I am playing imx6ul.And I build a fsl-image-gui based on fsl-imx-x11.Then I burn the images into the board and start.But the lcd backlight is lighted and no gui show .How to make it correct ? Fowarding your reply.
762 次查看
guojianqiang
Use fsl-image-gui,but no gui show on imx6ulevk.What should I do now?
1 回复
704 次查看
joanxie
what display do you use?  what did you get on your display? and pls share with your log file
