU: All CPU(s) started in SVC mode.
devtmpfs: initialized
pinctrl core: initialized pinctrl subsystem
regulator-dummy: no parameters
NET: Registered protocol family 16
DMA: preallocated 256 KiB pool for atomic coherent allocations
Use WDOG1 as reset source
syscon 20c8000.anatop: regmap [mem 0x020c8000-0x020c8fff] registered
vdd1p1: 800 <--> 1375 mV at 1125 mV
vdd3p0: 2800 <--> 3150 mV at 3000 mV
vdd2p5: 2100 <--> 2850 mV at 2525 mV
cpu: 725 <--> 1450 mV
vddpu: 725 <--> 1450 mV
vddsoc: 725 <--> 1450 mV
syscon 20e0000.iomuxc-gpr: regmap [mem 0x020e0000-0x020e0037] registered
syscon 21bc000.ocotp-ctrl: regmap [mem 0x021bc000-0x021bffff] registered
hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 4 bytes.
imx6sl-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
bio: create slab <bio-0> at 0
lcd-3v3: no parameters
wm8962-supply-3v15: 3150 mV
wm8962-supply-4v2: 4325 mV
usb_otg1_vbus: 5000 mV
usb_otg2_vbus: 5000 mV
i2c-core: driver [max17135] using legacy suspend method
i2c-core: driver [max17135] using legacy resume method
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
i2c i2c-0: Max17135 PMIC not found!
i2c i2c-0: IMX I2C adapter registered
i2c i2c-1: IMX I2C adapter registered
i2c i2c-2: IMX I2C adapter registered
Linux video capture interface: v2.00
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
PTP clock support registered
MIPI CSI2 driver module loaded
Advanced Linux Sound Architecture Driver Initialized.
Bluetooth: Core ver 2.17
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO socket layer initialized
pureg-dummy: no parameters
Switching to clocksource mxc_timer1
NET: Registered protocol family 2
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP: reno registered
UDP hash table entries: 256 (order: 1, 8192 bytes)
UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
Trying to unpack rootfs image as initramfs...
Freeing initrd memory: 512K (81800000 - 81880000)
hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
ldo2p5-dummy: no parameters
Bus freq driver module loaded
console [pstore-1] enabled
ramoops: attached 0x100000@0x9bf00000, ecc: 0/0
mxc_ramoops device success loaded
futex hash table entries: 256 (order: 2, 16384 bytes)
audit: initializing netlink socket (disabled)
type=2000 audit(0.240:1): initialized
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
NFS: Registering the id_resolver key type
Key type id_resolver registered
Key type id_legacy registered
NTFS driver 2.1.30 [Flags: R/W DEBUG].
jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
fuse init (API version 7.22)
msgmni has been set to 980
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
MIPI DSI driver module loaded
mxsfb 20f8000.lcdif: failed to find mxc display driver
Console: switching to colour frame buffer device 30x40
mxsfb 20f8000.lcdif: initialized
imx-sdma 20ec000.sdma: loaded firmware 1.1
imx-sdma 20ec000.sdma: initialized
pfuze100-regulator 0-0008: Full lay: 1, Metal lay: 1
pfuze100-regulator 0-0008: FAB: 0, FIN: 0
pfuze100-regulator 0-0008: pfuze100 found.
SW1AB: 300 <--> 1875 mV at 1175 mV
SW1C: 300 <--> 1875 mV at 1175 mV
SW2: 800 <--> 3300 mV at 3150 mV
SW3A: 400 <--> 1975 mV at 1200 mV
SW3B: 400 <--> 1975 mV at 1200 mV
SW4: 800 <--> 1975 mV at 1800 mV
SWBST: 5000 <--> 5150 mV at 5000 mV
VSNVS: 1000 <--> 3000 mV at 3000 mV
VREFDDR: 750 mV
VGEN1: 800 <--> 1550 mV at 1200 mV
VGEN2: 800 <--> 1550 mV at 800 mV
VGEN3: 1800 <--> 3300 mV at 1800 mV
VGEN4: 1800 <--> 3300 mV at 1800 mV
VGEN5: 1800 <--> 3300 mV at 2500 mV
VGEN6: 1800 <--> 3300 mV at 1800 mV
Serial: IMX driver
2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 58) is a IMX
console [ttymxc0] enabled
serial: Freescale lpuart driver
imx sema4 driver is registered.
[drm] Initialized drm 1.1.0 20060810
[drm] Initialized vivante 1.0.0 20120216 on minor 0
brd: module loaded
loop: module loaded
m25p80 spi32766.0: m25p32 (4096 Kbytes)
spi_imx 2008000.ecspi: probed
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
CAN device driver interface
fec 2188000.ethernet (unregistered net_device): Invalid MAC address: 00:00:00:00:00:00
fec 2188000.ethernet (unregistered net_device): Using random MAC address: 9a:c4:44:14:08:81
libphy: fec_enet_mii_bus: probed
PPP generic driver version 2.4.2
PPP BSD Compression module registered
PPP Deflate Compression module registered
PPP MPPE Compression module registered
NET: Registered protocol family 24
usbcore: registered new interface driver asix
usbcore: registered new interface driver ax88179_178a
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver net1080
usbcore: registered new interface driver cdc_subset
usbcore: registered new interface driver zaurus
usbcore: registered new interface driver cdc_ncm
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
usbcore: registered new interface driver cdc_acm
cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
usbcore: registered new interface driver usbserial
usbcore: registered new interface driver option
usbserial: USB Serial support registered for GSM modem (1-port)
ci_hdrc ci_hdrc.0: EHCI Host Controller
ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: EHCI Host Controller
usb usb1: Manufacturer: Linux 3.10.53-88102-gbcffb04abae1-dirty ehci_hcd
usb usb1: SerialNumber: ci_hdrc.0
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
ci_hdrc ci_hdrc.1: EHCI Host Controller
ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 2
ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: EHCI Host Controller
usb usb2: Manufacturer: Linux 3.10.53-88102-gbcffb04abae1-dirty ehci_hcd
usb usb2: SerialNumber: ci_hdrc.1
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
mousedev: PS/2 mouse device common for all mice
input: 20b8000.kpp as /devices/soc0/soc.2/2000000.aips-bus/20b8000.kpp/input/input0
usbcore: registered new interface driver xpad
usbcore: registered new interface driver usb_acecad
usbcore: registered new interface driver aiptek
usbcore: registered new interface driver gtco
usbcore: registered new interface driver hanwang
usbcore: registered new interface driver kbtab
usbcore: registered new interface driver wacom
elan-touch 0-0010: elan - Read Hello Packet Failed
elan-touch: probe of 0-0010 failed with error -22
mma8450 0-001c: read chip ID 0xfffffffb is not equal to 0xc6!
mma8450: probe of 0-001c failed with error -22
i2c-core: driver [isl29023] using legacy suspend method
i2c-core: driver [isl29023] using legacy resume method
snvs_rtc 20cc034.snvs-rtc-lp: rtc core: registered 20cc034.snvs-rtc-lp as rtc0
i2c /dev entries driver
ov5640 2-003c: cannot get io voltage
usb 1-1: new high-speed USB device number 2 using ci_hdrc
ov5640_read_reg:write reg error:reg=300a
camera ov5640 is not found
ov5642_power_on: cannot get io voltage error
usb 1-1: New USB device found, idVendor=214b, idProduct=7000
usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
usb 1-1: Product: USB2.0 HUB
hub 1-1:1.0: USB hub found
hub 1-1:1.0: 4 ports detected
ov5642_read_reg:write reg error:reg=300a
camera ov5642 is not found
pxp-v4l2 pxp_v4l2_out.24: initialized
usbcore: registered new interface driver uvcvideo
USB Video Class driver (1.1.1)
gspca_main: v2.14.0 registered
imx2-wdt 20bc000.wdog: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=0)
device-mapper: uevent: version 1.0.3
device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: [email protected]
Bluetooth: HCI UART driver ver 2.2
Bluetooth: HCIATH3K protocol initialized
usbcore: registered new interface driver btusb
cpuidle: using governor ladder
cpuidle: using governor menu
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
mmc0: no vqmmc regulator found
mmc0: no vmmc regulator found
mmc0: SDHCI controller on 2190000.usdhc [2190000.usdhc] using DMA
mmc1: no vqmmc regulator found
mmc1: no vmmc regulator found
mmc1: SDHCI controller on 2194000.usdhc [2194000.usdhc] using DMA
mmc2: no vqmmc regulator found
mmc2: no vmmc regulator found
mmc2: SDHCI controller on 2198000.usdhc [2198000.usdhc] using DMA
galcore: clk_get gpu3d_clk failed, disable 3d!
Galcore version 5.0.11.25762
mmc1: BKOPS_EN bit is not set
mmc1: switch to highspeed failed
mmc1: new MMC card at address 0001
mmcblk1: mmc1:0001 SEM08G 7.28 GiB
mmcblk1boot0: mmc1:0001 SEM08G partition 1 2.00 MiB
mmcblk1boot1: mmc1:0001 SEM08G partition 2 2.00 MiB
mmcblk1rpmb: mmc1:0001 SEM08G partition 3 2.00 MiB
 mmcblk1: p1 p2 p3 < p5 p6 p7 p8 > p4
mmcblk1: p4 size 13090816 extends beyond EOD, truncated
 mmcblk1boot1: unknown partition table
 mmcblk1boot0: unknown partition table
hidraw: raw HID events driver (C) Jiri Kosina
usbhid: USB HID core driver
ashmem: initialized
logger: created 256K log 'log_main'
logger: created 256K log 'log_events'
logger: created 256K log 'log_radio'
logger: created 256K log 'log_system'
usbcore: registered new interface driver snd-usb-audio
wm8962 1-001a: Failed to read ID register
wm8962: probe of 1-001a failed with error -5
imx-wm8962 sound.25: failed to find codec platform device
imx-wm8962: probe of sound.25 failed with error -22
imx-spdif sound-spdif.26:  dit-hifi <-> 2004000.spdif mapping ok
NET: Registered protocol family 26
u32 classifier
    Actions configured
Netfilter messages via NETLINK v0.30.
nf_conntrack version 0.5.0 (7841 buckets, 31364 max)
ctnetlink v0.93: registering with nfnetlink.
NF_TPROXY: Transparent proxy support initialized, version 4.1.0
NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
xt_time: kernel timezone is -0000
ip_tables: (C) 2000-2006 Netfilter Core Team
arp_tables: (C) 2002 David S. Miller
TCP: cubic registered
Initializing XFRM netlink socket
NET: Registered protocol family 10
mip6: Mobile IPv6
ip6_tables: (C) 2000-2006 Netfilter Core Team
NET: Registered protocol family 15
can: controller area network core (rev 20120528 abi 9)
NET: Registered protocol family 29
can: raw protocol (rev 20120528)
can: broadcast manager protocol (rev 20120528 t)
can: netlink gateway (rev 20130117) max_hops=1
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM ver 1.11
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: BNEP filters: protocol multicast
Bluetooth: BNEP socket layer initialized
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
Bluetooth: HIDP socket layer initialized
8021q: 802.1Q VLAN Support v1.8
lib80211: common routines for IEEE802.11 drivers
Key type dns_resolver registered
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
SWBST: disabling
SW4: disabling
wm8962-supply-4v2: disabling
wm8962-supply-3v15: disabling
regulator-dummy: disabling
imx mcc test is registered.
file system registered
android_usb gadget: Mass Storage Function, version: 2009/09/11
android_usb gadget: Number of LUNs=1
 lun0: LUN: removable file: (no medium)
android_usb gadget: android_usb ready
snvs_rtc 20cc034.snvs-rtc-lp: setting system clock to 1970-01-01 00:00:01 UTC (1)
ALSA device list:
  #0: imx-spdif
Freeing unused kernel memory: 340K (80e6f000 - 80ec4000)
SELinux:  Permission attach_queue in class tun_socket not defined in policy.
SELinux: the above unknown classes and permissions will be denied
type=1403 audit(1.660:2): policy loaded auid=4294967295 ses=4294967295
SELinux: Loaded policy from /sepolicy
type=1404 audit(1.670:3): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295
init: /init.rc: 303: invalid command 'echo'
init: /init.freescale.rc: 22: invalid command 'hciconfig'
init: /init.freescale.rc: 25: invalid command 'hciconfig'
init: /init.freescale.rc: 171: ignored duplicate definition of service 'dhcpcd_wlan0'
init: /init.freescale.rc: 176: ignored duplicate definition of service 'dhcpcd_p2p'
init: /init.freescale.rc: 181: ignored duplicate definition of service 'iprenew_wlan0'
init: /init.freescale.rc: 186: ignored duplicate definition of service 'iprenew_p2p'
init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
init: /dev/hw_random not found
keychord: using input dev 20b8000.kpp for fevent
init: cannot open '/initlogo.rle'
Console: switching to colour dummy device 80x30
EXT4-fs (mmcblk1p5): mounted filesystem with ordered data mode. Opts: (null)
EXT4-fs (mmcblk1p4): Ignoring removed nomblk_io_submit option
EXT4-fs (mmcblk1p4): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,noauto_da_alloc,errors=panic
EXT4-fs (mmcblk1p6): Ignoring removed nomblk_io_submit option
EXT4-fs (mmcblk1p6): mounted filesystem with ordered data mode. Opts: nomblk_io_submit
EXT4-fs (mmcblk1p7): mounted filesystem with ordered data mode. Opts: (null)
rtk_btusb: disagrees about version of symbol skb_put
rtk_btusb: Unknown symbol skb_put (err -22)
rtk_btusb: disagrees about version of symbol hci_free_dev
rtk_btusb: Unknown symbol hci_free_dev (err -22)
rtk_btusb: disagrees about version of symbol skb_dequeue
rtk_btusb: Unknown symbol skb_dequeue (err -22)
rtk_btusb: disagrees about version of symbol sock_create
rtk_btusb: Unknown symbol sock_create (err -22)
rtk_btusb: disagrees about version of symbol kfree_skb
rtk_btusb: Unknown symbol kfree_skb (err -22)
rtk_btusb: disagrees about version of symbol __alloc_skb
rtk_btusb: Unknown symbol __alloc_skb (err -22)
rtk_btusb: disagrees about version of symbol skb_queue_tail
rtk_btusb: Unknown symbol skb_queue_tail (err -22)
rtk_btusb: disagrees about version of symbol hci_alloc_dev
rtk_btusb: Unknown symbol hci_alloc_dev (err -22)
rtk_btusb: disagrees about version of symbol sock_sendmsg
rtk_btusb: Unknown symbol sock_sendmsg (err -22)
rtk_btusb: disagrees about version of symbol skb_queue_purge
rtk_btusb: Unknown symbol skb_queue_purge (err -22)
rtk_btusb: disagrees about version of symbol hci_unregister_dev
rtk_btusb: Unknown symbol hci_unregister_dev (err -22)
rtk_btusb: disagrees about version of symbol sock_release
rtk_btusb: Unknown symbol sock_release (err -22)
rtk_btusb: disagrees about version of symbol hci_recv_fragment
rtk_btusb: Unknown symbol hci_recv_fragment (err -22)
rtk_btusb: disagrees about version of symbol hci_register_dev
rtk_btusb: Unknown symbol hci_register_dev (err -22)
cfg80211: Calling CRDA to update world regulatory domain
type=1400 audit(4.590:4): avc:  denied  { entrypoint } for  pid=115 comm="init" path="/sbin/healthd" dev="rootfs" ino=234 scontext=u:r:healthd:s0 tcontext=u:object_r:rootfs:s0 tclass=file permissive=1
init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
healthd: BatteryTemperaturePath not found
healthd: BatteryTechnologyPath not found
binder: 115:115 transaction failed 29189, size 0-0
init: using deprecated syntax for specifying property 'ro.serialno', use ${name} instead
init: using deprecated syntax for specifying property 'ro.product.manufacturer', use ${name} instead
init: using deprecated syntax for specifying property 'ro.product.model', use ${name} instead
init: property 'sys.powerctl' doesn't exist while expanding '${sys.powerctl}'
init: powerctl: cannot expand '${sys.powerctl}'
init: property 'sys.sysctl.extra_free_kbytes' doesn't exist while expanding '${sys.sysctl.extra_free_kbytes}'
init: cannot expand '${sys.sysctl.extra_free_kbytes}' while writing to '/proc/sys/vm/extra_free_kbytes'
android_usb: already disabled
mtp_bind_config
root@evk_6sl:/ # EXT4-fs (mmcblk1p7): re-mounted. Opts: (null)
csi_v4l_open: Internal error, camera is not found!
mmcblk1: error -84 transferring data, sector 372377, nr 128, cmd response 0x900, card status 0x800b00
mmcblk1: retrying using single block read
warning: `zygote' uses 32-bit capabilities (legacy support in use)
root@evk_6sl:/ #
root@evk_6sl:/ #
root@evk_6sl:/ # request_suspend_state: wakeup (3->0) at 50127175505 (1970-01-02 00:00:16.897847043 UTC)
mmcblk1: error -110 sending stop command, original cmd response 0x900, card status 0xc00900
mmcblk1: error -84 transferring data, sector 140305, nr 32, cmd response 0x900, card status 0x0
echo "sf" > /sys/power/wake_locklowmemorykiller: lowmem_shrink: convert oom_adj to oom_score_adj:
lowmemorykiller: oom_adj 0 => oom_score_adj 0
lowmemorykiller: oom_adj 1 => oom_score_adj 58
lowmemorykiller: oom_adj 2 => oom_score_adj 117
lowmemorykiller: oom_adj 3 => oom_score_adj 176
lowmemorykiller: oom_adj 9 => oom_score_adj 529
lowmemorykiller: oom_adj 15 => oom_score_adj 1000
fec 2188000.ethernet eth0: Freescale FEC PHY driver [Generic PHY] (mii_bus:phy_addr=2188000.ethernet:00, irq=-1)
IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
acc_open
acc_release
root@evk_6sl:/ # echo "sf" > /sys/power/wake_lock
root@evk_6sl:/ # usb 1-1.1: new high-speed USB device number 3 using ci_hdrc
usb 1-1.1: New USB device found, idVendor=214b, idProduct=7000
usb 1-1.1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
usb 1-1.1: Product: USB2.0 HUB
hub 1-1.1:1.0: USB hub found
hub 1-1.1:1.0: 4 ports detected
usb 1-1.3: new high-speed USB device number 4 using ci_hdrc
usb 1-1.3: New USB device found, idVendor=0bda, idProduct=b720
usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
usb 1-1.3: Product: 802.11n WLAN Adapter
usb 1-1.3: Manufacturer: Realtek
usb 1-1.3: SerialNumber: 00e04c000001
usb 1-1.1.4: new low-speed USB device number 5 using ci_hdrc
usb 1-1.1.4: New USB device found, idVendor=275d, idProduct=0ba6
usb 1-1.1.4: New USB device strings: Mfr=0, Product=1, SerialNumber=0
usb 1-1.1.4: Product: USB OPTICAL MOUSE
input: USB OPTICAL MOUSE  as /devices/soc0/soc.2/2100000.aips-bus/2184000.usb/ci_hdrc.0/usb1/1-1/1-1.1/1-1.1.4/1-1.1.4:1.0/input/input1
hid-generic 0003:275D:0BA6.0001: input,hidraw0: USB HID v1.11 Mouse [USB OPTICAL MOUSE ] on usb-ci_hdrc.0-1.1.4/input0
init: sys_prop: permission denied uid:1003  name:service.bootanim.exit
root@evk_6sl:/ #
root@evk_6sl:/ #
root@evk_6sl:/ # am start -a android.settings.SETTINGS
Starting: Intent { act=android.settings.SETTINGS }
root@evk_6sl:/ # RTL871X: module init start
RTL871X: rtl8723bu v4.3.6.11_12942.20141204_BTCOEX20140507-4E40
RTL871X: rtl8723bu BT-Coex version = BTCOEX20140507-4E40
RTL871X: rtw_ndev_init(wlan0)
RTL871X: rtw_ndev_init(p2p0)
usbcore: registered new interface driver rtl8723bu
RTL871X: module init ret=0
RTL871X: RTW_ADAPTIVITY_EN_AUTO, chplan:0x20, Regulation:3,3
RTL871X: RTW_ADAPTIVITY_MODE_NORMAL
IPv6: ADDRCONF(NETDEV_UP): p2p0: link is not ready
IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
RTL871X: nolinked power save enter
RTL871X: nolinked power save leave
root@evk_6sl:/ #
root@evk_6sl:/ #
root@evk_6sl:/ #
root@evk_6sl:/ # dmesg
<6>Booting Linux on physical CPU 0x0
<6>Initializing cgroup subsys cpu
<6>Initializing cgroup subsys cpuacct
<5>Linux version 3.10.53-88102-gbcffb04abae1-dirty (zumi@zumi-Fujitsu) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #15 SMP PREEMPT Sat Mar 24 12:52:39 IST 2018
<4>CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
<4>CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
<6>Machine: Freescale i.MX6 SoloLite (Device Tree), model: Freescale i.MX6 SoloLite EVK Board(PFUZE100)
<6>cma: CMA: reserved 256 MiB at 8a000000
<4>Memory policy: ECC disabled, Data cache writealloc
<7>On node 0 totalpages: 130816
<7>free_area_init_node: node 0, pgdat 80f47ac0, node_mem_map 80fde000
<7>  DMA zone: 1024 pages used for memmap
<7>  DMA zone: 0 pages reserved
<7>  DMA zone: 130816 pages, LIFO batch:31
<6>PERCPU: Embedded 8 pages/cpu @813ef000 s9728 r8192 d14848 u32768
<7>pcpu-alloc: s9728 r8192 d14848 u32768 alloc=8*4096
<7>pcpu-alloc: [0] 0
<4>Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 129792
<5>Kernel command line: console=ttymxc0,115200 init=/init androidboot.console=ttymxc0 consoleblank=0 androidboot.hardware=freescale androidboot.serialno=293279d4df67dd9c
<6>PID hash table entries: 2048 (order: 1, 8192 bytes)
<6>Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
<6>Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
<6>Memory: 447MB 64MB = 511MB total
<5>Memory: 239192k/239192k available, 285096k reserved, 0K highmem
<5>Virtual kernel memory layout:
<5>    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
<5>    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
<5>    vmalloc : 0xa0800000 - 0xff000000   (1512 MB)
<5>    lowmem  : 0x80000000 - 0xa0000000   ( 512 MB)
<5>    pkmap   : 0x7fe00000 - 0x80000000   (   2 MB)
<5>    modules : 0x7f000000 - 0x7fe00000   (  14 MB)
<5>      .text : 0x80008000 - 0x80e6efe4   (14748 kB)
<5>      .init : 0x80e6f000 - 0x80ec4600   ( 342 kB)
<5>      .data : 0x80ec6000 - 0x80f49000   ( 524 kB)
<5>       .bss : 0x80f49000 - 0x80fddbbc   ( 595 kB)
<6>SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
<6>Preemptible hierarchical RCU implementation.
<6>     RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
<6>NR_IRQS:16 nr_irqs:16 16
<6>L310 cache controller enabled
<6>l2x0: 16 ways, CACHE_ID 0x410000c8, AUX_CTRL 0x32030000, Cache size: 262144 B
<6>sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
<6>Console: colour dummy device 80x30
<6>Calibrating delay loop... 1581.05 BogoMIPS (lpj=7905280)
<6>pid_max: default: 32768 minimum: 301
<6>Security Framework initialized
<6>SELinux:  Initializing.
<7>SELinux:  Starting in permissive mode
<6>Mount-cache hash table entries: 512
<6>Initializing cgroup subsys debug
<6>Initializing cgroup subsys freezer
<6>CPU: Testing write buffer coherency: ok
<6>CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
<6>Setting up static identity map for 0x807d4180 - 0x807d41d8
<6>Brought up 1 CPUs
<6>SMP: Total of 1 processors activated (1581.05 BogoMIPS).
<6>CPU: All CPU(s) started in SVC mode.
<6>devtmpfs: initialized
<6>pinctrl core: initialized pinctrl subsystem
<6>regulator-dummy: no parameters
<6>NET: Registered protocol family 16
<6>DMA: preallocated 256 KiB pool for atomic coherent allocations
<6>Use WDOG1 as reset source
<6>syscon 20c8000.anatop: regmap [mem 0x020c8000-0x020c8fff] registered
<6>vdd1p1: 800 <--> 1375 mV at 1125 mV
<6>vdd3p0: 2800 <--> 3150 mV at 3000 mV
<6>vdd2p5: 2100 <--> 2850 mV at 2525 mV
<6>cpu: 725 <--> 1450 mV
<6>vddpu: 725 <--> 1450 mV
<6>vddsoc: 725 <--> 1450 mV
<6>syscon 20e0000.iomuxc-gpr: regmap [mem 0x020e0000-0x020e0037] registered
<6>syscon 21bc000.ocotp-ctrl: regmap [mem 0x021bc000-0x021bffff] registered
<6>hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
<6>hw-breakpoint: maximum watchpoint size is 4 bytes.
<6>imx6sl-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
<6>bio: create slab <bio-0> at 0
<6>lcd-3v3: no parameters
<6>wm8962-supply-3v15: 3150 mV
<6>wm8962-supply-4v2: 4325 mV
<6>usb_otg1_vbus: 5000 mV
<6>usb_otg2_vbus: 5000 mV
<4>i2c-core: driver [max17135] using legacy suspend method
<4>i2c-core: driver [max17135] using legacy resume method
<5>SCSI subsystem initialized
<7>libata version 3.00 loaded.
<6>usbcore: registered new interface driver usbfs
<6>usbcore: registered new interface driver hub
<6>usbcore: registered new device driver usb
<3>i2c i2c-0: Max17135 PMIC not found!
<6>i2c i2c-0: IMX I2C adapter registered
<6>i2c i2c-1: IMX I2C adapter registered
<6>i2c i2c-2: IMX I2C adapter registered
<6>Linux video capture interface: v2.00
<6>pps_core: LinuxPPS API ver. 1 registered
<6>pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
<6>PTP clock support registered
<6>MIPI CSI2 driver module loaded
<6>Advanced Linux Sound Architecture Driver Initialized.
<6>Bluetooth: Core ver 2.17
<6>NET: Registered protocol family 31
<6>Bluetooth: HCI device and connection manager initialized
<6>Bluetooth: HCI socket layer initialized
<6>Bluetooth: L2CAP socket layer initialized
<6>Bluetooth: SCO socket layer initialized
<6>pureg-dummy: no parameters
<6>Switching to clocksource mxc_timer1
<6>NET: Registered protocol family 2
<6>TCP established hash table entries: 4096 (order: 3, 32768 bytes)
<6>TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
<6>TCP: Hash tables configured (established 4096 bind 4096)
<6>TCP: reno registered
<6>UDP hash table entries: 256 (order: 1, 8192 bytes)
<6>UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
<6>RPC: Registered named UNIX socket transport module.
<6>RPC: Registered udp transport module.
<6>RPC: Registered tcp transport module.
<6>RPC: Registered tcp NFSv4.1 backchannel transport module.
<6>Trying to unpack rootfs image as initramfs...
<6>Freeing initrd memory: 512K (81800000 - 81880000)
<6>hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
<6>ldo2p5-dummy: no parameters
<6>Bus freq driver module loaded
<6>console [pstore-1] enabled
<6>ramoops: attached 0x100000@0x9bf00000, ecc: 0/0
<6>mxc_ramoops device success loaded
<6>futex hash table entries: 256 (order: 2, 16384 bytes)
<6>audit: initializing netlink socket (disabled)
<5>type=2000 audit(0.240:1): initialized
<5>VFS: Disk quotas dquot_6.5.2
<4>Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
<5>NFS: Registering the id_resolver key type
<5>Key type id_resolver registered
<5>Key type id_legacy registered
<6>NTFS driver 2.1.30 [Flags: R/W DEBUG].
<6>jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
<6>fuse init (API version 7.22)
<6>msgmni has been set to 980
<7>SELinux:  Registering netfilter hooks
<6>io scheduler noop registered
<6>io scheduler deadline registered
<6>io scheduler cfq registered (default)
<6>MIPI DSI driver module loaded
<6>mxsfb 20f8000.lcdif: failed to find mxc display driver
<6>Console: switching to colour frame buffer device 30x40
<6>mxsfb 20f8000.lcdif: initialized
<6>imx-sdma 20ec000.sdma: loaded firmware 1.1
<6>imx-sdma 20ec000.sdma: initialized
<6>pfuze100-regulator 0-0008: Full lay: 1, Metal lay: 1
<6>pfuze100-regulator 0-0008: FAB: 0, FIN: 0
<6>pfuze100-regulator 0-0008: pfuze100 found.
<6>SW1AB: 300 <--> 1875 mV at 1175 mV
<6>SW1C: 300 <--> 1875 mV at 1175 mV
<6>SW2: 800 <--> 3300 mV at 3150 mV
<6>SW3A: 400 <--> 1975 mV at 1200 mV
<6>SW3B: 400 <--> 1975 mV at 1200 mV
<6>SW4: 800 <--> 1975 mV at 1800 mV
<6>SWBST: 5000 <--> 5150 mV at 5000 mV
<6>VSNVS: 1000 <--> 3000 mV at 3000 mV
<6>VREFDDR: 750 mV
<6>VGEN1: 800 <--> 1550 mV at 1200 mV
<6>VGEN2: 800 <--> 1550 mV at 800 mV
<6>VGEN3: 1800 <--> 3300 mV at 1800 mV
<6>VGEN4: 1800 <--> 3300 mV at 1800 mV
<6>VGEN5: 1800 <--> 3300 mV at 2500 mV
<6>VGEN6: 1800 <--> 3300 mV at 1800 mV
<6>Serial: IMX driver
<6>2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 58) is a IMX
<6>console [ttymxc0] enabled
<6>serial: Freescale lpuart driver
<6>imx sema4 driver is registered.
<6>[drm] Initialized drm 1.1.0 20060810
<6>[drm] Initialized vivante 1.0.0 20120216 on minor 0
<6>brd: module loaded
<6>loop: module loaded
<6>m25p80 spi32766.0: m25p32 (4096 Kbytes)
<6>spi_imx 2008000.ecspi: probed
<6>tun: Universal TUN/TAP device driver, 1.6
<6>tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
<6>CAN device driver interface
<3>fec 2188000.ethernet (unregistered net_device): Invalid MAC address: 00:00:00:00:00:00
<6>fec 2188000.ethernet (unregistered net_device): Using random MAC address: 9a:c4:44:14:08:81
<6>libphy: fec_enet_mii_bus: probed
<6>PPP generic driver version 2.4.2
<6>PPP BSD Compression module registered
<6>PPP Deflate Compression module registered
<6>PPP MPPE Compression module registered
<6>NET: Registered protocol family 24
<6>usbcore: registered new interface driver asix
<6>usbcore: registered new interface driver ax88179_178a
<6>usbcore: registered new interface driver cdc_ether
<6>usbcore: registered new interface driver net1080
<6>usbcore: registered new interface driver cdc_subset
<6>usbcore: registered new interface driver zaurus
<6>usbcore: registered new interface driver cdc_ncm
<6>ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
<6>usbcore: registered new interface driver cdc_acm
<6>cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
<6>usbcore: registered new interface driver usb-storage
<6>usbcore: registered new interface driver usbserial
<6>usbcore: registered new interface driver option
<6>usbserial: USB Serial support registered for GSM modem (1-port)
<6>ci_hdrc ci_hdrc.0: EHCI Host Controller
<6>ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
<6>ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
<6>usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
<6>usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
<6>usb usb1: Product: EHCI Host Controller
<6>usb usb1: Manufacturer: Linux 3.10.53-88102-gbcffb04abae1-dirty ehci_hcd
<6>usb usb1: SerialNumber: ci_hdrc.0
<6>hub 1-0:1.0: USB hub found
<6>hub 1-0:1.0: 1 port detected
<6>ci_hdrc ci_hdrc.1: EHCI Host Controller
<6>ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 2
<6>ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
<6>usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
<6>usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
<6>usb usb2: Product: EHCI Host Controller
<6>usb usb2: Manufacturer: Linux 3.10.53-88102-gbcffb04abae1-dirty ehci_hcd
<6>usb usb2: SerialNumber: ci_hdrc.1
<6>hub 2-0:1.0: USB hub found
<6>hub 2-0:1.0: 1 port detected
<6>mousedev: PS/2 mouse device common for all mice
<6>input: 20b8000.kpp as /devices/soc0/soc.2/2000000.aips-bus/20b8000.kpp/input/input0
<6>usbcore: registered new interface driver xpad
<6>usbcore: registered new interface driver usb_acecad
<6>usbcore: registered new interface driver aiptek
<6>usbcore: registered new interface driver gtco
<6>usbcore: registered new interface driver hanwang
<6>usbcore: registered new interface driver kbtab
<6>usbcore: registered new interface driver wacom
<3>elan-touch 0-0010: elan - Read Hello Packet Failed
<4>elan-touch: probe of 0-0010 failed with error -22
<3>mma8450 0-001c: read chip ID 0xfffffffb is not equal to 0xc6!
<4>mma8450: probe of 0-001c failed with error -22
<4>i2c-core: driver [isl29023] using legacy suspend method
<4>i2c-core: driver [isl29023] using legacy resume method
<6>snvs_rtc 20cc034.snvs-rtc-lp: rtc core: registered 20cc034.snvs-rtc-lp as rtc0
<6>i2c /dev entries driver
<4>ov5640 2-003c: cannot get io voltage
<6>usb 1-1: new high-speed USB device number 2 using ci_hdrc
<3>ov5640_read_reg:write reg error:reg=300a
<4>camera ov5640 is not found
<3>ov5642_power_on: cannot get io voltage error
<6>usb 1-1: New USB device found, idVendor=214b, idProduct=7000
<6>usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
<6>usb 1-1: Product: USB2.0 HUB
<6>hub 1-1:1.0: USB hub found
<6>hub 1-1:1.0: 4 ports detected
<3>ov5642_read_reg:write reg error:reg=300a
<4>camera ov5642 is not found
<6>pxp-v4l2 pxp_v4l2_out.24: initialized
<6>usbcore: registered new interface driver uvcvideo
<6>USB Video Class driver (1.1.1)
<6>gspca_main: v2.14.0 registered
<6>imx2-wdt 20bc000.wdog: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=0)
<6>device-mapper: uevent: version 1.0.3
<6>device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: [email protected]
<6>Bluetooth: HCI UART driver ver 2.2
<6>Bluetooth: HCIATH3K protocol initialized
<6>usbcore: registered new interface driver btusb
<6>cpuidle: using governor ladder
<6>cpuidle: using governor menu
<6>sdhci: Secure Digital Host Controller Interface driver
<6>sdhci: Copyright(c) Pierre Ossman
<6>sdhci-pltfm: SDHCI platform and OF driver helper
<6>mmc0: no vqmmc regulator found
<6>mmc0: no vmmc regulator found
<6>mmc0: SDHCI controller on 2190000.usdhc [2190000.usdhc] using DMA
<6>mmc1: no vqmmc regulator found
<6>mmc1: no vmmc regulator found
<6>mmc1: SDHCI controller on 2194000.usdhc [2194000.usdhc] using DMA
<6>mmc2: no vqmmc regulator found
<6>mmc2: no vmmc regulator found
<6>mmc2: SDHCI controller on 2198000.usdhc [2198000.usdhc] using DMA
<4>galcore: clk_get gpu3d_clk failed, disable 3d!
<6>Galcore version 5.0.11.25762
<6>mmc1: BKOPS_EN bit is not set
<4>mmc1: switch to highspeed failed
<6>mmc1: new MMC card at address 0001
<6>mmcblk1: mmc1:0001 SEM08G 7.28 GiB
<6>mmcblk1boot0: mmc1:0001 SEM08G partition 1 2.00 MiB
<6>mmcblk1boot1: mmc1:0001 SEM08G partition 2 2.00 MiB
<6>mmcblk1rpmb: mmc1:0001 SEM08G partition 3 2.00 MiB
<6> mmcblk1: p1 p2 p3 < p5 p6 p7 p8 > p4
<4>mmcblk1: p4 size 13090816 extends beyond EOD, truncated
<6> mmcblk1boot1: unknown partition table
<6> mmcblk1boot0: unknown partition table
<6>hidraw: raw HID events driver (C) Jiri Kosina
<6>usbcore: registered new interface driver usbhid
<6>usbhid: USB HID core driver
<6>ashmem: initialized
<6>logger: created 256K log 'log_main'
<6>logger: created 256K log 'log_events'
<6>logger: created 256K log 'log_radio'
<6>logger: created 256K log 'log_system'
<6>usbcore: registered new interface driver snd-usb-audio
<3>wm8962 1-001a: Failed to read ID register
<4>wm8962: probe of 1-001a failed with error -5
<3>imx-wm8962 sound.25: failed to find codec platform device
<4>imx-wm8962: probe of sound.25 failed with error -22
<6>imx-spdif sound-spdif.26:  dit-hifi <-> 2004000.spdif mapping ok
<6>NET: Registered protocol family 26
<6>u32 classifier
<6>    Actions configured
<6>Netfilter messages via NETLINK v0.30.
<6>nf_conntrack version 0.5.0 (7841 buckets, 31364 max)
<6>ctnetlink v0.93: registering with nfnetlink.
<6>NF_TPROXY: Transparent proxy support initialized, version 4.1.0
<6>NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
<6>xt_time: kernel timezone is -0000
<6>ip_tables: (C) 2000-2006 Netfilter Core Team
<6>arp_tables: (C) 2002 David S. Miller
<6>TCP: cubic registered
<6>Initializing XFRM netlink socket
<6>NET: Registered protocol family 10
<6>mip6: Mobile IPv6
<6>ip6_tables: (C) 2000-2006 Netfilter Core Team
<6>NET: Registered protocol family 17
<6>NET: Registered protocol family 15
<6>can: controller area network core (rev 20120528 abi 9)
<6>NET: Registered protocol family 29
<6>can: raw protocol (rev 20120528)
<6>can: broadcast manager protocol (rev 20120528 t)
<6>can: netlink gateway (rev 20130117) max_hops=1
<6>Bluetooth: RFCOMM TTY layer initialized
<6>Bluetooth: RFCOMM socket layer initialized
<6>Bluetooth: RFCOMM ver 1.11
<6>Bluetooth: BNEP (Ethernet Emulation) ver 1.3
<6>Bluetooth: BNEP filters: protocol multicast
<6>Bluetooth: BNEP socket layer initialized
<6>Bluetooth: HIDP (Human Interface Emulation) ver 1.2
<6>Bluetooth: HIDP socket layer initialized
<6>8021q: 802.1Q VLAN Support v1.8
<6>lib80211: common routines for IEEE802.11 drivers
<7>lib80211_crypt: registered algorithm 'NULL'
<7>lib80211_crypt: registered algorithm 'WEP'
<7>lib80211_crypt: registered algorithm 'CCMP'
<7>lib80211_crypt: registered algorithm 'TKIP'
<5>Key type dns_resolver registered
<6>VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
<6>SWBST: disabling
<6>SW4: disabling
<6>wm8962-supply-4v2: disabling
<6>wm8962-supply-3v15: disabling
<6>regulator-dummy: disabling
<6>imx mcc test is registered.
<6>file system registered
<6>android_usb gadget: Mass Storage Function, version: 2009/09/11
<6>android_usb gadget: Number of LUNs=1
<6> lun0: LUN: removable file: (no medium)
<6>android_usb gadget: android_usb ready
<6>snvs_rtc 20cc034.snvs-rtc-lp: setting system clock to 1970-01-01 00:00:01 UTC (1)
<6>ALSA device list:
<6>  #0: imx-spdif
<6>Freeing unused kernel memory: 340K (80e6f000 - 80ec4000)
<7>SELinux: 512 avtab hash slots, 1318 rules.
<7>SELinux:  1 users, 2 roles, 287 types, 1 bools, 1 sens, 1024 cats
<7>SELinux:  84 classes, 1318 rules
<6>SELinux:  Permission attach_queue in class tun_socket not defined in policy.
<6>SELinux: the above unknown classes and permissions will be denied
<7>SELinux:  Completing initialization.
<7>SELinux:  Setting up existing superblocks.
<7>SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts
<7>SELinux: initialized (dev rootfs, type rootfs), uses genfs_contexts
<7>SELinux: initialized (dev bdev, type bdev), not configured for labeling
<7>SELinux: initialized (dev proc, type proc), uses genfs_contexts
<7>SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>SELinux: initialized (dev devtmpfs, type devtmpfs), uses transition SIDs
<7>SELinux: initialized (dev debugfs, type debugfs), uses genfs_contexts
<7>SELinux: initialized (dev sockfs, type sockfs), uses task SIDs
<7>SELinux: initialized (dev pipefs, type pipefs), uses task SIDs
<7>SELinux: initialized (dev anon_inodefs, type anon_inodefs), not configured for labeling
<7>SELinux: initialized (dev devpts, type devpts), uses transition SIDs
<7>SELinux: initialized (dev selinuxfs, type selinuxfs), uses genfs_contexts
<7>SELinux: initialized (dev configfs, type configfs), not configured for labeling
<5>type=1403 audit(1.660:2): policy loaded auid=4294967295 ses=4294967295
<12>SELinux: Loaded policy from /sepolicy
<5>type=1404 audit(1.670:3): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295
<11>init: /init.rc: 303: invalid command 'echo'
<11>init: /init.freescale.rc: 22: invalid command 'hciconfig'
<11>init: /init.freescale.rc: 25: invalid command 'hciconfig'
<11>init: /init.freescale.rc: 171: ignored duplicate definition of service 'dhcpcd_wlan0'
<11>init: /init.freescale.rc: 176: ignored duplicate definition of service 'dhcpcd_p2p'
<11>init: /init.freescale.rc: 181: ignored duplicate definition of service 'iprenew_wlan0'
<11>init: /init.freescale.rc: 186: ignored duplicate definition of service 'iprenew_p2p'
<4>init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
<11>init: /dev/hw_random not found
<6>keychord: using input dev 20b8000.kpp for fevent
<11>init: cannot open '/initlogo.rle'
<7>SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
<7>SELinux: initialized (dev pstore, type pstore), not configured for labeling
<6>Console: switching to colour dummy device 80x30
<6>EXT4-fs (mmcblk1p5): mounted filesystem with ordered data mode. Opts: (null)
<7>SELinux: initialized (dev mmcblk1p5, type ext4), uses xattr
<4>EXT4-fs (mmcblk1p4): Ignoring removed nomblk_io_submit option
<6>EXT4-fs (mmcblk1p4): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,noauto_da_alloc,errors=panic
<7>SELinux: initialized (dev mmcblk1p4, type ext4), uses xattr
<4>EXT4-fs (mmcblk1p6): Ignoring removed nomblk_io_submit option
<6>EXT4-fs (mmcblk1p6): mounted filesystem with ordered data mode. Opts: nomblk_io_submit
<7>SELinux: initialized (dev mmcblk1p6, type ext4), uses xattr
<6>EXT4-fs (mmcblk1p7): mounted filesystem with ordered data mode. Opts: (null)
<7>SELinux: initialized (dev mmcblk1p7, type ext4), uses xattr
<4>rtk_btusb: disagrees about version of symbol skb_put
<4>rtk_btusb: Unknown symbol skb_put (err -22)
<4>rtk_btusb: disagrees about version of symbol hci_free_dev
<4>rtk_btusb: Unknown symbol hci_free_dev (err -22)
<4>rtk_btusb: disagrees about version of symbol skb_dequeue
<4>rtk_btusb: Unknown symbol skb_dequeue (err -22)
<4>rtk_btusb: disagrees about version of symbol sock_create
<4>rtk_btusb: Unknown symbol sock_create (err -22)
<4>rtk_btusb: disagrees about version of symbol kfree_skb
<4>rtk_btusb: Unknown symbol kfree_skb (err -22)
<4>rtk_btusb: disagrees about version of symbol __alloc_skb
<4>rtk_btusb: Unknown symbol __alloc_skb (err -22)
<4>rtk_btusb: disagrees about version of symbol skb_queue_tail
<4>rtk_btusb: Unknown symbol skb_queue_tail (err -22)
<4>rtk_btusb: disagrees about version of symbol hci_alloc_dev
<4>rtk_btusb: Unknown symbol hci_alloc_dev (err -22)
<4>rtk_btusb: disagrees about version of symbol sock_sendmsg
<4>rtk_btusb: Unknown symbol sock_sendmsg (err -22)
<4>rtk_btusb: disagrees about version of symbol skb_queue_purge
<4>rtk_btusb: Unknown symbol skb_queue_purge (err -22)
<4>rtk_btusb: disagrees about version of symbol hci_unregister_dev
<4>rtk_btusb: Unknown symbol hci_unregister_dev (err -22)
<4>rtk_btusb: disagrees about version of symbol sock_release
<4>rtk_btusb: Unknown symbol sock_release (err -22)
<4>rtk_btusb: disagrees about version of symbol hci_recv_fragment
<4>rtk_btusb: Unknown symbol hci_recv_fragment (err -22)
<4>rtk_btusb: disagrees about version of symbol hci_register_dev
<4>rtk_btusb: Unknown symbol hci_register_dev (err -22)
<6>cfg80211: Calling CRDA to update world regulatory domain
<7>SELinux: initialized (dev functionfs, type functionfs), not configured for labeling
<5>type=1400 audit(4.590:4): avc:  denied  { entrypoint } for  pid=115 comm="init" path="/sbin/healthd" dev="rootfs" ino=234 scontext=u:r:healthd:s0 tcontext=u:object_r:rootfs:s0 tclass=file permissive=1
<11>init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
<12>healthd: BatteryTemperaturePath not found
<12>healthd: BatteryTechnologyPath not found
<6>binder: 115:115 transaction failed 29189, size 0-0
<11>init: using deprecated syntax for specifying property 'ro.serialno', use ${name} instead
<11>init: using deprecated syntax for specifying property 'ro.product.manufacturer', use ${name} instead
<11>init: using deprecated syntax for specifying property 'ro.product.model', use ${name} instead
<11>init: property 'sys.powerctl' doesn't exist while expanding '${sys.powerctl}'
<11>init: powerctl: cannot expand '${sys.powerctl}'
<11>init: property 'sys.sysctl.extra_free_kbytes' doesn't exist while expanding '${sys.sysctl.extra_free_kbytes}'
<11>init: cannot expand '${sys.sysctl.extra_free_kbytes}' while writing to '/proc/sys/vm/extra_free_kbytes'
<3>android_usb: already disabled
<6>mtp_bind_config
<7>SELinux: initialized (dev fuse, type fuse), uses genfs_contexts
<6>EXT4-fs (mmcblk1p7): re-mounted. Opts: (null)
<3>csi_v4l_open: Internal error, camera is not found!
<3>mmcblk1: error -84 transferring data, sector 372377, nr 128, cmd response 0x900, card status 0x800b00
<4>mmcblk1: retrying using single block read
<6>warning: `zygote' uses 32-bit capabilities (legacy support in use)
<6>request_suspend_state: wakeup (3->0) at 50127175505 (1970-01-02 00:00:16.897847043 UTC)
<3>mmcblk1: error -110 sending stop command, original cmd response 0x900, card status 0xc00900
<3>mmcblk1: error -84 transferring data, sector 140305, nr 32, cmd response 0x900, card status 0x0
<6>lowmemorykiller: lowmem_shrink: convert oom_adj to oom_score_adj:
<6>lowmemorykiller: oom_adj 0 => oom_score_adj 0
<6>lowmemorykiller: oom_adj 1 => oom_score_adj 58
<6>lowmemorykiller: oom_adj 2 => oom_score_adj 117
<6>lowmemorykiller: oom_adj 3 => oom_score_adj 176
<6>lowmemorykiller: oom_adj 9 => oom_score_adj 529
<6>lowmemorykiller: oom_adj 15 => oom_score_adj 1000
<6>fec 2188000.ethernet eth0: Freescale FEC PHY driver [Generic PHY] (mii_bus:phy_addr=2188000.ethernet:00, irq=-1)
<6>IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
<6>acc_open
<6>acc_release
<6>usb 1-1.1: new high-speed USB device number 3 using ci_hdrc
<6>usb 1-1.1: New USB device found, idVendor=214b, idProduct=7000
<6>usb 1-1.1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
<6>usb 1-1.1: Product: USB2.0 HUB
<6>hub 1-1.1:1.0: USB hub found
<6>hub 1-1.1:1.0: 4 ports detected
<6>usb 1-1.3: new high-speed USB device number 4 using ci_hdrc
<6>usb 1-1.3: New USB device found, idVendor=0bda, idProduct=b720
<6>usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
<6>usb 1-1.3: Product: 802.11n WLAN Adapter
<6>usb 1-1.3: Manufacturer: Realtek
<6>usb 1-1.3: SerialNumber: 00e04c000001
<6>usb 1-1.1.4: new low-speed USB device number 5 using ci_hdrc
<6>usb 1-1.1.4: New USB device found, idVendor=275d, idProduct=0ba6
<6>usb 1-1.1.4: New USB device strings: Mfr=0, Product=1, SerialNumber=0
<6>usb 1-1.1.4: Product: USB OPTICAL MOUSE
<6>input: USB OPTICAL MOUSE  as /devices/soc0/soc.2/2100000.aips-bus/2184000.usb/ci_hdrc.0/usb1/1-1/1-1.1/1-1.1.4/1-1.1.4:1.0/input/input1
<6>hid-generic 0003:275D:0BA6.0001: input,hidraw0: USB HID v1.11 Mouse [USB OPTICAL MOUSE ] on usb-ci_hdrc.0-1.1.4/input0
<11>init: sys_prop: permission denied uid:1003  name:service.bootanim.exit
<4>RTL871X: module init start
<4>RTL871X: rtl8723bu v4.3.6.11_12942.20141204_BTCOEX20140507-4E40
<4>RTL871X: rtl8723bu BT-Coex version = BTCOEX20140507-4E40
<4>RTL871X: rtw_ndev_init(wlan0)
<4>RTL871X: rtw_ndev_init(p2p0)
<6>usbcore: registered new interface driver rtl8723bu
<4>RTL871X: module init ret=0
<4>RTL871X: RTW_ADAPTIVITY_EN_AUTO, chplan:0x20, Regulation:3,3
<4>RTL871X: RTW_ADAPTIVITY_MODE_NORMAL
<6>IPv6: ADDRCONF(NETDEV_UP): p2p0: link is not ready
<6>IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
<4>RTL871X: nolinked power save enter
<4>RTL871X: nolinked power save leave
root@evk_6sl:/ # RTL871X: RTW_ADAPTIVITY_EN_AUTO, chplan:0x20, Regulation:3,3
root@evk_6sl:/ # RTL871X: nolinked power save enter
root@evk_6sl:/ #
root@evk_6sl:/ # logcat
--------- beginning of /dev/log/system
I/Vold    (  118): Vold 2.1 (the revenge) firing up
D/Vold    (  118): Volume extsd state changing -1 (Initializing) -> 0 (No-Media)
D/Vold    (  118): Volume udisk state changing -1 (Initializing) -> 0 (No-Media)
W/SystemServer(  417): System clock is before 1970; setting to 1970.
I/SystemServer(  417): Entered the Android system server!
I/SystemServer(  417): Waiting for installd to be ready.
I/Installer(  417): connecting...
I/SystemServer(  417): Power Manager
I/SystemServer(  417): Activity Manager
I/ActivityManager(  417): Memory class: 64
W/BatteryStatsImpl(  417): Couldn't get kernel wake lock stats
I/AppOps  (  417): No existing app ops /data/system/appops.xml; starting empty
I/IntentFirewall(  417): Read new rules (A:0 B:0 S:0)
I/SystemServer(  417): Display Manager
I/SystemServer(  417): Telephony Registry
I/DisplayManagerService(  417): Display device added: DisplayDeviceInfo{"Built-in Screen": 240 x 320, 51.0 fps, density 120, 160.421 x 159.372 dpi, touch INTERNAL, rotation 0, type BUILT_IN, FLAG_DEFAULT_DISPLAY, FLAG_ROTATES_WITH_CONTENT, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
I/SystemServer(  417): Scheduling Policy
I/SystemServer(  417): Package Manager
W/FileUtils(  417): Failed to chmod(/data/system/packages.list): libcore.io.ErrnoException: chmod failed: ENOENT (No such file or directory)
D/SELinuxMMAC(  417): Couldn't find install policy /data/security/mac_permissions.xml
D/SELinuxMMAC(  417): Using install policy file /system/etc/security/mac_permissions.xml
I/PackageManager(  417): No settings file; creating initial state
W/PackageParser(  417): No actions in intent filter at /system/priv-app/Contacts.apk Binary XML file line #375
W/PackageParser(  417): No actions in intent filter at /system/priv-app/Dialer.apk Binary XML file line #163
W/PackageParser(  417): No actions in intent filter at /system/app/Bluetooth.apk Binary XML file line #211
W/PackageManager(  417): Package com.android.camera desires unavailable shared library com.google.android.media.effects; ignoring!
I/PackageManager(  417): Time to scan packages: 15.954 seconds
W/PackageManager(  417): Not granting permission android.permission.GLOBAL_SEARCH to package com.android.quicksearchbox (protectionLevel=18 flags=0x8be45)
W/PackageManager(  417): Unknown permission com.android.smspush.WAPPUSH_MANAGER_BIND in package com.android.phone
W/PackageManager(  417): Unknown permission com.google.android.gallery3d.permission.GALLERY_PROVIDER in package com.android.bluetooth
W/PackageManager(  417): Unknown permission com.android.gallery3d.permission.GALLERY_PROVIDER in package com.android.bluetooth
W/PackageManager(  417): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.providers.calendar
W/PackageManager(  417): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.cl in package com.android.providers.calendar
W/PackageManager(  417): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.mail in package com.android.calendar
W/PackageManager(  417): Not granting permission android.permission.ACCESS_DOWNLOAD_MANAGER to package com.android.browser (protectionLevel=18 flags=0x9be45)
W/PackageManager(  417): Not granting permission android.permission.SEND_DOWNLOAD_COMPLETED_INTENTS to package com.android.browser (protectionLevel=2 flags=0x9be45)
W/PackageManager(  417): Unknown permission android.permission.INSTALL_DRM in package com.android.mms
W/PackageManager(  417): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.settings
W/PackageManager(  417): Not granting permission android.permission.DELETE_PACKAGES to package com.svox.pico (protectionLevel=18 flags=0x8be45)
W/PackageManager(  417): Not granting permission android.permission.DEVICE_POWER to package com.android.deskclock (protectionLevel=2 flags=0x48be45)
I/SystemServer(  417): Entropy Mixer
W/EntropyMixer(  417): No existing entropy file -- first boot?
I/EntropyMixer(  417): Writing entropy...
I/SystemServer(  417): User Service
I/SystemServer(  417): Account Manager
I/SystemServer(  417): Content Manager
I/SystemServer(  417): System Content Providers
D/SettingsProvider(  417): Generated and saved new ANDROID_ID [56f7e407c56d785c] for user 0
I/SystemServer(  417): Lights Service
I/SystemServer(  417): Battery Service
I/SystemServer(  417): Vibrator Service
I/SystemServer(  417): Consumer IR Service
I/SystemServer(  417): Alarm Manager
I/SystemServer(  417): Init Watchdog
I/SystemServer(  417): Input Manager
I/InputManager(  417): Initializing input manager, mUseDevInputEventForAudioJack=false
I/SystemServer(  417): Window Manager
I/WindowManager(  417): No existing display settings /data/system/display_settings.xml; starting empty
I/WindowManager(  417): No keyguard interface!
I/InputManager(  417): Starting input manager
I/SystemServer(  417): Bluetooth Manager Service
I/SystemServer(  417): Input Method Service
W/InputMethodManagerService(  417): No IME selected. Choose the most applicable IME.
I/InputMethodManagerService(  417): No default found, using com.android.inputmethod.latin/.LatinIME
I/SystemServer(  417): Accessibility Manager
I/ActivityManager(  417): Config changes=1df8 {1.0 ?mcc?mnc en_US ldltr sw320dp w320dp h426dp 120dpi smll port ?uimode ?night -touch -keyb/h/h -nav/h s.2}
I/ActivityManager(  417): Config changes=400 {1.0 ?mcc?mnc en_US ldltr sw320dp w320dp h353dp 120dpi smll port ?uimode ?night -touch -keyb/h/h -nav/h s.3}
I/SystemServer(  417): Mount Service
D/MountService(  417): got storage path: null description: Internal storage primary: true removable: false emulated: true mtpReserve: 100 allowMassStorage: false maxFileSize: 0
D/MountService(  417): addVolumeLocked() StorageVolume:
D/MountService(  417):     mStorageId=65537 mPath=/storage/emulated/0 mDescriptionId=17040663
D/MountService(  417):     mPrimary=true mRemovable=false mEmulated=true mMtpReserveSpace=100
D/MountService(  417):     mAllowMassStorage=false mMaxFileSize=0 mOwner=UserHandle{0} mUuid=null
D/MountService(  417):     mUserLabel=null mState=null
D/MountService(  417): got storage path: /storage/extsd description: SD card primary: false removable: true emulated: false mtpReserve: 0 allowMassStorage: false maxFileSize: 0
D/MountService(  417):     mStorageId=0 mPath=/storage/extsd mDescriptionId=17040664 mPrimary=false
D/MountService(  417):     mRemovable=true mEmulated=false mMtpReserveSpace=0 mAllowMassStorage=false
D/MountService(  417):     mMaxFileSize=0 mOwner=null mUuid=null mUserLabel=null mState=null
D/MountService(  417): got storage path: /storage/udisk description: USB storage primary: false removable: true emulated: false mtpReserve: 0 allowMassStorage: false maxFileSize: 0
D/MountService(  417):     mStorageId=0 mPath=/storage/udisk mDescriptionId=17040665 mPrimary=false
I/SystemServer(  417): LockSettingsService
I/SystemServer(  417): Device Policy
I/SystemServer(  417): Status Bar
I/SystemServer(  417): Clipboard Service
I/SystemServer(  417): NetworkManagement Service
I/SystemServer(  417): Text Service Manager Service
D/MountService(  417): volume state changed for /storage/extsd (unmounted -> removed)
D/MountService(  417): volume state changed for /storage/udisk (unmounted -> removed)
I/SystemServer(  417): NetworkStats Service
I/SystemServer(  417): NetworkPolicy Service
I/SystemServer(  417): Wi-Fi P2pService
I/SystemServer(  417): Wi-Fi Service
I/SystemServer(  417): Connectivity Service
D/ConnectivityService(  417): ConnectivityService starting up
D/ConnectivityService(  417): wifiOnly=false
E/ConnectivityService(  417): Ignoring protectedNetwork 14
E/MobileDataStateTracker(  417): default: Ignoring feature request because could not acquire PhoneService
E/MobileDataStateTracker(  417): default: Could not enable APN type "default"
I/WifiService(  417): WifiService starting up with Wi-Fi disabled
I/SystemServer(  417): Network Service Discovery Service
D/NsdService(  417): Network service discovery enabled true
I/SystemServer(  417): UpdateLock Service
I/SystemServer(  417): Notification Manager
I/SystemServer(  417): Device Storage Monitor
I/SystemServer(  417): Location Manager
I/SystemServer(  417): Country Detector
I/SystemServer(  417): Search Service
I/SystemServer(  417): DropBox Service
I/SystemServer(  417): Wallpaper Service
W/WallpaperService(  417): no current wallpaper -- first boot?
I/SystemServer(  417): Audio Service
I/SystemServer(  417): Dock Observer
W/DockObserver(  417): This kernel does not have dock station support
I/SystemServer(  417): Wired Accessory Manager
W/WiredAccessoryManager(  417): This kernel does not have wired headset support
W/WiredAccessoryManager(  417): This kernel does not have HDMI audio support
I/SystemServer(  417): USB Service
I/SystemServer(  417): Serial Service
I/SystemServer(  417): Twilight Service
I/SystemServer(  417): UI Mode Manager Service
I/SystemServer(  417): Backup Service
V/BackupManagerService(  417): Initializing package tracking
V/BackupManagerService(  417): No ancestral data
V/BackupManagerService(  417): addPackageParticipantsLocked: all
I/BackupManagerService(  417): Scheduling backup for new app com.android.calendar
D/BackupManagerService(  417): Now staging backup of com.android.calendar
I/BackupManagerService(  417): Scheduling backup for new app com.android.browser
D/BackupManagerService(  417): Now staging backup of com.android.browser
I/BackupManagerService(  417): Scheduling backup for new app com.android.providers.userdictionary
D/BackupManagerService(  417): Now staging backup of com.android.providers.userdictionary
I/BackupManagerService(  417): Scheduling backup for new app com.android.sharedstoragebackup
D/BackupManagerService(  417): Now staging backup of com.android.sharedstoragebackup
I/BackupManagerService(  417): Scheduling backup for new app android
D/BackupManagerService(  417): Now staging backup of android
I/BackupManagerService(  417): Scheduling backup for new app com.android.dialer
D/BackupManagerService(  417): Now staging backup of com.android.dialer
I/BackupManagerService(  417): Scheduling backup for new app com.android.providers.settings
D/BackupManagerService(  417): Now staging backup of com.android.providers.settings
V/BackupManagerService(  417): Starting with transport android/com.android.internal.backup.LocalTransport
V/BackupManagerService(  417): Found transports: 1
I/BackupManagerService(  417): Binding to transport host ComponentInfo{android/com.android.internal.backup.LocalTransportService}
I/BackupManagerService(  417): Backup enabled => false
I/BackupManagerService(  417): Opting out of backup
I/SystemServer(  417): AppWidget Service
I/SystemServer(  417): Recognition Service
I/SystemServer(  417): DiskStats Service
I/SystemServer(  417): SamplingProfiler Service
I/SystemServer(  417): NetworkTimeUpdateService
I/SystemServer(  417): CommonTimeManagementService
I/SystemServer(  417): CertBlacklister
I/SystemServer(  417): Dreams Service
I/SystemServer(  417): Assets Atlas Service
I/SystemServer(  417): IdleMaintenanceService
I/SystemServer(  417): Print Service
I/SystemServer(  417): Media Router Service
I/LockSettingsService(  417): Migrated lock settings to new location
I/LockSettingsService(  417): Migrated per-user lock settings to new location
I/ActivityManager(  417): Start proc com.android.systemui for service com.android.keyguard/.KeyguardService: pid=474 uid=10007 gids={50007, 1028, 1015, 1035, 3002, 3001}
W/SystemServer(  417): ***********************************************
I/ActivityManager(  417): Sending system update to ComponentInfo{com.android.providers.calendar/com.android.providers.calendar.CalendarUpgradeReceiver} for user 0
I/ActivityManager(  417): Sending system update to ComponentInfo{com.android.providers.contacts/com.android.providers.contacts.ContactsUpgradeReceiver} for user 0
I/ActivityManager(  417): Sending system update to ComponentInfo{com.android.providers.media/com.android.providers.media.MediaUpgradeReceiver} for user 0
I/ActivityManager(  417): Start proc com.android.providers.calendar for broadcast com.android.providers.calendar/.CalendarUpgradeReceiver: pid=487 uid=10001 gids={50001, 3003, 1028, 1015}
W/InputMethodManagerService(  417): Focus gain on non-focused client android.view.inputmethod.InputMethodManager$1@2d54c7c0 (uid=1000 pid=417)
V/BackupManagerService(  417): Connected to transport ComponentInfo{android/com.android.internal.backup.LocalTransportService}
V/BackupManagerService(  417): Registering transport android/com.android.internal.backup.LocalTransportService::android/com.android.internal.backup.LocalTransport = com.android.internal.backup.LocalTransport@2d2c6d00
I/ActivityManager(  417): Launching preboot mode app: ProcessRecord{2d4e5188 487:com.android.providers.calendar/u0a1}
I/ActivityManager(  417): Start proc android.process.acore for broadcast com.android.providers.contacts/.ContactsUpgradeReceiver: pid=511 uid=10002 gids={50002, 3003, 1028, 1015}
I/ActivityManager(  417): Launching preboot mode app: ProcessRecord{2d340610 511:android.process.acore/u0a2}
I/ActivityManager(  417): Start proc android.process.media for broadcast com.android.providers.media/.MediaUpgradeReceiver: pid=527 uid=10005 gids={50005, 1028, 1015, 1023, 1024, 2001, 3003, 3007}
I/ActivityManager(  417): Launching preboot mode app: ProcessRecord{2d434cf0 527:android.process.media/u0a5}
I/ActivityManager(  417): Writing new set of last done pre-boot receivers...
I/ActivityManager(  417): Removing system update proc: ProcessRecord{2d4e5188 487:com.android.providers.calendar/u0a1}
I/ActivityManager(  417): Killing 487:com.android.providers.calendar/u0a1 (adj 13): system update done
I/ActivityManager(  417): Removing system update proc: ProcessRecord{2d340610 511:android.process.acore/u0a2}
I/ActivityManager(  417): Killing 511:android.process.acore/u0a2 (adj 11): system update done
I/ActivityManager(  417): Removing system update proc: ProcessRecord{2d434cf0 527:android.process.media/u0a5}
I/ActivityManager(  417): Killing 527:android.process.media/u0a5 (adj 9): system update done
I/ActivityManager(  417): System now ready
I/SystemServer(  417): Making services ready
D/NetworkManagementService(  417): enabling bandwidth control
W/MountService(  417): Duplicate state transition (mounted -> mounted) for /storage/emulated/0
I/StatusBarManagerService(  417): registerStatusBar bar=com.android.internal.statusbar.IStatusBar$Stub$Proxy@2d277b50
E/NetdConnector(  417): NDC Command {5 bandwidth enable} took too long (601ms)
I/ActivityManager(  417): Config changes=200 {1.0 ?mcc?mnc en_US ldltr sw320dp w320dp h353dp 120dpi smll port -touch -keyb/h/h -nav/h s.4}
W/RecognitionManagerService(  417): no available voice recognition services found for user 0
W/AppWidgetServiceImpl(  417): Failed to read state: java.io.FileNotFoundException: /data/system/users/0/appwidgets.xml: open failed: ENOENT (No such file or directory)
W/InputMethodManagerService(  417): Ignoring setImeWindowStatus of uid 1000 token: null
I/ActivityManager(  417): Start proc android.process.acore for content provider com.android.providers.contacts/.ContactsProvider2: pid=592 uid=10002 gids={50002, 3003, 1028, 1015}
W/InputMethodUtils(  417): Found no subtypes in a system IME: com.android.inputmethod.pinyin
W/InputMethodManagerService(  417): Reset the default IME as "Resource" is ready here.
I/InputMethodManagerService(  417): Selected default: com.android.inputmethod.latin/.LatinIME
I/ActivityManager(  417): Config changes=20 {1.0 ?mcc?mnc en_US ldltr sw320dp w320dp h353dp 120dpi smll port -touch -keyb/v/h -nav/h s.5}
I/ActivityManager(  417): Start proc com.android.inputmethod.latin for service com.android.inputmethod.latin/.LatinIME: pid=605 uid=10027 gids={50027, 1028, 1015}
V/InputMethodManagerService(  417): Adding window token: android.os.Binder@2d25f9e8
W/InputMethodManagerService(  417): Illegal subtype state: old subtype = null, new subtype = android.view.inputmethod.InputMethodSubtype@c9194f98
W/LocationManagerService(  417): no network location provider found
E/LocationManagerService(  417): no geocoder provider found
E/LocationManagerService(  417): No FusedProvider found.
E/LocationManagerService(  417): no geofence provider found
V/KeyguardTouchDelegate(  474): Connected to keyguard
I/ActivityManager(  417): Start proc com.android.phone for added application com.android.phone: pid=619 uid=1001 gids={41001, 3002, 3001, 3003, 1028, 1015}
I/ActivityManager(  417): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10000000 cmp=com.android.settings/.CryptKeeper} from pid 0
I/ActivityManager(  417): Start proc com.android.settings for activity com.android.settings/.CryptKeeper: pid=626 uid=1000 gids={41000, 3003, 1028, 1015, 3002, 3001}
I/ActivityManager(  417): Start proc android.process.media for broadcast com.android.providers.media/.MtpReceiver: pid=637 uid=10005 gids={50005, 1028, 1015, 1023, 1024, 2001, 3003, 3007}
W/ContextImpl(  417): Calling a method in the system process without a qualified user: android.app.ContextImpl.sendBroadcast:1131 com.android.server.usb.UsbSettingsManager.deviceAttached:621 com.android.server.usb.UsbHostManager.usbDeviceAdded:156 com.android.server.usb.UsbHostManager.monitorUsbHostBus:-2 com.android.server.usb.UsbHostManager.access$000:38
I/ActivityManager(  417): Start proc com.android.printspooler for service com.android.printspooler/.PrintSpoolerService: pid=662 uid=10037 gids={50037}
I/ActivityManager(  417): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10000000 cmp=com.android.provision/.DefaultActivity} from pid 0
I/ActivityManager(  417): Start proc com.android.provision for activity com.android.provision/.DefaultActivity: pid=683 uid=10038 gids={50038}
W/BackupManagerService(  417): dataChanged but no participant pkg='com.android.providers.settings' uid=10038
D/MobileDataStateTracker(  417): fota: Broadcast received: android.intent.action.ANY_DATA_STATE apnType=fota
D/MobileDataStateTracker(  417): fota: Received state=DISCONNECTED, old=DISCONNECTED, reason=radioTurnedOff
D/MobileDataStateTracker(  417): supl: Broadcast received: android.intent.action.ANY_DATA_STATE apnType=supl
D/MobileDataStateTracker(  417): supl: Received state=DISCONNECTED, old=DISCONNECTED, reason=radioTurnedOff
I/ActivityManager(  417): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10000000 cmp=com.android.launcher/com.android.launcher2.Launcher} from pid 0
I/ActivityManager(  417): Start proc com.android.launcher for activity com.android.launcher/com.android.launcher2.Launcher: pid=710 uid=10008 gids={50008}
D/MobileDataStateTracker(  417): hipri: Broadcast received: android.intent.action.ANY_DATA_STATE apnType=hipri
D/MobileDataStateTracker(  417): hipri: Received state=DISCONNECTED, old=DISCONNECTED, reason=radioTurnedOff
D/MobileDataStateTracker(  417): ims: Broadcast received: android.intent.action.ANY_DATA_STATE apnType=ims
D/MobileDataStateTracker(  417): ims: Received state=DISCONNECTED, old=DISCONNECTED, reason=radioTurnedOff
D/MobileDataStateTracker(  417): default: Broadcast received: android.intent.action.ANY_DATA_STATE apnType=default
D/MobileDataStateTracker(  417): default: Received state=DISCONNECTED, old=DISCONNECTED, reason=radioTurnedOff
D/MobileDataStateTracker(  417): mms: Broadcast received: android.intent.action.ANY_DATA_STATE apnType=mms
D/MobileDataStateTracker(  417): mms: Received state=DISCONNECTED, old=DISCONNECTED, reason=radioTurnedOff
D/MobileDataStateTracker(  417): cbs: Broadcast received: android.intent.action.ANY_DATA_STATE apnType=cbs
D/MobileDataStateTracker(  417): cbs: Received state=DISCONNECTED, old=DISCONNECTED, reason=radioTurnedOff
D/MobileDataStateTracker(  417): fota: Received state=DISCONNECTED, old=DISCONNECTED, reason=dataDetached
D/MobileDataStateTracker(  417): supl: Received state=DISCONNECTED, old=DISCONNECTED, reason=dataDetached
D/MobileDataStateTracker(  417): hipri: Received state=DISCONNECTED, old=DISCONNECTED, reason=dataDetached
D/MobileDataStateTracker(  417): ims: Received state=DISCONNECTED, old=DISCONNECTED, reason=dataDetached
D/MobileDataStateTracker(  417): default: Received state=DISCONNECTED, old=DISCONNECTED, reason=dataDetached
D/MobileDataStateTracker(  417): mms: Received state=DISCONNECTED, old=DISCONNECTED, reason=dataDetached
D/MobileDataStateTracker(  417): cbs: Received state=DISCONNECTED, old=DISCONNECTED, reason=dataDetached
D/MobileDataStateTracker(  417): fota: Received state=DISCONNECTED, old=DISCONNECTED, reason=roamingOff
D/MobileDataStateTracker(  417): supl: Received state=DISCONNECTED, old=DISCONNECTED, reason=roamingOff
D/MobileDataStateTracker(  417): hipri: Received state=DISCONNECTED, old=DISCONNECTED, reason=roamingOff
D/MobileDataStateTracker(  417): ims: Received state=DISCONNECTED, old=DISCONNECTED, reason=roamingOff
D/MobileDataStateTracker(  417): default: Received state=DISCONNECTED, old=DISCONNECTED, reason=roamingOff
D/MobileDataStateTracker(  417): mms: Received state=DISCONNECTED, old=DISCONNECTED, reason=roamingOff
D/MobileDataStateTracker(  417): cbs: Received state=DISCONNECTED, old=DISCONNECTED, reason=roamingOff
W/ContextImpl(  626): Calling a method in the system process without a qualified user: android.app.ContextImpl.bindService:1551 android.content.ContextWrapper.bindService:517 android.bluetooth.BluetoothInputDevice.doBind:245 android.bluetooth.BluetoothInputDevice.<init>:238 android.bluetooth.BluetoothAdapter.getProfileProxy:1367
W/ContextImpl(  626): Calling a method in the system process without a qualified user: android.app.ContextImpl.bindService:1551 android.content.ContextWrapper.bindService:517 android.bluetooth.BluetoothPan.doBind:149 android.bluetooth.BluetoothPan.<init>:141 android.bluetooth.BluetoothAdapter.getProfileProxy:1370
W/ContextImpl(  626): Calling a method in the system process without a qualified user: android.app.ContextImpl.bindService:1551 android.content.ContextWrapper.bindService:517 android.bluetooth.BluetoothMap.doBind:109 android.bluetooth.BluetoothMap.<init>:102 android.bluetooth.BluetoothAdapter.getProfileProxy:1376
W/ContextImpl(  626): Calling a method in the system process without a qualified user: android.app.ContextImpl.bindService:1551 android.content.ContextWrapper.bindService:517 android.bluetooth.BluetoothPbap.doBind:164 android.bluetooth.BluetoothPbap.<init>:157 com.android.settings.bluetooth.PbapServerProfile.<init>:68
I/ActivityManager(  417): Start proc com.android.music for broadcast com.android.music/.MediaButtonIntentReceiver: pid=747 uid=10032 gids={50032, 3003, 1028, 1015}
I/ActivityManager(  417): Start proc com.android.deskclock for broadcast com.android.deskclock/com.android.alarmclock.AnalogAppWidgetProvider: pid=763 uid=10022 gids={50022, 1028}
I/ActivityManager(  417): Start proc com.android.bluetooth for service com.android.bluetooth/.btservice.AdapterService: pid=777 uid=1002 gids={41002, 3003, 3002, 3001, 1028, 1015, 3005, 1016, 3008}
W/ContextImpl(  417): Calling a method in the system process without a qualified user: android.app.ContextImpl.bindService:1551 android.bluetooth.BluetoothHeadset.doBind:283 android.bluetooth.BluetoothHeadset.<init>:276 android.bluetooth.BluetoothAdapter.getProfileProxy:1361 android.media.AudioService.getBluetoothHeadset:2255
W/ContextImpl(  417): Calling a method in the system process without a qualified user: android.app.ContextImpl.bindService:1551 android.bluetooth.BluetoothA2dp.doBind:165 android.bluetooth.BluetoothA2dp.<init>:158 android.bluetooth.BluetoothAdapter.getProfileProxy:1364 android.media.AudioService$AudioServiceBroadcastReceiver.onReceive:4176
V/WiredAccessoryManager(  417): init()
W/WiredAccessoryManager(  417): /sys/class/switch/usb_audio/state not found while attempting to determine initial switch state
I/PowerManagerService(  417): Boot animation finished.
I/ActivityManager(  417): Start proc com.android.calendar for broadcast com.android.calendar/.UpgradeReceiver: pid=802 uid=10019 gids={50019, 3003}
I/bluetoothd(  827): Bluetooth daemon 5.48
D/bluetoothd(  827): external/bluetooth/bluez/android/main.c:set_capabilities() Caps: eff: 0x3400, perm: 0x3400, inh: 0x0
D/bluetoothd(  827): external/bluetooth/bluez/android/bluetooth.c:bt_bluetooth_start() index -1
I/bluetoothd(  827): Starting SDP server
D/bluetoothd(  827): external/bluetooth/bluez/android/main.c:main() Entering main loop
D/bluetoothd(  827): external/bluetooth/bluez/android/bluetooth.c:read_version_complete()
D/bluetoothd(  827): external/bluetooth/bluez/android/bluetooth.c:read_version_complete() Zaid : read_version_complete
I/bluetoothd(  827): **********Bluetooth management interface 1.4 initialized
I/bluetoothd(  827): Sending read_index_list_complete ***************
D/bluetoothd(  827): external/bluetooth/bluez/android/bluetooth.c:read_index_list_complete()
D/bluetoothd(  827): external/bluetooth/bluez/android/bluetooth.c:read_index_list_complete() Zaid : read_index_list_complete
D/bluetoothd(  827): external/bluetooth/bluez/android/bluetooth.c:read_index_list_complete() Number of controllers: 0
I/ActivityManager(  417): Start proc com.android.providers.calendar for broadcast com.android.providers.calendar/.CalendarReceiver: pid=836 uid=10001 gids={50001, 3003, 1028, 1015}
I/BootReceiver(  417): Copying audit failures to DropBox
I/BootReceiver(  417): Checking for fsck errors
I/ActivityManager(  417): Delay finish: com.android.providers.downloads/.DownloadReceiver
I/ActivityManager(  417): Resuming delayed broadcast
I/ActivityManager(  417): Delay finish: com.android.providers.media/.MediaScannerReceiver
I/ActivityManager(  417): Start proc com.android.exchange for content provider com.android.exchange/.provider.ExchangeDirectoryProvider: pid=857 uid=10025 gids={50025, 3003, 1028, 1015}
I/ActivityManager(  417): Start proc com.android.mms for broadcast com.android.mms/.transaction.MmsSystemEventReceiver: pid=869 uid=10009 gids={50009, 3003, 1028, 1015}
I/ActivityManager(  417): Start proc com.android.email for content provider com.android.email/.provider.EmailProvider: pid=881 uid=10024 gids={50024, 3003, 1028, 1015}
D/CountryDetector(  417): The first listener is added
I/ActivityManager(  417): Delay finish: com.android.mms/.transaction.MmsSystemEventReceiver
D/ActivityThread(  881): Loading provider com.android.email.provider;com.android.email.notifier: com.android.email.provider.EmailProvider
I/ActivityManager(  417): Delay finish: com.android.mms/.transaction.SmsReceiver
I/ActivityManager(  417): Start proc com.android.onetimeinitializer for broadcast com.android.onetimeinitializer/.OneTimeInitializerReceiver: pid=909 uid=10011 gids={50011}
I/ActivityManager(  417): Delay finish: com.android.onetimeinitializer/.OneTimeInitializerReceiver
I/ActivityManager(  417): Delay finish: com.android.calendar/.alerts.AlertReceiver
W/BackupManagerService(  417): dataChanged but no participant pkg='com.android.providers.settings' uid=10005
D/bluetoothd(  827): external/bluetooth/bluez/android/main.c:cleanup_services()
I/bluetoothd(  827): Stopping SDP server
I/bluetoothd(  827): Exit
W/ActivityManager(  417): Unable to start service Intent { cmp=com.android.email/.service.AttachmentDownloadService } U=0: not found
I/ActivityManager(  417): START u0 {act=android.settings.SETTINGS flg=0x10000000 cmp=com.android.settings/.Settings} from pid 934
I/ActivityManager(  417): Waited long enough for: ServiceRecord{2d27ef20 u0 com.android.music/.MediaPlaybackService}
W/BackupManagerService(  417): dataChanged but no participant pkg='com.android.providers.settings' uid=10022
I/ActivityManager(  417): Delay finish: com.android.email/.service.EmailUpgradeBroadcastReceiver
I/ActivityManager(  417): Delay finish: com.android.email/.service.EmailBroadcastReceiver
I/ActivityManager(  417): Delaying start of: ServiceRecord{2d51ad70 u0 com.android.exchange/.service.EmailSyncAdapterService}
I/ActivityManager(  417): Waited long enough for: ServiceRecord{2d4fb300 u0 com.android.providers.media/.MediaScannerService}
W/BroadcastQueue(  417): Permission Denial: broadcasting Intent { act=android.appwidget.action.APPWIDGET_UPDATE_OPTIONS flg=0x10 cmp=com.android.settings/.widget.SettingsAppWidgetProvider (has extras) } from android (pid=710, uid=10008) is not exported from uid 1000 due to receiver com.android.settings/.widget.SettingsAppWidgetProvider
I/ActivityManager(  417): Delay finish: com.android.providers.calendar/.CalendarProviderBroadcastReceiver
I/ActivityManager(  417): Waited long enough for: ServiceRecord{2d28ba00 u0 com.android.calendar/.alerts.InitAlarmsService}
W/ContextImpl(  626): Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1487 android.content.ContextWrapper.startService:494 android.content.ContextWrapper.startService:494 com.android.settings.bluetooth.DockEventReceiver.beginStartingService:134 com.android.settings.bluetooth.DockEventReceiver.onReceive:115
D/WifiService(  417): setWifiEnabled: true pid=626, uid=1000
I/ActivityManager(  417): START u0 {act=android.intent.action.MAIN cmp=com.android.settings/.SubSettings (has extras)} from pid 626
--------- beginning of /dev/log/main
E/audio_hw_primary(  124): cannot open pcm_out driver 0: cannot open device '/dev/snd/pcmC4294967295D0p': No such file or directory
I/audio_hw_primary(  124): start_output_stream... 1999751064, device 2
W/audio_hw_primary(  124): card -1, port 0 device 0x2
W/audio_hw_primary(  124): rate 44100, channel 2 period_size 0xc0
E/audio_hw_primary(  124): cannot open pcm_out driver 0: cannot open device '/dev/snd/pcmC4294967295RTL871X: RTW_ADAPTIVITY_EN_D0p': No such file or directory
I/audio_hw_primary(  124): start_RTL871X: RTW_ADAPTIVITY_MODE_output_stream... 1999751064, deviNORMAL
ce 2
I/wpa_supplicant(  989): [CTRL_IFACE]wlan0: BSS RANGE=0- MASK=0x21987
W/audio_hw_primary(  124): rate 4RTL871X: nolinked power save leave
3,985 次查看
350686946
Have you solved the problem? I also encountered this problem when transplanting 8723bu Bluetooth.
