How to source code debug M4 running on i.MX 8M Mini EVK ?
1,284件の閲覧回数
EdOfTheMountain
I understand MCUXpresso IDE does not work for debugging M4 on this board.
Can anyone suggest alternatives to bare metal source code debugging on M4?
  • I understand Linux must be installed on A cores in order to boot M4.
  • This is fine as we want to RPMSG M4 data to Linux.
For this first phase, the challenge is M4 debugging.
Thank you,
-Ed
タグ(1)
1,270件の閲覧回数
joanxie
 yes, imx8mm doesn't support MCUXpresso IDE, but you can use IAR or GCC compiler
