I can't execute callgrind_control.
1,348件の閲覧回数
Takashi_Kashiwagi
Senior Contributor I
Hi Community.
We are using IMX8MM and Linux4.19.
We can use valgrind but not callgrind_control.  I get the following error: Is there a workaround?
$ callgrind_control -i on
Can't locate File/Basename.pm in @INC (you may need to install the File::Basename module) (@INC contains: /usr/lib/perl5/site_perl/5.28.1/aarch64-linux /usr/lib/perl5/site_perl/5.28.1 /usr/lib/perl5/vendor_perl/5.28.1/aarch64-linux /usr/lib/perl5/vendor_perl/5.28.1 /usr/lib/perl5/5.28.1/aarch64-linux /usr/lib/perl5/5.28.1 .) at /usr/bin/callgrind_control line 26.
BEGIN failed--compilation aborted at /usr/bin/callgrind_control line 26.
$ ls /usr/lib/perl5/
5.28.1 config.sh site_perl
$ ls /usr/lib/perl5/site_perl/
5.28.1
$ ls /usr/lib/perl5/5.28.1/
aarch64-linux Exporter overload Pod vars.pm XSLoader.pm
Config.pm Exporter.pm overloading.pm strict.pm warnings
constant.pm Getopt overload.pm Text warnings.pm
We want to use callgrind_control as follows:
  1. $ valgrind --tool=callgrind --instr-atstart=no <XXXX>
  2. $ callgrind_control -i on
No. 2 doesn't work.
T.Kashiwagi
ラベル(3)
0 返答(返信)
