How to support MP3 playback on Android?
13614278
I build the Android 9.0 system on IMX8mini successfully.
But when I try to click a MP3 file(this file isn't damanged, it's playable on my phone), the android would pop a toast, which said 'player doesn't suppport this type of audio flie '.
How should I do to support this simple feature for this?
gusarambula
Hello Yang Songxiang,
You can find the list of supported codecs on the Release Notes of the Android BSP you are using.
It could be that the file itself has some properties that won’t allow it’s playback like the case below:
https://community.nxp.com/message/868230
I hope this helps!
