How to use Gstreamer in Android 7 BSP
4,370 次查看
aravinthkumarja
Senior Contributor II
Hi All,
I'm using imx6q on Android 7 platform. To stream data from camera i need gstreamer. So how to add Gstreamer support on this Android BSP.?
Aravinth
6 回复数
4,053 次查看
joanxie
I got information from codec team:
"I haven't heard of an effort like this, but freescale codecs for openMAx are on android if that helps."
4,024 次查看
flame_knight000
@joanxie
how to invoke the openMAX service to open the camera stream data on Android sys?
4,053 次查看
aravinthkumarja
I have RAW Bayer sensor camera How can use above method to capture in Android.?
Aravinth
4,053 次查看
joanxie
imx6q can supports raw data capture, but you need to convert it to yuv or RGB, it's about capture, not about codec. then you can use the openmax extended codec package
4,053 次查看
aravinthkumarja
How to convert into yuv or RGB. Do you have any reference code.?
Aravinth
4,053 次查看
joanxie
unfortunately we don't offer this source code for customer
