Hypervisors
Hypervisors
Kusuma
Hi,we are exploring on Hypervisors,we come to know NXP i MAX series supporting for hypervisor.may i know the supporting hardware boards and also already tested boards to work on hypervisors.
thanks
Kusuma
Thanks for your response sir!!
joanxie
I have mailed to you, pls check the document attached in the mail
chinnnu
A hypervisor, also known as a virtual machine monitor or VMM, is software that creates and runs virtual machines (VMs). A hypervisor allows one host computer to support multiple guest VMs by virtually sharing its resources, such as memory and processing. best regards Betflix team.
The hypervisor is a hardware virtualization technique that allows multiple guest operating systems (OS) to run on a single host system at the same time. A hypervisor is sometimes also called a virtual machine manager(VMM).
