I.MX6Q. Help PWM !!
I.MX6Q. Help PWM !!
2,230件の閲覧回数
grégorycascio
hello everybody,
I am in possession of a card from Emtrion (Dimm MX6) with a freescale processor IMX6Q
I am trying to program a PWM with a variable duty cycle (freq=4KHz), but i do not know how.
if anyone can help me write the code to control the PWM or give me informations to get there.
Thank you in advance
Best regaurd
ラベル(2)
2 返答(返信)
1,850件の閲覧回数
Yuri
Please use the Platform SDK as an example. Take a look at Chapter 27 (Configuring the PWM driver) of "iMX6_Firmware_Guide.pdf".
https://www.freescale.com/webapp/Download?colCode=i.MX6_PLATFORM_SDK&location=null&fpsp=1&WT_TYPE=Sn...
As for Linux, please take a look at  Chapter 41 (Pulse-Width Modulator (PWM) Driver)
of "i.MX_6Dual6Quad_Linux_Reference_Manual.pdf".
1,850件の閲覧回数
grégorycascio
thank you for your response
I started to browse the files you told me, but my C ability are limited and I do not totally understand the test programs (pwm_test.c ...).
Can you tell me how to run a program or the steps to follow (for example: pwm_test.c) ?
Best regard
