I.MX8 nano LPDDR4 support
EmmaT
I used the Rayson's LPDDR4 on our design and they did the SIPI test for the PCBA. Can you help check the result if it is good enough?
JorgeCas
The report covers all critical timing and power parameters for LPDDR4 operation, the board PASS the categories of your testing environment, indicating a robust and compliant design.
Just to double check, did you perform a DDR stress test? With this, we can confirm that the board does not have any issues in DDR side.
Best regards.
EmmaT
Yes, I did the DDR tress test in chamber with temperature cycle. Please check the attached log file.
JorgeCas
Thank you for the logs, with these tests you can confirm the correct operation of LPDDR section of your device.
Best regards.
%3CLINGO-SUB%20id%3D%22lingo-sub-2177927%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EI.MX8%20nano%20LPDDR4%20support%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2177927%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EI%20used%20the%20Rayson's%20LPDDR4%20on%20our%20design%20and%20they%20did%20the%20SIPI%20test%20for%20the%20PCBA.%20Can%20you%20help%20check%20the%20result%20if%20it%20is%20good%20enough%3F%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2178876%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20I.MX8%20nano%20LPDDR4%20support%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2178876%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%3EThank%20you%20for%20the%20logs%2C%20with%20these%20tests%20you%20can%20confirm%20the%20correct%20operation%20of%20LPDDR%20section%20of%20your%20device.%3C%2FP%3E%0A%3CP%3EBest%20regards.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2178556%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20I.MX8%20nano%20LPDDR4%20support%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2178556%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EYes%2C%20I%20did%20the%20DDR%20tress%20test%20in%20chamber%20with%20temperature%20cycle.%20Please%20check%20the%20attached%20log%20file.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2178340%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20I.MX8%20nano%20LPDDR4%20support%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2178340%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%3EThe%20report%20covers%20all%20critical%20timing%20and%20power%20parameters%20for%20LPDDR4%20operation%2C%20the%20board%20PASS%20the%20categories%20of%20your%20testing%20environment%2C%20indicating%20a%20robust%20and%20compliant%20design.%3C%2FP%3E%0A%3CP%3EJust%20to%20double%20check%2C%20did%20you%20perform%20a%20DDR%20stress%20test%3F%20With%20this%2C%20we%20can%20confirm%20that%20the%20board%20does%20not%20have%20any%20issues%20in%20DDR%20side.%3C%2FP%3E%0A%3CP%3EBest%20regards.%3C%2FP%3E%3C%2FLINGO-BODY%3E
