How to update the uboot & kernel when linux is running
alj79
I want to update my linux under linux running.
Can somebody tell me how to do?
I.mx6ull+nand flash+ddr.
gusarambula
Hello Ansen An,
This feature is not available on the i.MX BSP. However, you should be able to look for information about the Linux livepatch feature that I think satisfies your requirement. This feature allows to update the kernel without the need for reboot. You can find more information here:
https://www.kernel.org/doc/Documentation/livepatch/livepatch.txt
I hope this helps!
