How to use Vivante GPU tool on iMX6 platform
6,646 次查看
felixhsu
Hi All
As below hyper link, it is introduction how to use Vivante GPU tool.
How to profile Vivante GPU on iMX6 - RidgeRun Developer Connection
But my customer follow the step can't generation .vpd file.
How to Vivante GPU tool on iMX6 platform correctly?
Thanks.
标签 (3)
8 回复数
5,529 次查看
joanxie
nxp released gpu tools for imx6 with different version, you can download what you need
https://community.nxp.com/docs/DOC-329918
5,529 次查看
felixhsu
Hi Joan
Thank for your reply.
I had click your provide hyperlink, but  the web page show "Unauthorized".
could you help confirm the web page status?
Thanks.
5,529 次查看
joanxie
one can download GPU tool from official website as below:
i.MX 6Quad SABRE Development Board|NXP
pls find "IDE - Debug, Compile and Build Tools (3)"
5,529 次查看
felixhsu
Hi Joan
The customer could get vProfiler log currently, but only got log file while playback media file from storage device(like SD card or USB), the customer want to know how to config can get MIPI CSI vProfiler log file.
Thanks.
5,528 次查看
joanxie
do you mean vpd file? if yes, this is created by vProfiler, your cutomer couldn't creat it?
5,525 次查看
felixhsu
Hi Joan
Yes, I mean is vpd file, the customer can generate vpd file when playback video stream, but use MIPI CSI capture image can not generate vpd file.
Thanks.
5,529 次查看
marcomadrigal
Hi Felix,
The profiler picks GPU usage statistics. When you tested with video playback I assume you might use a G2D-based element or used the GPU somehow for display. I am not aware of how is your customer capturing or how is the pipeline (if it is GStreamer), but if the GPU is not in use I would expect no profiling data is acquired.
-Marco
GStreamer Development | Embedded Linux Development | Linux SDK
5,527 次查看
joanxie
"Can you try as follows?
  1. vim /linux/drivers/mxc/gpu-viv/config
  2. make sure you add the following lines at the end of this file:
i. VIVANTE_PROFILER = 1
ii. USE_PROFILER = 1"
