How to setup systemctl on the Yocto
2,412件の閲覧回数
senming_lin
Currently using imx7d development, the system is yocto of Linux.
To use the systemctl order, how to set up.
1,971件の閲覧回数
Rita_Wang
Are you using the reference board and BSP from NXP?
1,971件の閲覧回数
Rita_Wang
First you need to try the systemctl command, if it not works you can find the source code and install.
