Hypervisors
Hypervisors
3,262件の閲覧回数
Kusuma
Hi,we are exploring on Hypervisors,we come to know NXP i MAX series supporting for hypervisor.may i know the supporting hardware boards and also already tested boards to work on hypervisors.
thanks
3 返答(返信)
3,244件の閲覧回数
Kusuma
Thanks for your response sir!!
3,250件の閲覧回数
joanxie
I have mailed to you, pls check the document attached in the mail
3,223件の閲覧回数
chinnnu
A hypervisor, also known as a virtual machine monitor or VMM, is software that creates and runs virtual machines (VMs). A hypervisor allows one host computer to support multiple guest VMs by virtually sharing its resources, such as memory and processing. best regards Betflix team.
The hypervisor is a hardware virtualization technique that allows multiple guest operating systems (OS) to run on a single host system at the same time. A hypervisor is sometimes also called a virtual machine manager(VMM).
