[I.MX8M Plus] using DMA to do memory copy from RAM to RAM
3,129 次查看
linzhenggang1
Is it possible to do a RAM-to-RAM memory copy using DMA?
If yes, how should we do that in Linux?
P.S. We are using BSP L6.1.22
3,007 次查看
Bio_TICFSL
Yes, it's correct!, if you like to copy RAM to RAM can use the SDMA but The current drivers don't have the API to do it.
5 回复数
3,104 次查看
Bio_TICFSL
Yes it is possible, but you need to clarify which memory to what memory are you using, you can use the provided driver in the BSP.
3,094 次查看
linzhenggang1
Thank you for your reply.
Sorry, I don't understand the meaning of "which RAM and what RAM" you said.
I just want to do a memory copy in a user-space application(not from or to a peripheral) by using DMA to reduce my CPU usage.
If it is possible, could you please show me which part of the BSP I should use to do that?
Thank you very much!
3,071 次查看
Bio_TICFSL
There is no code to show how to use dma, but one can show the section 3.7.3 of the linux reference manual:
https://www.nxp.com/docs/en/reference-manual/IMX_REFERENCE_MANUAL.pdf
3,013 次查看
linzhenggang1
In 3.7.1, it said that the SDMA API driver is for other drivers(kernel mode) but not for a user space application. Is my understanding correct?
3.7.1 Overview
The Smart Direct Memory Access (SDMA) API driver controls the SDMA hardware. It provides an API to other
drivers for transferring data between MCU memory space and the peripherals. It supports the following features:
3,008 次查看
Bio_TICFSL
