How to use Parallel CSI( 16 bit camera ) interface on IMX6Q
2,153 次查看
sun_hua
Hello all.
          I’m trying to interface IMX6Q with a 16 bit camera module which directly gives YUV422 format output with HSYNC , VSYNC and PIXCLK (data mode protocol: gated mode).
          I have tried to modification IPUx_CSI0_SENS_CONF reg (CSI0_DATA_WIDTH、CSI0_SENS_DATA_FORMAT、CSI0_PACK_TIGHT)but not work(base on ov5640 code).
So what shall i do, please give me some guidance.
Thanks.
2,136 次查看
joanxie
for imx6q sabresd board, which use ov5642 as parallel camera, so you can refer to that, I don't know what bsp version you use, you can refer to your bsp version document, named i.MX_Porting_Guide.pdf, which has detailed information about how to enable the new parallel camera
