How to run rtsp server with multicast on i.mx8mmini
2,277 次查看
santhosh2
i was able to run the rtsp server using the below command,
gst-variable-rtsp-server -p 554 -u "v4l2src device=/dev/video0 ! video/x-raw,width=640,height=480 ! videoconvert ! vpuenc_h264 tune=zerolatency bitrate=500 speed-preset=superfast ! rtph264pay pt=96 name=pay0"
This works like uni-cast on the network, but i want to enable the multicast feature in the rtsp streaming. Let me know how to create the pipe for Multicast group ip, multicast port number and ttl
Santhosh Kumar S
3 回复数
2,083 次查看
diegoadrian
Are you willing to composite many streaming videos into one video output? If that is the case, I suggest you see the section 7.3.16 of the Linux reference manual.
Diego.
2,083 次查看
santhosh2
Thanks i checked the manual as you suggested, but I am trying RTSP stream and enable multicasting for port forwarding purpose. I want to stream on Multicast IP address and multicast group port num
Do let me know how to can we do
Santhosh
2,083 次查看
diegoadrian
Hello
Have you tried starting a VLC server with a Multicast IP address?
Try adding the VLC support as below in the local.conf:
IMAGE_INSTALL_append += " libdvcss"
Diego.
