I.MX6 Linux version
I.MX6 Linux version
1,720 次查看
mathieuturelier
I can't find the information of wich linux version are compatible with the i.MX6SX.
I need to know if an older version is compatible.
Thank you
Mathieu
标签 (3)
1,501 次查看
gusarambula
Hello Mathieu Turelier,
The older BSP releases for the i.MX6SX is based on kernel 3.14.28. You may also find the same kernel version on the Community BSP, but I’m afraid there is not an even older version available.
I hope this helps!
